Question about Kenmore 60654 Microwave Oven
Microwave will not start.
I just moved into a house which has this microwave mmv1153aaw. The microwave will not start. I cannot afford to buy a microwave right now. Thanks.
  • 2 more comments
  • mercy_salgad Feb 02, 2009
    It has not been moved. Not since I moved in. It's a built in microwave.
  • William Miller
    William Miller May 11, 2010
    Does the inside light come on when you open the door?
    Do you have a display?
    Can you set the clock?
    If so, when you enter the time, does it beep when you press the Start pad?
    Is it trying to run?
  • joe May 11, 2010
    if its a built in, then its probably wired into the house wiring (no plug to plug in). however, some may locate an outlet in a hidden area (like the cabinet above the stove/microwave).
    can you locate your circuit breaker panel and see if any of the breakers are tripped?
  • joe May 11, 2010
    is it a built in or countertop model?
    if countertop model, have you moved it to another room to see if it works? was guessing maybe the GFI outlet in the kitchen needs to be reset or replaced, but need more info.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
Maytag Model MMV1153AAW vent won't turn off; we have to unplug it and plug it in to use it so the vent won't run 24/7. When we plug it back in to use it, the vent comes on within 15 seconds and might shut...
Either your thermostat or relay to the blower has faulted. Thermostat is cheap but the relay is on the control board. So either replace the thermostat P#53001373 or replace the microwave as the control board is discontinued according to the information you provided. Good Luck
Jan 02, 2015 | Maytag Microwave Ovens
I am having problems with my Maytag microwave MMV1153AAWMaytag microwave MMV1153AAW. Everything seems to be working except it does not heat up the food. Light goes on, plate rotes, timer works, but at the...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
If it is the type with an "Invertor", they are not user serviceable and should be directed to an authorised repair agent for continued safety, otherwise if conventional;
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Apr 21, 2011 | Maytag MMV1153A Microwave Oven
I have a 1000watts maytag microwave MMV1153AAW the condenserfan was running by itself on and off i disconnected the wire bacause it drove me crazy now the transformer is sparking up on me is the any...
Unfortunately, if you have cut a wire internally then any warranty will be void.
Have you investigated why the transformer is sparking? This sounds like either a serious problem with the transformer or simply a loose connection.
I assume when you cut the wire you have made sure that it is insulated from the chassis?
Mar 21, 2010 | Maytag MMV1153A Microwave Oven
I have a maytag microwave model # mmv1153aaw..the light and/or air vent turn on all by themselves..I hear a beep, go into the kitchen and the vent is running or the light is on. Is this a fire hazard??...
I have a MMV1153BAB. My service tech mentioned that if use of the surface units overheat the microwave, the microwave fan will come on automatically.
Nov 11, 2009 | Maytag MMV1153A Microwave Oven
Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Micowave power
Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
Microwave
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Jan 01, 2008 | Microwave Ovens
Maytag MMV1153AAW microwave
I have the same problem with mine!!! I spent 58 dollars to have a 6 dollar diode replaced. Now 8 months later... same prob. Replaced again myself and working fine again. Just make sure you label the wires while working on it. I didn't and it cost me 2 new fuses! Hope this helps.
Aug 06, 2007 | Maytag MMV1153A Microwave Oven
Kenmore 60654 Microwave Oven Logo
278 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
