Question about EliteGroup 661GX-M Motherboard
Pls i dont know my setup password so i cant enter the bios setup and the person that asembled the computer is no where to be found pls how can i get the password.
    Sniper:
  • 96 Answers
If this is really so, then you should shorten "Clear CMOS" jumper near the battery on your motherboard or even take the battery out for a short time. For detailed instruction how to do that, see your motherboard's manual
Posted on Feb 02, 2009
    Sergeant:
  • 320 Answers
Dont worry.. Dont search for him. you can easily reset the bios password. Follow below instructions...
  1. Power off the computer and make sure that it is unplugged.
  2. Open up your computer case. You need physical access to the motherboard to complete this procedure.
  3. Find a circular, (mostly) silver metallic object on the motherboard. This is the CMOS battery.
  4. CAREFULLY remove the CMOS battery, avoid touching it with your fingers, and leave it out for about 120 seconds. This will flush the CMOS memory which stores the BIOS password and all other configuration.
  5. Set the battery back into place and power on the computer.
  6. The computer should then warn you that the CMOS configuration could not be found. You can either reconfigure it yourself or restore defaults. Restoring the default configuration should be fine.
Thank you.......
  • 2,404 Answers
On your motherboard next to the silver battery is a a jumper. Its going to be labeled JP1. This will clear the BIOS Password. There will be a piece of plastic covering pins 1 and 2. What you need to do is move that jumper so it covers pins 2 and 3. Then turn on the system and you should get into the bios.
If you change the jumper and your system doesn't turn on then that means its shorting out the motherboard which is fine. Regardless put the jumper back onto pins 1 and 2 and then turn on the computer and you should get into the BIOS as well.
Let me know how this helps you.
  • 416 Answers
Remove the onboard Battery, the one like the coin chaped battery on the motherbaord. then place it back & your bios will be reset.
Start up problams
try removing the bios battery AND the rechargable battery for 10 minutes. Install both batteries and try again
Mar 18, 2010 | Advent Netbook
I would like reset the password of my d33005 motherboard
Go into the BIOS setup to reset the password. Start by rebooting the system. Before the system starts loading the operating system, the computer will give an opportunity to enter the BIOS setup utility. Usually a screen appears saying to press a key to enter the setup utility; i.e. "Hit DEL to enter Setup". You have to know what key the computer is looking for to get to Setup. DEL in used on the a lot of ASUS machines but you may that to refer to a manual or read the screen just before the operating systems to load. Once you get in, look for something related to security settings. Once it is found under the boot tab. Here is where you can reset the motherboard password. Hope this helps.
Dec 15, 2009 | ASUS Computers & Internet
Power-on password forgotten! How can the computer be started?
The Power on Password is set from the BIOS configuration. Ask that person who borrowed your Compaq for the password. Once you have this password, you can enter the BIOS configuration and remove/disable this password.
Depending how old you Compaq is, removing the BIOS battery and main battery for 15+ mins may remove this password and restore the BIOS to the factory default (insert both batteries again) and configure the BIOS Date and Time etc.
BUT if the the password is stored on an EEPROM chip then removing will not fix this problem. There are no backdoor passwords available.
Nov 19, 2009 | HP Compaq nx6110 PC Laptop
I cant remember my password to log into the computer
See if you can access the bios setup - usually F1 or F2 key right at the start up and see if that is where the password issue is. If so, try this:
Tech FAQ Forum members have reported that they were able to remove their Acer BIOS passwords by simply opening their notebooks and removing the CMOS batteries for 30 minutes.
Once your BIOS password is removed, you will need to press the <F2> key during POST (Power On Self Test) to enter the Acer BIOS setup.
Let me know.
Jon
Apr 11, 2009 | Acer Aspire 5315 Notebook
My computer has a password in the BIOS Setting. i forgot it
Do you know what the password is? If so, enter the bios and change it. When asked for a new password, just hit enter. If it asks a second time to confirm the password, just hit enter again.
Good luck
Mar 17, 2009 | Dell Inspiron 8600 Notebook
Bios password
You can break your BIOS setup password,
For that you have to open your cabinate( be careful at the time of opening, Switch off ur pc first) after this remove battery(CMOS BATTERY looking like your big hand watch battery) from the motherboard and after 30 second attach battery again
and start your PC
goto bios it want ask Passwd
Enjoy
Feb 02, 2009 | EliteGroup 661GX-M Motherboard
Acer aspire 5315 wont boot up
for password, you need to reset your bios. check your bios and enter the password given below:
for AMI BIOS Passwords:
A.M.I.
AAAMMMIII
AMI?SW
AMI_SW
AMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
for AWARD BIOS
01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
BIOSTAR
CONCAT
CONDO
Condo
d8on
djonet
HLT
for Phoenix
BIOS
CMOS
phoenix
PHOENIX
Other Manufacturer BIOS Password
Biostar - Biostar
Compaq - Compaq
Dell - Dell
Enox - xo11nE
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
VOBIS & IBM - merlin
hope this helps!
Nov 12, 2008 | Acer Aspire 5315 Notebook
Acer setup password
Need more info to help
Mar 23, 2008 | Computers & Internet
To unlock my mobile
IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Solution: Because of the wide variety of computer manufacturers and BIOS manufacturers over the evolution of computers, there have been numerous different ways to enter the BIOS or CMOS Setup. Below is a listing of the majority of these methods as well as other recommendations for entering the BIOS setup.
Notice: If you are unable to get into the BIOS or CMOS setup because of a password please see document CH000235.
New computers Thankfully, computers that have been manufactured in the last few years will allow you to enter the CMOS by pressing one of the below five keys during the boot.
A user will know when to press this key when they see a message similar to the below example as the computer is booting. Some older computers may also display a flashing block to indicate when to press the F1 or F2 keys.
Press <F2> to enter BIOS setup
Tip: If your computer is a new computer and you are unsure of what key to press when the computer is booting, try pressing and holding any key on the keyboard. This will cause a stuck key error, which may allow you to enter the BIOS setup.
steps dont work for ya above:Try this :
Go to start
control panel
Click on User account
click on computer administrator.
Dec 04, 2007 | Gateway M305CRV Notebook
Satelite a100 bios password
How to enter the BIOS or CMOS setup.
Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
If the above steps didnt work can do this:
start
control panel
user account
Click on : Computer Administrator
Good Luck hope this gets ya back on line
Dec 03, 2007 | Computers & Internet
EliteGroup 661GX-M Motherboard Logo
88 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
