Question about Hardware & Accessories
Baldwin 6321 mortise:when locked can open from either side
I installed the baldwin mortise 6321 and glass knobs and keyed outside bolt. When I lock the door from inside and bolt is extended, you can turn the outside knob an the door will open and the bolt will recess thanks
  • Anonymous Mar 25, 2014
    See summary.
  • 10 Answers
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Posted on May 08, 2009
How to install quarter window that flips out on 2003 dodge Dakota. 2 door.right side
REMOVAL
(1) Remove quarter trim panel.
(2) Remove the bolts attaching the latch to the cab
side panel.
(3) Remove the nuts attaching the frame/hinge to
the B-pillar.
(4) Remove the glass from the cab.
(5) If necessary, remove the latch from the glass.
INSTALLATION
(1) If removed, install the latch to the glass.
(2) Center the window glass at the opening, insert
the hinge studs in the B-pillar holes, and install the
nuts.
(3) Attach the latch to the rear side panel with the
bolts. Tighten the bolts with the latch in the lock
position and pushing rearward on the latch.
(4) Test the vent window for water leaks.
(5) Install quarter trim panel.
INSTALLATION
nuts.
Oct 02, 2016 | 2003 Dodge Dakota
How to fix or replace the lock dial.
Many door knob and lockset problems can be corrected before they become so serious that the lockset does not work at all. Often, a malfunctioning latch assembly or lock mechanism causes the problem. An improperly functioning latch may be the result of a poorly fitting door. The lock mechanism may not work simply because the lock is dirty or dry and needs to be lubricated with graphite (do not use any type of oil because this will gum-up the works).
For serious lock problems, it is usually best to call a locksmith or to replace the lock entirely. Most interior door knobs are relatively inexpensive to replace; it doesn't really pay to have these professionally repaired unless they are special. You can buy door knobs online.
©Don Vandervort, HomeTips
Cylindrical Lockset Diagram
Exterior latches and locksets, on the other hand, can be very pricey. If you need a pro to fix problems with a high-quality door knob or lockset, removing the hardware and taking it to a locksmith is usually far less expensive than having the come to you.
Door Latch Is Misaligned If a door latch does not operate smoothly, the latch bolt on the door may not be lined up properly with the strike plate on the doorjamb. Repairs range from making minor latch adjustments to repositioning the door.
If the latch does not catch, close the door slowly to watch how the latch bolt meets the strike plate. The bolt may be positioned above, below, or to one side of the strike plate. (Scars on the strike plate will show where it is misaligned.) It is also possible the door has shrunk and the latch no longer reaches the strike plate. Once you have figured out the problem, try one of the methods shown here.
For less than a 1/8-inch misalignment of the latch bolt and strike plate, file the inside edges of the plate to enlarge the opening.
If the latch does not reach the strike plate, shim out the plate, or add another strike plate. If the latch still will not reach, shim out the door's hinges. Replace the door with a wider one as a last resort.
For more than a 1/8-inch misalignment, remove the strike plate and extend the mortise higher or lower as necessary. Replace the plate, fill the gap at the top or bottom with wood putty, and refinish.
Doorknob Is Loose Doorknobs may become loose over time. Methods of tightening them depend upon the type of lockset. You can tighten a simple interior mortise lockset like the one shown at left as follows:
1) Loosen the setscrew on the knob's shank.
2) Hold the knob on the other side of the door, and turn the loose knob clockwise until it fits snugly. Then tighten the screw until you feel it resting against the flat side of the spindle. The knob should turn freely.
3) If this does not help, remove the knob and check the spindle; if the spindle is worn, it must be replaced. If the whole lockset is worn, it is best to replace it entirely.
Door Lock & Key Problems Door latches and locks are somewhat complex pieces of hardware with several working parts that can go wrong and cause them to be unworkable or balky. For helpful do-it-yourself repair techniques for fixing common lock and latch problems, please see How to Repair Door Locks.
Door Key Doesn't Work
If your door key doesn't work right, the first and most obvious step is to be sure you're using the right key. Once you get the door open, try the key again. If it works easily, the deadbolt isn't engaging the strike plate properly. If it doesn't work any easier, lubricate the lock with graphite. Then spray a little graphite onto the key and try it several times.
If the key turns but doesn't unlock the lock, disassemble the lock so that you can be sure the cam or tang is properly engaged with the bolt. Replace any broken parts and reassemble the lock.
Is the lock frozen? If the key won't go into the lock, ask yourself if the weather is cold enough for the lock to be frozen. If it is, you can heat the key and insert it gradually into the keyway. Repeat heating and inserting the key until the ice has melted. Or you can use a lock de-icer, as discussed below under Door Lock Works Slowly.
