Question about Electrolux Kenmore 3.5 cu. ft. I.E.C. Super Capacity High-Efficiency Washer
Stop working in final spin mode won't restart. after door lock there is a humming noise any help would be great thanks
Took the plate of just under the door removed 2 screws then took the black rubber boot that hooks up to the pump and cleaned out the **** that was stuck in there, pluged washer back in after a little crunhin noise everything was back to normal
Posted on Feb 03, 2009
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Kenmore super capacity washer3.5 not working lights flashes and stops
This is usually a sign that the drain pump filter needs to be dumped or an object has jambed the pump mechanism.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Stops at spin cycle
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
Feb 20, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Kenmore front loading washer/NOT SPINNING in cyle
    replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
    Feb 24, 2008 | Washing Machines
    Electrolux Kenmore 3.5 cu. ft. I.E.C. Super Capacity High-Efficiency Washer Logo
    501 people viewed this question
    Top Electrolux Washing Machines Experts
    Electrolux
    Electrolux
    Tim Whalen
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
