Question about Car Audio & Video
Hi. i was setting up a new music system the other day and i decided to plug my cd player speakers into my new amp. i then turned the volume up too loud and it blew. do you know if it can be fixed please? thanks.
  • 54 Answers
Unfortunately you will not be able to fix a blown speaker. If you are talking about your amp, you should have a reset switch somewhere on it. If you provide me with the make and model I can help you out further.
Please do not forget to rate me
Posted on Feb 02, 2009
I have a Marantz turntable, a Marantz CD player, an Eltax tape player and a Marantz amplifier with two Cambridge speakers, how do I assemble them into a stack system please ? Thank you
All the sources, turntable, CD player and tape unit have an output. These should go in the input of the amplifier with the same name. Then only the Tape player, could have an input, for recording music or whatever. For that input, your amplifier should have an tape out. All these should be connected with cables with tulip plugs, like these.
Use the white for left on everything and red for right.
If one of the devices as a different connector, find a cable for audio, with on one end the tulip plugs and on the other end the fitting plug.
Then the output of the power amplifier it should say output or LS, can be connected with 2 wires going to the speakers.
For this the same counts, although it is difficult to see when you use electrical wires in one colour. What comes out red on he amp, should go on the same screw connector on the speaker. Just to avoid one speaker being out of phase. It will work, but could sound a little strange when the speakers are out of phase.
With the correct model names added, perhaps we could have given a more accurate answer.
Please don't test the system or switch on, with the volume button to the max. Don't switch anything on an amplifier when the volume is high, or the setting is high. A short increase of the volume, during switching can, and has very often destroy(ed) the speakers.
Mar 11, 2015 | Marantz Audio Players & Recorders
I cant hear the music very well... it is very faint and i have my speakers plugged in. how do i turn up the volume? i cant find any buttons to do so.
CD changers don't normally drive speakers (the lack of a volume control and speaker connections being a HUGE clue). What are you using for a speaker amplifier?
Sep 18, 2011 | Kenwood CD-223M 200-Disc CD Changer
I just bought the Ls21 external speaker system. They work but the volume is incredibly low and the sub doesn't work at all. Also it works without the plug being in. Very strange. Suggestions? Drivers? what...
OS these days are usually set up for additional hardware like speakers. But you should check the settings for the speakers from your computer first. To find out if the settings is the culprit, you can plug your speakers into another music player to test it. If the same issue arises, you may have to bring it back for exchange.
Mar 06, 2011 | Logitech Ls21 21 Stereo Speaker System 2 X...
I have an Onkyo TX SR 700 receiver, Bose Acoustic Mass 10 speakers, Panasonic Viera 52" flat screen with my computer connected to the receiver. The computer uses a high end sound card. The flat screen...
Hi, what causes hums from speaker is when there is no ground shield from either the power supply or from the cable you plugged into the socket from the power supply.
So you will need to check that out and replace untrusted cables for connection..
If after doing this troubleshooting exercise, you will now need to test the speaker with another set to be sure the humming sound is not coming from there.
I guess that will Do.
Have a nice day...
Feb 18, 2011 | Bose Acoustimass 10 Series IV Home...
Sound in only one speaker
With a music CD playing, and the volume on the SA-404 set to a lower (but audible) level, try the following steps while closely listening for music from the speaker that is not functioning (some crackling or screeching sounds may be heard when removing and reconnecting the cables).
Remove & reconnect the traditional RCA type audio cables that originate from the CD player at the connection point at the rear of the SA-404 several times. If the cables can be removed from the CD player, do it to that end too if no music is heard. If the audio cable is a single coaxial dolby digital type carefully do the same thing to it - at both ends if needed, too. The optical cables usually don't fail the way you describe so if they're being used it may be a problem with the CD player.
You might also try moving the RCA type cables to a different input (try TAPE or another available input) if the previous steps don't solve the problem. If the problem is present on the new input (TAPE or another available input), the issue lies with the cables or the CD player. Try connecting with NEW cables to the CD input. If still failing - try TAPE input again. If still not working, I would feel comfortable saying the CD player has some sort of problem.
Please rate this reply if it was helpful to you. Good luck!
Jul 01, 2010 | Audio Players & Recorders
Everything works fine when i play a cd it works it reads it but dont hear the music when i turn to radio i hear the music,just wondering what could be wrong help me out thanks..
First off how long have you owned the unit? Did you buy it new? Did it ever work playing cd's? it sounds like either a setting problem or a hardware problem with the unit. Once I have more information I can assist you further in trying to isolate the problem.
Thank you,
Mar 31, 2010 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
M&S DMC1 System- When I turn the power on it music does not play on the main station but does on the door stations. It only gives a humming sound.
Well it's not mainly the radio problem the problem occurs due to bad signals, anyway you can try a bigger antenna.
please check the below link for more information.......
Good Luck!!
Dec 24, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
1991 corvette stereo is not working correctly. When you turn it on it cracks & squeeks. CD players will not take a CD & the cassette players keeps kicking it out. What is the best & fasts way to find out...
I assume you have the bose system. The crack and squeek is caused by the speaker amps going bad. You can buy new amps on line. I believe that the amps are plugged in wants the speakers are out. There are people on the net that will repair these radios. You might be able to just find another similiar radio on the net. You have to decide if you want to spend the money to get it working or replace with another system.
Apr 25, 2009 | 1991 Chevrolet Corvette
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
