Question about Electrolux Kenmore 3.5 cu. ft. I.E.C. Super Capacity High-Efficiency Washer
Kenmore 3.5 cu. ft. I.E.C. Super Capacity High-Efficiency Washer stop in final spin stage, won't restart after the door is shut push start i can hear the door lock then after about 5 seconds there is a loud hum put nothing happens I did notice the bottom of the door does not fit flush and i did hold it in place but there is no difference when i do this any help would be great
    Problem Solver:
  • 3 Answers
Check and make sure the shock absorbers are ok.
Posted on Feb 25, 2010
2 Suggested Answers
SOURCE: Kenmore 3.5 cu. ft. I.E.C. Super Capacity High-Efficiency Washer
took the plate of just under the door removed 2 screws then took the black rubber boot that hooks up to the pump and cleaned out the **** that was stuck in there, pluged washer back in after a little crunhin noise everything was back to normal
Posted on Feb 03, 2009
My Kenmore 3.5 super capacity front loading washer won't start. I can hear the click when I close the door, so I know it's not the latch. The lights on the right side are all lit up (above the...
the model # would be very helpful in diagnosing the problem it usually is on a label on the rim inside the door and sometimes their is a second label on the back of it
Aug 04, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Magnet found in washer after system clean
The magnet probably was in a load of laundry to begin with.
Jun 28, 2017 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
Jun 24, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Stops at spin cycle
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
Feb 20, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Feb 02, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Kenmore front loading washer/NOT SPINNING in cyle
    replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
    Feb 24, 2008 | Washing Machines
    Electrolux Kenmore 3.5 cu. ft. I.E.C. Super Capacity High-Efficiency Washer Logo
    195 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