Is the key new? A new key that won't go in or work properly may have rough spots that need to be filed off. To find them, hold the key over a candle to blacken it with soot and then turn it very slightly in the lock and remove it. File down any shiny areas where the soot was removed by the rough spots.
Exterior locks can freeze, interior locks get dirty, and small internal parts eventually wear out or break. Before you buy a replacement lock, try some quick remedies:
Victor
Aerosol lock de-icer thaws and lubricates a frozen lock.
Put some graphite into the keyhole, either by squeezing it from a tube or dusting it onto a key, and then operate the lock a few times to work the graphite into the mechanism.
Lock de-icers contain alcohol and other lubricants that help to dissolve gummy, dirty deposits. The last resort is to disassemble the lock to see if something has jammed or is broken-you may be able to set it straight or replace the part without buying a whole new lock.
Entire Lock Cylinder Turns
A cylinder turns when the setscrew(s) meant to hold it in place become loose or broken.
Mortise lockset: Remove the faceplate (if there is one) at the door's edge and locate the one or two cylinder setscrews. They should be in line with the center of the cylinder. Tighten the setscrew(s) by turning clockwise-be sure they engage the slot that runs along the edge of the cylinder (the key slot should be perfectly vertical). Replace the faceplate.
Surface-mounted rim lock: Unscrew and remove the cover, called a "case." Tighten the cylinder setscrews. Replace the case.
Lock Doesn't Latch Properly
When a door latch doesn't click into position, it usually means the latch and the strike plate are out of alignment. Tighten the hinge screws and then try adjusting the strike plate by loosening its screws and shifting it slightly.
If door latch doesn't align, adjust the position of the strike plate.
When possible, it's easier to file the slot in the strike plate a little bit so that it will receive the latch. Shifting the strike plate's position usually involves mortising the jamb, filling part of the old mortise, and so forth. You can also solve misalignment by replacing the strike plate with an adjustable one.
A latch can stick for many reasons, most of which are easily fixed. Check that the hinge screws are tight. If the door is out of alignment, the latch will bind. Also check the knob and lock assembly for loose screws or misalignment. Finally, look closely at the strike on the door jamb-if it's blocked or out of adjustment, the latch won't run freely in and out.
Deadbolt Is Stuck
The chances are good that the bolt is having a hard time finding the throat in the strike plate. Be sure the strike plate is secure and in reasonable alignment with the bolt. You can file the edges of the strike plate a little, and even slightly round the edges of the deadbolt's end. If this doesn't work, you'll probably have to remove the strike plate, fill the screw holes with glue and wood matchsticks, reposition it properly, and rescrew it in.
Key Is Broken Off in Lock
Use needle-nose or long-nose pliers to extract a broken key.
Using pliers, try to grip and pull the key straight out. If you can't get a grip even with needle-nose pliers, cut off a coping saw blade and, with the teeth pointed outward, insert the blade into the keyway and try to hook and drag the key out. As a last resort, remove the cylinder. Insert a stiff wire into the cam slot at the back of the cylinder and push the key out. Or take the cylinder to a locksmith.
Featured Resource: Find Local Pre-Screened Locksmiths
Call for free estimates from local pros now:
1-866-342-3263
Aug 14, 2016 | Breville 800GRXL Die-Cast Indoor Barbeque...
Remove outside mirror on 2012 chevy traverse
You need a special puller for the inside door panel. Have to go to an autoparts store for it. Then you take out all the screws on the door panel. The you use the puller on the bottom and sometimes the sides to LOCATE and REMOVE the fasteners..Lift the panel up and away from the door. Careful about any wires that might be connected to switches. Unplug those if present. You will now be looking at a sheet of sound deadening material that has a tar like substance on it. You cannot really save this and it is messy. remove it and then you can see the internal door and window parts. Be careful because the parts are sharp. Long sleeves and gloves are recommended. See if you can reach in under the window and feel for the bolts. If you cannot then the window has to be removed. Locate and remove the glass retainer and remove the window. Then remove any bolts holding the window mechanical parts. Then you should be able to get to the bolts for the mirror.
Jun 07, 2015 | 2012 Chevrolet Traverse
How do I remove the doorknob to possibly oil it?
it would depend on the door knob construction and what was stiff inside it.
The problem could be part of the handle or part of the lock mechanism.
For a typical indoor door lever handle, undo the screws on the face plate and take the handle off and oil as appropriate. You may have oil handles on both sides of the door.
For a rotating door knob handle there is generally a single screw on the underside of the knob
For a lock mechanism, you could just spray oil inside the mortise moving part (you wouldn't have to dismantle anything to do this!).
