Replaced 3 ink cartridges and same message is appearing
For some reason it told me to replace 3 cartridges so I did and then the same message is reappearing on the screen. Do you think there may be a system proble?
Not sure what you mean by clean the contacts in the carraige (is this where the in cartridges reside) if so I tried this as well as cleaning the contacts on each of the ink cartridges but to no avail the message came back when I fired up the machine again.
Any other suggestions.
thanks joeNot sure what you mean by clean the contacts in the carraige (is this where the in cartridges reside) if so I tried this as well as cleaning the contacts on each of the ink cartridges but to no avail the message came back when I fired up the machine again.
thanks joe
You can't post conmments that contain an email address.
For the Canon Pixma MP220, I kept getting a message saying "Col Ink Vol Unknown" after refilling and replacing a cartridge. After reading some of the other responses it appears as though Canon cartridges contain internal chips that prevent you from using them after they have been refilled. However, I tried a few things and this is what worked for me.
1. Insert your refilled Canon cartridge like normal, close the lid.
2. The Error message "Col Ink Vol Unknown" should still appear.
3. Use the "Menu" button to scroll to "Maintenance" (press "Menu" 8 times to find it), then press "OK" to conduct a "Nozzle Check" and a coloured test will print out.
4. The Error message will still appear but you will be able to print using colour AND with black and white. For some silly reason the Canon Pixma MP220 won't print using black and white if there is no coloured ink...
Epson printer only work if there are all ink tank installed, and one of them not reach zero ink level (ink out in program). After replacing black ink, may be the other ink tanks reach zero level, so message to replace ink tank appear again. You can use the used ink tank (by refilling) if you don't reset ink level counter. Better you use the CISS ink tank (with or without outside bottle), that have autoreset function.
The ink cartridges included in the box are used to set up the printer. This type of ink cartridge is called a “host” cartridge. Once the printer has completed device initialization, they are marked as regular “trade” cartridges. This error only occurs if the printer has finished the device initialization process and one or more of the ink supplies inserted into the printer are a “host” supply.
Solution: The indicated ink cartridge(s) cannot be used after the device has undergone first-time setup. Once the product displays the message ' The following ink cartridges cannot be used after device initialization and must be replaced ', the designated host cartridge(s) (indicated by the color icon(s) on the display) that were rejected should be discarded or recycled and never used again. Replace the ink cartridge(s) with the appropriate “trade” ink cartridges for the HP All-in-One.
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
Turn on the unit.
Open the top cover to access the print cartridges.
Remove the new cartridge that is causing the message.
Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
Turn on the unit.
Open the top cover to access the ink cartridges.
After the cartridges stop moving, unplug the power cord.
Remove both cartridges and close the top cover.
Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hi there Error 50c Here we go try this out.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on. The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed. If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new color cartridge. If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges. 8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige. Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Each time
the cartridge is removed from the printer an "empty cartridge" message
appears and a blinking amber light will come on, on the printer. Holding
the paper feed button down for 3-5 sec. will allow you to override the
counter.
thanks joe
