Question about Philips 43PP9202 43" Rear Projection Television
Adjusting to the proper color
I can not seem to get my 43 inch phillips to the proper color.I was watching a movie on my tv (transformers) and played with the picture setting and it looks yellowish. You have tint,color,brightness,sharpness. How do you get the picture to the normal setting or what looks good. HELP
  • 4 Answers
Tint would be the control that will control the color balance, but this sounds like it may be deeper then that. Turn your color all the way down so that you have a black and whit picture. If the picture is still yellow then you have a problem with the blue picture tube.
Posted on Feb 18, 2009
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
CAN"T PLAY MOVIES FROM MY USB ON 32 inch HISENSE TV. What format should the movies be in? Presently they are in avi
i have a 32inch hisense led tv i watch movie using usb but it stop and back to the begining when the movie is over 2hours.. hope you can help me .
Mar 08, 2013 | Televison & Video
GE Rear Projection TV set with "3D" colors
This is a common problem that was NOT caused by watching the 3D movie! Bad solder connections on the high voltage transformer have caused a solder in fuse to blow. The transformer will have to be resoldered and the fuse replaced.
Jul 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Jul 10, 2009 | Televison & Video
Blue tent while playing movie
what type cables are hooked to the dvd, check and make sure that the cables are seated properly or chang the cables , could be the dvd player also
Feb 16, 2008 | Samsung LN-T4671F 46 in. LCD Television
PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
43 inch phillips projection t.v
There is no bulb or color wheel in a standard projection set. The standard projection set has convergence output IC's that correct the 3 colors around the edges of the picture. If one of these IC's burns out then one color may sag toward the center at the top. The defective convergence IC will have to be replaced and the convergence circuits realigned and that should be done by a qualified tech.
Aug 07, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
207 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
