Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Grease caked on the oven from a spill
I cooked a turkey yesterday and there was a whole in the pan which caused a large amount of grease to spill ~ smoke was coming out of the oven. I immediately shut off the oven (luckily the turkey was cooked), and while I cleaned some of the grease off, there is still a large amount of grease which has hardened in the oven.
I'm afraid to turn on the self-cleaner because of the intensity of the oven when it's turned on to the self-cleaner. Can you please tell me what household product I can buy to first clean the grease off and then put on the self-cleaner?
I have a gas General Electric oven?
Thank you
    President:
  • 2,976 Answers
First--Look for a couple release levers around the bottom of the oven. You should remove the bottom and scrape the spilled grease off. If you can't remove it, clean off what you can before using a standard ovencleaner. It will still need to be washed well before firing it up.
Easy Off Oven Cleaner has been around for years.
Posted on Feb 21, 2009
    Genius:
  • 2,120 Answers
Regular oven cleaner such as Easy Off
I spilled a lot of bacon grease in my accubake oven when i turned the self cleaner on it flamed
Wipe out the oven with paper towels. As much as you can. Try putting some baking powder down to absorb the grease then wipe it out. If the flames are not huge it should be ok. Mine did that once and burned out the grease and did not damage the oven, but they were very small and burned down quickly.
Aug 10, 2014 | Whirlpool Accubake RF362LXTT Electric...
MY OVEN HAS GREASE SPILLAGE IN THE BOTTOM. I WAS BAKING AND IT STARTED TO SMOKE. I want to remove the grease first before I start the self cleaning. What should I use to best remove the grease without...
best way to loosen grease in the oven area is to place an oven safe pan with some water in it and run the oven at 200 degrees for thirty minutes. This help in the removal grease without using anything but water.
Dec 17, 2010 | Thermador PRDS366US Dual Fuel (Electric...
Maytag convection range model MER5875QAB The convection fan runs really slow, I can count the revolutions. I can turn it by hand but it won't spin. Is there a service for the fan (cleaning, oiling etc)...
I usually disconnect the fan and soak it in alcohol to remove the grease buildup from cooking oils and animal fat. This fixes most of the fan motors I have ever dealt with.
Remember that these fans do not have bearings. They float on a brass bushing which is why the fan eventually becomes caked with grease and slows down.
Nov 16, 2010 | Maytag Kitchen Ranges
Oil mystierously appears on bottom pan of oven, 465, when in use.
Larry,
Your stove has no parts that contain any type of oil or grease. It's possible that the prior owner accidently spilled some oil on the stove. I would continue to clean up the grease and hopefully it will all run down and after the clean up, it will disappear.
You are welcome to contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service for any questions or should you need appliance parts or accessories.
We hope this helps and we wish you a Happy New Year! Ella
Jan 03, 2010 | Kitchen Ranges
When our oven is heating up especially and
I'll check the oven bottom pan first, the bottom of the bottom pan ( flame spreader ) must broken off, check the welded area it must cracked. You can either reweld it back on or buy a new pan. Dynasty / Jade ph # 800-884-5233
Nov 30, 2009 | Dynasty DGRSC 36-4CB Gas Kitchen Range
How to clean an oven window
After a long period, grease can get caught and cooked between the double windows. You can usually remove them with a screwdriver to clean them. Beware it may void a warranty if that is an issue though.
Caked on grease is best removed by letting the glass soak in detergent (like dawn) if it comes all the way out. If not, you can wipe it down with a detergent on a sponge. Then pat it dry with paper towel and use a solution of white vinegar and water to make it shiny and get the baked bits off. If your warranty won't allow you to remove the double glass, you can at least get it cleaner by using this method on the inside and outside. This won't solve what is jammed between the double window, but will probably make it so you can see inside.
May 05, 2008 | Kitchen Ranges
We have a ge self-cleaning radiant range. I accidently spilled hot grease from steaks when I was removing them from the broiler. The grease dripped down inside the glass on the front of the oven. Is...
If you are saying that the grease got in between the layers of glass (lamination), then you will have to disassemble the door, clean the glass, and reassemble. I haven't done this job on your particular model, but have on others and it is a tedious & time consuming task.
If though the grease is just cooked onto the inner surface of the glass on the oven door, you could use a single edge razor to scrape the gunk off (being extremely careful not to flip the blade causing you injury), as you would ice off a windshield with an ice scraper. There are handles made to keep the blade secured while using it (making it less likely to flip and injure the user).
Apr 05, 2008 | Kitchen Ranges
How to clean an oil spill
All of you are MORONS. the guy is asking "quite clearly", how to remove the bottom pan so he can clean under it. It's quite obviouse he understands how to clean the the main part of the oven. He just want to know HOW TO REMOVE THE BOTTOM PAN.......
Dec 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
563 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
