Question about Gestetner Copier
Code SC195 Functional Problems
This is what pops up when I turn it on. Gestetner DSc424
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Enter SP mode: Press Clear (yellow) button, 1 0 7 and press and hold the Stop (orange) button for 3 secs. Then switch off and on again.
SC 195: Serial number mismatch
Serial number stored in memory is not correct.
Enter SP mode and check the serial number of the machine with SP5-811-002.
If the stored serial number is incorrect, possible causes are;
  1. NVRAM defective
  2. BICU (Main board) replaced without original NVRAM
Good luck and please rate me, thanks.
Posted on Feb 03, 2009
Functional problem within the copier. sc1-195
chek the scaner lamp and all other tins that is copieing in the macine
Sep 15, 2014 | Gestetner DSc424 Color Copier
Service manual
http://www.gestetnerusa.biz/manuals/gestetner/gestetner_comV4.nsf/DownloadManualPaged5d7.html
Oct 21, 2013 | Gestetner DSc424 Color Copier
How do I learn how to use the scanner on the gestetner dsc424
You can download the manual from their site:
Oct 29, 2012 | Ricoh 888482 Cyan Toner For The Aficio...
Am getting a functional errror on our gestetner dsc424 to replace developer units magenta and yellow. replaced both toners, but error message will not clear, even after turning off and then on again. can...
Hello!
Did you mean what you are saying?
If the machine are telling you to change the DEVELOPER UNIT why did you change the toner and hoped to reset the massage?????????????
If the machine are telling you to change the developer unit you need to change the developer unit!!!!!
Do that and your problem is solved
Sep 09, 2011 | Gestetner DSc424 Color Copier
Hi we get error message "SC570 on an DSc424
These errors indicate a problem in fixing temperature or thermistor, confirm the line voltage
5xx series codes
Jun 21, 2011 | Gestetner DSc424 Color Copier
Functional problem sc481 , what does it mean
DRUM CLEANING ERROR ON THE MAGENTA DRUM CHECK THE CHARGE ROLLER HASNT COME LOOSE OR IS JAMMED AGAINST THE DRUM UNIT YOU CAN TAKE THE DRUM OUT AND REMOVE THE FRONT FACE PLATE BY THE TWO SCREWS AND GENTLY REMOPVE THE DRUM BY PUSHING IT PAST THE FRONT HOUSING..BE CAREFULL IT MAY JAM BUT SHOULD BE OK.. CLEAN THE CHARGE ROLLER WITH A DAMP CLOTH AND THE FELT CLEANING ROLLER WITH A DRY DUST CLOTH REFIT AND CHECK.. TO CLEAR THE CODE PRESS YELLOW CLEAR THEN 107 THEN HOLD DOWN THE STOP BUTTON TILL SCREEN CHANGES.. TURN OFF AND BACK ON.. GOOD LUCK
Jun 28, 2010 | Gestetner DSc424 Color Copier
When turned on it says to contact service provider.
It's a fuser (warm up) error.
Can only be reset in service mode by a technician once the problem is solved (lamp, fuse, or thermostat, etc)
Mar 24, 2009 | Gestetner Copier
Gestetner DSc424 says contact service provider when turner on
That depends on the service code that appears on the screen. The code will start with "SC" and then have a set of three numbers -- those numbers will tell you what the problem relates to. If it's an SC 515, for example, it's a problem with the first paper tray and can probably easily be remedied. Some other problems will require more work and possibly new parts.
Feb 02, 2009 | Gestetner Copier
339 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
