Question about Mad Dog Multimedia Dominator (MDED1F) External Floppy Drive
I am trying to transfer photos and data from 3.5 disk to cd's and memory cards but when I insert a disk it is telling me that the disk is not formatted and ask me if I want to format now. I know these disk have data on them. I have transferred a few already, but now when I put those in my drive I am getting the same message. How do I retrieve my data.
    Problem Solver:
  • 7 Answers
You can't retrieve data from those disks on whatever computer you're using it on. It apparently doesn't support the same format that you used save the data to the disks initially. I don't know what you can do, other than just trying the disks on any computer you can find that has a floppy disk drive until something works. Personally, I absolutely hate all the formats there are for removable disks. I have problems just like that with CDs all the time.
Well, good luck.
Posted on Feb 16, 2009
My Canon eos Rebel xs was working fine for over a year. Now it is telling me that my Card is not Formatted. Is there anyway to retrieve the pictures be for I format?
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 24, 2012 | Canon EOS Rebel XS / EOS 1000D Digital...
Tip
How to repair memory card
  1. Download and install a data recovery program. The first thing you want to do when you encounter a memory card error is to attempt to recover important files. There are a number of programs available to accomplish this. Photo Rec is a powerful, free option for most operating systems, but lacks a graphical user interface, which can be intimidating for less advanced users. Find the data recovery program you are most comfortable with in terms of price and features.
    Insert the memory card into your computer's memory card reader. Use a USB card reader or connect your device to your computer via USB if your computer does not have a card reader.
    • Some devices require that you enable disk use via USB through its settings before your computer will recognize it.
  3. 3
    Run your data recovery program. Follow the procedure to recover files for your data recovery program and recover what you can from your damaged memory card.
  • 2
    Go to Computer. Open the Start menu and click Computer. Type Computer into the search box if you cannot find it.
    • In Windows 8, Computer is called This PC, and can be found by searching forComputer from the Start screen.
  • 3
    Find your memory card. Your memory card will be listed under Devices with Removable Storage (Devices and drives in Windows 8). It should be named something like "Removable Disk (M:)". Make note of the drive letter, as it will be needed later.
    • If you cannot tell which disk is your memory card, remove your card with this window open and note the drive that disappears. Remember to reinsert you card before continuing.
  • 4
    Open Command Prompt. From your desktop, press ? Win+R to open the Run dialog. Enter cmd and click OK.
  • 5
    Run Check Disk fix and recover. On Command Prompt, type chkdsk m: /r, where m: is the drive letter of your memory card, then press ? Enter to begin.
    • Depending on the errors found during this process, Check Disk may ask for your input in regards to what action it can take. When this occurs, answer "Yes" and press enter to continue.
    Part 3 of 3: Repairing a Memory Card on Mac
    1. 1
    2. 2
      Run Disk Utility on your Mac. Disk Utility is a Mac operating system utility that can perform disk-related tasks. Select Go from your Finder menu and select Utilities or press ? Shift+? Command+U from the Finder to open your Utilities folder. Open Disk Utility from your Utilities folder.
    3. 3
      Select your memory card. Find your memory card on the list of connected drives. If you do not know which drive is your memory card, remove it and reinsert it to determine which drive it is.
    4. 4
      Repair your memory card. In the First Aid tab, check the "Show details" box, then click Repair Disk. If Disk Utility reports any errors, repeat the repair process until it finishes and reports "The volume appears to be OK".
    on Aug 24, 2015 | Philips SAC2530 - CD/DVD repair kit...
    How do i transfer photos from my htc mobile to my pc
    You have the following choices. I dont have the exact model of your mobile but i hope this will give you an idea.
    1. Transfer image using bluetooth.
    2. Transfer using data cable
    - just plug the data cable HTC to PC then browse also..
    3.Transfer using memory card reader.
    -Simply removed the memory card of your mobile and insert it to memory card reader.
    - insert memory cardreader to PC the browse..
    Jun 12, 2011 | Computers & Internet
    How do I download photos from my phone to my PC
    The photos can be downloaded from the mobile to pc in many ways
    1.By using blue tooth.if your phone and pc has blue tooth you can transfer it
    2.If the phone have memory card you can insert memory card in memory card reader and download photos.
