Question about Gateway Computers & Internet
I need a diagram
Hello, I was trying to re-assemble a gateway g5-233 model. But i been having some problems with setting the hard drive an the power wires back in. So I was wondering if you had a picture of the inside of the g5-233 flat desktop version. I found it at a friends house all of it appears to be there, I just want to bring it back to life. Thank you/
  • 21 Answers
Check on the motherboard make and model number.
Type this information into Google and then go to motherboard site, and they should have updates and a manual, which will have all the required information, hopefully.
Posted on Feb 16, 2009
Western Digital Hard Drive Help Needed
Hi, The drive you are connecting to this USB enclosure can be set up as an auto select, master, or slave drive by changing the jumpers. Suggest to check your USB enclosure manual to see what is required for this device as to the configuration of the drive jumpers. Regards, Rongg
Mar 29, 2014 | Western Digital Computers & Internet
Using Western Digital Hard Drive as External Hard Drive Problems
OK! First of all try to disconnect all usb's from neighbouring usb ports as they might be using up too much current resulting in your HD not having enough power to be powered up properly! Also, try to use a different usb port.
If all these fail, please use a voltmeter (if any available...) to check if your devices actually function...
Hope this helps! If not, please report back!
Where is the hard drive on a gateway all in one computer. i opened it up and dont recognize which part it is.
Which model Gateway all in one do you have?
I have a Gateway ZX4800 and the hard drive is under the center rear cover. You have to remove the smaller panel that sticks out near the base of the PC (where the RAM is located) first then the center panel that is taller will pull out and reveals the hard drive cage. unbolt the hard drive cage, remove the SATA and power cables and you can then replace the hard drive.
On other All In One PC's (like the HP TouchSmart series) there is a rear cover that is under the desktop stand that can be removed and the hard drive is in a metal rectangle cage on the left side.
So, in almost all AIO systems, the hard drive is accessible by removing one or two panels off the back of the unit. RAM for these units will also be visible too.
Nov 02, 2013 | Computers & Internet
On the image below you can see the location of the hard drive. In the manual of this model, starting from page 51 you can find information regarding how to gain access to internal components.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Sep 07, 2010 | Gateway (M520HD80G) Hard Drive
I am replacing my hard drive (Gateway GT5694) since the original crashed. I didn't realize the replacement would have a jumper to install and therefor didn't look at the original close enough to see if it...
The new hard drive should be set to master drive, if not just make sure the jumper is in the master slot. A small diagram should be on the hard drive. Then make sure you connect the hard drive to the end ribbon cable connector.
Nov 24, 2009 | Gateway GT5694 Desktop Computer
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
A diagram to assemble and dis- assemble to replace a new hard drive Will give you the diagram....but it shouldn't be needed. Bottom of laptop, with hinges facing away from you. Lower Right corner there is a 3 and a half inch panel. 2 screws removed, lift panel. There's your hard drive. If it's got screws holding it should...then remove those screws, and gently slide it right until its out of the mount. reverse steps to install new one.
Apr 30, 2009 | Computers & Internet
I'm betting that you need a new "Inverter" board, especially if it's a Gateway 450ROG.
There is an inverter that Gateway used in several models that has a known defect.
Inverters are relatively inexpensive ,and easy to replace. You could ven do it yourself if you have a little skill at disassembly / re-assembly. Tell me the model number of your laptop and I can help you more
Apr 10, 2009 | Gateway 40G / 40GB for laptops /...
Computers & Internet Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
