Question about Goodman CLQ36AR49 Air Conditioner
Heater kicks in flames go on and then off keeps trying to ignite
Heater is just blowing cold air and at the same time the flames are trying to go on. This continues on and on.
  • Chris Parrish May 11, 2010
    ok do the flames stay on or do they shut off after a few seconds and the blower stays on?
Is not turn on the hit
Posted on Feb 10, 2009
  • lakeplace Feb 10, 2009
    the heather not make hit
Hayward 100 series not blowing out air
if new heater and wired 120 volt check wiring try to reverse sounds like not showing rectification if old unit bad flame sensor
Jul 11, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
THE IGNITION DON'T FLAME AND THE HEATER BLOW COLD AIR
Can you verify if the igniter is receiving 120 volts?
Dec 09, 2012 | Goodman GMS90703BXA Heater
Heater will not stay on rm60 reddy heater
When you say the heater is coming on does it actually ignite or is the motor just running until the safety circuit kicks it off? The air pump on you heater should blow at 3.5 to 4 psi which runs up to the nozzle which is a venturi which sucks the fuel out of the tank. The motor will generally run for 20 to 30 seconds trying to ignite. If the flame sensor does not sufficient flame during the time it shuts the motor off. Check these items and let me know what you find.
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Furnace does not work when windy outside. Has an electric ignite, it either won't kick on at all, or it just blows cold air. The slightest breeze will cause it to not work. When there is no wind it works...
The problem is withthe venting. Your vent pipe goes out of the house in such a way as to catch the air when it is windy and cause the pressure switch to cut out. The flame may only run for a short time, then shut down and then restart. The heat exchanger never gets hot enough to give you warm air.
Check where the vent pipes exit the house. Try adding on an elbow and turning it so that the wind cannot blow back the pipe. Turning it down towards the ground often is good. Make sure that the exhaust cannot recirculate back to the intake pipe also.
Also check that there is no water build up hanging in a pool where the vent pipe may have sagged a bit. this will make the pressure switch much more sensitive.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 11, 2009 | Coleman Propane Forced Air Heater...
Igniter kicks the burners on, but about the time the main fan turns on, the burners blow back out. blowing cold air out as a result. plz help!!!
From what you are saying, I would bet you have acrack in the heat exchanger.See if you can watch the burner when the fan comes on. You should see the flame blow out and either move away from the flame sensor or onto a a rollout switch. I'm afraid the only remedy is to replace the heat exchanger or the furnace, depending on the age of the furnace.
Nov 16, 2009 | Heating & Cooling
Fan runs backwards forces flame to blow back into heater instead
cracked heat exchanger not cheap replace unit ur motor just doesnt change rotation on its own
Jan 13, 2009 | Reddy Heater RLP100 Portable Forced Air...
Goodman CLQ36AR49 Air Conditioner Logo
32 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