    3.you can also use the Data cable of the mobile and transer files
    Aug 10, 2010 | LG Cell Phones
    The camera says that the memory is full but it only have 3 photos my memory card is empty how to back up the photos into memory card. I cant find it in menu tool. Please help me. Thank u very much.
    Well you can try transferring Photos from the memory card to the computer by using a card reader, after transferring the photos just format your card by computer, for more help how to format the card please follow the below steps -
    1. Insert your memory card into your card reader then insert the card reader to the computer USB port.
    2. Open up 'My Computer'. You should see it under the list of available drives.
    3. Check its contents first to make sure that you have the right drive.
    4. In 'My Computer', right-click on the drive and choose 'Format'.
    Once the process is completed, take the memory card out and insert it into your Digital Camera and try taking pictures again........ If further you have the same problem then you can try to reset your camera to default settings. also make sure you select the memory card to save the captured photos.
    Please post comments if you need more help or information......
    Good Luck!!
    Thanks
    Dec 29, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
    Disk with data stored on it says that it is not formatted
    Maybe you had something with a magnetic field lying nex to the flopy drive and the code got mixed up and now the data is not readable.
    You can try with raw extraction like in CD's. you need to have a program to recover the data without having to actually decode them. I used to use Recovery Toolbox for CD's, I'm sure there's a simular programe for floppy's somewhere on the net. after recovering, things worked on the computer, although the dish was never usable since the day I got the message 'can't read data'/'no data'/'not formatted' etc.
    With floppy's I think that you'll never get the data from it by computer itself. I didn't get the data from the corrupt CD's, and they have much more advancer programs than floppy discs. so I recomend you find the program, get the data and throw the floppy away. If you have problems finding the program, post and I'll help.
    Feb 02, 2009 | Mad Dog Multimedia Dominator (MDED1F)...
    Transferring photos to sim card memory from phone memory
    Hi sir,
    You can tarnsfer all the photos to your computer by using the data transfer cable that comes along woth the mobile phone. Insert one end of the cable in ur phone and ther other end in your laptop/computer where USB sign is given. The laptop/computer would detect a new object and open all the data avilable in your mobile. You can select the photos from those folders and copy them and then paste them on your desktop.All the photos in ur sim card and memory card would reflect in your computer once the wire is inserted. Please contact me in case issue is not resolved.
    Jan 28, 2009 | Sony Ericsson K750i Cellular Phone
    Hi i am trying to upload my pictures from my LG Shine KE970 on to my computer, how do i do this?
    install the cd given with your phone and transfer photo to your system through.....else if it is in memory card using memory adapter insert the memory card into the adapter and transfer through usb.......another way to transfer photo is if your computer is bluetooth enabled transfer your photos through it
    Jul 09, 2008 | Cell Phones
    Downloading pictures onto computer
    There are Three primary ways to do this...
    1. use a (usualy supplied) data cable... normaly a USB cable... it connects to your computer/laptop , Use a Photo utility program to "find" the camera. You should be able to view the pics stored in the camera.
    2. If the camera pics are stored on a sim card then simply put that card in a multi card reader... (very inexpensive to purchase and standard on some late model PC's) and in most cases you can pull the pics directly from the card.
    3. Take the camera directly to walmart or walgreen's photo station and they usualy can pull the pics directly from it.
    give me some more info and I maybe able to give detailed help...
    mod# of camera and what model/make of your PC.
    Apr 08, 2008 | Computers & Internet
    Transfering pictures using the FlashPath Floppy Disk Adapter?
    To transfer pictures: 1. Remove the memory card from the camera. 2. Insert the memory card into the floppy disk adapter. Make sure that you insert the memory card into the adapter with the gold side of the memory card facing you and to the right and the silver side of the adapter facing away from you. 3. Insert the floppy disk adapter into the diskette drive on your computer. 4. Double-click the PhotoMAX shortcut on your desktop to open the software. 5. Click Get Photo. 6. Click Album or FlashPath. 7. Click Downlod from FlashPath. The images appear as thumbnails on the album manager window. 8. Double-click the image that you want to edit. The image appears in the image tray. 9. Remove the FlashPath Floppy Disk Adapter from the diskette drive when you are done.
    Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
    Mad Dog Multimedia Dominator (MDED1F) External Floppy Drive Logo
    137 people viewed this question
    Top Mad Dog Multimedia Computers & Internet Experts
    Alun Cox
    Steve Sweetleaf
    Steve Sweetleaf
    Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
