Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Ge profile, will not fill with water.
Has worked fine for years. All at once, no water.
  • 5 Answers
If it is a ld-12 it is the control board
Posted on Feb 02, 2009
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
WATER NOT FILLNG IN GE PROFILE DIHWASHER
It ended up being a simple fix. Soap had dried on the floater (water sensor device) and it could not move, therefore no water was going in. I poured hot water and vinegar into the washer and ran a complete cycle and it is working fine now
Jun 10, 2009 | GE 24 in. Profile PDW7880G Built-in...
GE Profile will not run cycles. Runs water continuously.
OK, i would do a hard reset by unplugging for 2 minutes. if the problem still exists, this is defiantly a malfunctioning relay. it will have to be replaced.
Mar 06, 2009 | GE Profile WPRE6100G Top Load Washer
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
115 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