However to dismantle it, you'll need to remove handles on both sides of the door, remove the square bar that slots between both handles and remove the lock mechanism (you may have to remove locating screws that exist on the mortise face. If lock mechanism is user serviceable then there will be screws to undo to allow it to be dismantled. If none exist then it is probably worth buying a new one.
Oct 16, 2014 | Hardware & Accessories
New deadbolt notworking?
You have the lever that goes from the key cylinder part of the lock through the striker portion of the locking assembly turned part way, either in the wrong direction or not turned enough in the right direction so if you take the inside portion of the lock off and pull the outside portion out of the door and rotate the lever to its proper position and then put if all back together in the correct sequence it should work properly.
Sep 19, 2014 | Schlage Aged Bronze Grip Handle Entry Set...
Our back door (double glazed with locks at top, middle and bottom) has become permanently locked from the inside. It would appear that the lock at the top has bolted shut. (We have safestyle doors and...
Hi, W/D here.
Easy fix. Your upper locking bar has slipped. While someone is holding the door handle in the open position, you'll need to push the upper lock bolt back far enough to get the door open. You can slide it back carefully with a screwdriver or knife, a little at a time, while holding slight tension on the door with the handle. OK, door's open. Remove the inner door lock cover plate. The lever and locking knob will come off with it. Remove the mortise cover plate, on the edge of the door. Insert a small, thin bladed into the upper alignment slot in the lock behind the mortise cover plate, and loosen the upper allen screw behind the inside lock cover plate. Use the screwdriver to engage a slot in the locking bar, and raise or lower the bar until you have it level with the alignment slot. Tighten the allen screw.
Sometimes, the bar is so far out of alignment that you will have to gain access to the other end of the bar, in order to raise or lower it. This is done by removing the plastic cover on top of the door, and using needle nosed pliers to move the bar.
This should fix you up.
Best regards, --W/D--
Jan 28, 2011 | Locks & Locksmithing
Door lock assembly
Toyota Corolla 1988-1997 Repair Guide Door Locks - REMOVAL & INSTALLATION
(see Figure 1)
  1. Disconnect the negative battery cable.
  2. Remove the door panel and watershield. Remove the service hole cover.
  3. Disconnect the door outside opening linkage. Remove the two mounting bolts and remove the door handle if in need of replacement.
Fig. 1: Power door lock control system component locations
  1. Disconnect the lock cylinder control linkage.
  2. Remove the lock knob and the child protector lock lever knob.
  3. Remove the lock assembly retaining screws and remove the door lock. If equipped with power locks, disconnect the electrical harness.
  4. To remove the lock cylinder, remove the lock cylinder retaining clip and pull the cylinder from the door.
To install:
  1. Coat all the door lock sliding surfaces with multi-purpose grease.
  2. Install the outside handle with the two retaining bolts, if removed.
  3. Install the door lock solenoid linkage to the door lock.
  4. Connect the link to the outside handle.
  5. Install the lock knob and the child protector lock lever knob.
  6. Install the door opening control link tighten the mounting bolts to 48 inch lbs. (5 Nm).
  7. Install the door lock cylinder control linkage.
  8. Install the door panel and watershield.
  9. Reconnect the negative battery cable.
Hope help with this; remember rated this post and thank you for using Fixya.
May 20, 2010 | 1991 Toyota Corolla
I have Kwickset door knobs on my outside doors. I
The instructions they send are almost always generic and cover more than one subject.
If you insert the key and turn it all the way clockwise, you should be able to insert the tool tip they sent you into the hole on the shank part of the handle. Pull straight out and it should come off. Some times it takes several attempts to do.
Next turn key counter clockwise back to starting position and remove key. Dump lock out of handle, paying attention to orientation. Turn lock 180 degrees and reinsert back into handle. Put lock and handle back on to door and reinsert the key. Turn key clockwise and push.... remove key.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Jan 20, 2010 | Kwikset Professional Door Lock...
I would like to install a used mortise lock in an old door which has the cut out for a smaller mortise lock. I am hoping to use a power tool and not a chizel because the door is a 100 year old hard wood...
Can't think of a bit which will do what you want but you could stitch drill it to the desired size then chisel the holes square this should reduce any chance of cracking
Jun 29, 2009 | Eagle EKB-2020 Key-2020 Key Box w/ Mortise...
Lock intruction manual
Call Baldwin Call Toll Free (877) 560-2818 and ask them to send you or fax you or email you a new manual
or
http://www.baldwinbrasshardware.com/?gclid=CNb1t_vq1ZkCFdxM5QodEQPbXg is their link.
Apr 03, 2009 | Irwin Industrial Tool Co No.10R - 3 10"...
Hardware & Accessories Logo
462 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
