Question about HP DeskJet 970cxi InkJet Printer
I cant istall my printer a table say the file hpfud50.dll is s neededi have download it and it don work either
    Genius:
  • 1,913 Answers
  • kishor khatri
    kishor khatri Feb 02, 2009
    u see there "driver informstion"
    check on bottom u find " 970-enu-xp.exe double clik it then save on desktop then simple open it then next next .then it installs driver .
No sound no audiono ethernet hard error c0000221
Here is an explanation of your problem - http://support.microsoft.com/default...;en-us;Q314474
and ways of fixing it. Regards.
Download the file here http://www.dlldump.com/download-dll-.../download.html and replace the corrupted file .. it should be in C:\Windows\system32
When you boot up, go into Safe Mode (tap the f8 key as its starting to boot up and select Safe mode from the resulting menu). Now go to the 'problem' dll, right click on it and select rename. Rename it to ntdll.dll.old then paste the new .dll into the system32 file
Hope this helps
Apr 16, 2014 | Dell DimensionTM E520 PC Desktop
When trying to scan, my scanner software program comes up with "twain_32.dll" not found. My HP PSC 1350 Printer/Scanner has always worked before.
http://www.fix-all-dll-errors.com/twain_32.dll/
Just visit this site...this will help in case of missing or downloading dll's , also if dll's are corrupted or errors in dll's..!
I also registered few dll's from this site...worked in my case. :)
Dec 24, 2010 | HP PSC 1350 All-In-One Thermal Printer
Mine is Lexmark X3470 model. When i tried to scan using Imaging studio, the msg. msvcr71 dll was not found. Reinstalling this application may fix this pbm comes. The scanner does not work. only motoring...
You need to have this file, msvcr71 dll So go here,  http://www.dll-files.com/dllindex/dll-files.shtml?msvcr71      Download the file. and then copy it to \Windows\system32\ also it won't hurt to put it in the Root Directory as well. That will at least eliminate that DLL problem may work now.
Feb 01, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have two Epson SX100 printers, one work, one Home. When i try to print from the second all i get is a message saying please install E_DMA130.DLL
E_DMA130.DLL ALWAY ASK ME WHEN I INSTALL EPSON STYLUS T11, my software canot work properly so how i can fine E_DMA130.DLL
thk
Oct 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I cant install my printer
you can download that dll file here
http://www.driverskit.com/dll/hpfud50.dll/979.html
please remember to rate me.
Feb 02, 2009 | HP DeskJet 970cxi InkJet Printer
Cant download itunes or any other programs
Download this file http://www.dlldump.com/download-dll-files_new.php/dllfiles/S/slbrccsp.dll/5.1.2518.0/download.html
If that doesnt do it, download these six files as well:
http://www.dlldump.com/download-dll-files_new.php/dllfiles/S/sccbase.dll/5.1.2600.1024/download.html, http://www.dlldump.com/download-dll-files_new.php/dllfiles/S/sccsccp.dll/5.1.2600.1029/download.html, http://www.dlldump.com/download-dll-files_new.php/dllfiles/S/slbcsp.dll/5.1.2600.2094/download.html, http://www.dlldump.com/download-dll-files_new.php/dllfiles/S/slbiop.dll/5.1.2600.2095/download.html, http://www.dlldump.com/download-dll-files.php/dllfiles/W/wmasf.dll/download.html and http://www.dlldump.com/download-dll-files_new.php/dllfiles/W/wmidx.dll/9.00.00.3250/download.html
Hope this helps
Jan 17, 2009 | ASUS Eee PC 900 Notebook
Lost install disk cant istall after pc repair
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Epson Stylus C46 : Drivers & Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthefile,doubleclick on the file, then if you get introubles,follow theinstructionsbelow to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
Printer driver
SOLUTION FOR HP 3055 SOFTWARE INSTALL ERROR!
THE METHOD:
Search for file "DPINST.LOG" on your computer. This will show you specifically what ERRORS are taking place. After three seperate trial and errors I found out that three different files are missing from the software package downloaded from the HP driver support site. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
"HP LaserJet 3050/3052/3055/3390/3392 PostScript Print Driver Package" ~364mb
MISSING FILES:
UNIDRV.HLP
UNIDRVUI.DLL
UNIRES.DLL
FIND HERE:
http://www.filewatcher.com/m/UNIDRV.HLP.15343.0.0.html
http://www.dlldump.com/download-dll-files_new.php/dllfiles/U/UNIDRVUI.DLL/5.2.3790.120/download.html
http://www.dlldump.com/download-dll-files_new.php/dllfiles/U/UNIRES.DLL/5.2.3790.120/download.html
STEPS:
Download missing files then copy to the unzipped software folder. Which is most likely
"C:\hp_LJ3050-3052-3055-3390-3392_Full_Solution\"
Jun 24, 2008 | HP LaserJet 3055 All-In-One Printer
Table Mismatch Download Again
This is the only Solution to "Table Mismatch"...
If a “Table Mismatch” is displayed, recycle power and reflash the printer. Can get “Table Mismatch” after replacing CMX Board.
“Table Mismatch”
Flash Upgrade Instructions Using the printer’s Parallel Port: You have ethernet, you can FTP download.
1. Print a configuration on the printer prior to the download. After the flash is upgraded, the printer will be at Factory settings and you will need this printout to restore any non- default settings.
2. The PTX flash code is on a CD you should have received with printer. Don’t have? I can email you the Flash program.
3. Turn the printer's power off.
4. If there is a cable connected to the printer’s serial port, disconnect it.
5. Connect a cable from the LPT1 port on a PC that has a DOS prompt mode to the printer’s parallel port.
6. While holding down the Online & FF(Paper Advance) keys, power up the printer. The printer will display "Waiting for Program Download".
7. At the PC’s DOS prompt, go to the directory where the file is located C:\Temp and
type "filename.exe -pb<ENTER>" where filename is the name of the file that you downloaded in step 2.
NOTE: there is a space before the -pb
8. The printer's display will keep you informed of the status of the download. When the download is complete, cycle the printer’s power.
May 15, 2008 | Printronix Line Matrix P5215 Printer
Cannot find file lxbmmcro.dll- not on Windows XP anywhere!!
Hi, this one should be easy, your installation disc is corrupt, or rather the driver, try copying the driver disc to a new blank one to override errors, this sometimes works. Do this after you have completely uninstalled any old partially installed printer files. (go to device manager and select unistall driver) Make sure you have original disc to do all this. If you have no luck with the copy, try downloading a new copy from the printers website. cheers lilacgerry
Feb 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP DeskJet 970cxi InkJet Printer Logo
59 people viewed this question
Ben Johnson
