Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Clean lcd pc screen
Any tips on how to clean my lcd flat screen tv and my pc screen
    New Friend:
  • 68 Answers
With mine I always first use a computer air duster, Then I use a good clean micor fiber cloth with water and water only, polish lightly until dry and clean
Posted on Feb 06, 2009
Replacement head/tips or you can call them to order new microdermabrasion tips and filters at 1-800-423-4248. You can also find them on EBay but I would suggest bidding opposed to buying outright as they are expensive. One last thing...there also is another tip that didn't come with the original kits...that you can get...It plumps the lips!!! Hope this helps!
Jan 09, 2013 | As Seen On TV Diamond Radiance
My Keurig coffee maker is not brewing. The word prime is on the screen. How do I prime the unit.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Jul 14, 2011 | Vacuums
How to clean sunbeam ultra 60 platinum iron. Can't find instruction booklet!!!!!
Do you mean the Sunbeam Ultura 60 Platinum iron? Wipe the exterior of the iron with a damp soft cloth and then dry the iron. To clean the steam valve, turn the Steam/Dry dial to Clean so that the tip pops up. Gently scrub the tip of the valve with a steel wool pad moistened with warm water. Rinse and dry with a soft cloth. Replace the valve and turn clockwise to lock into place (reset the dial to Dry when storing the iron). Clean the steam holes of any build up, use a cotton wool tip moistened with methylated spirits. The teflon plate should be cleaned with the damp soft cloth, just like the rest of the exterior of the iron. If you have ironed a polyester that melted onto the iron, then iron a damp cotton cloth when the iron is hot.
The manual for several Ultura irons, including the 60, is available here: . The link for the manual is in the center of the page above the Image Gallery.
I hope this helps.
Mar 06, 2011 | Sunbeam Vacuums
Ths spin scrub brushes wont spin
Be sure the speed switch is set to carpet. Also remember the brushes won't turn until the handle is tipped back. If this is not the problem, remove the brush and insert a flat screwdriver into the square hole the brush pin goes into, and be sure it turns ( there will be some resistance ). If it is seized up, the turbine will need replacement. There is also an air intake screen which must be kept clean. It is located behind a clear plastic cap on the upper front of the floor nozzle, just above the brush "spinner".
Feb 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes will not turn
Check to see that there is a belt around one end of the brush -- belt may be broken. If the belt is intact, let me know and we'll go to the next step.
Feb 01, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The cleaning solution water wont flow thru the unit. What do i do?
First, have you check the the owners manual? You can find them at
Spray Tip clogged
Clean/Solution tank is out of fluid
Clean/Solution tank is not inserted into the unit securely
- Clean Spray Tip
- Fill Clean/Solution Tank.
- Gently press the Clean/Solution Tank until you see “bubbles”
coming from the base of the tank.
May 22, 2010 | Bissell SpotBot Hands-Free Compact Deep...
I have a Bissell ProHeat Turbo 2x Carpet cleaner.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Jan 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No Suds! It just Spills the water
there is a little plastic round piece with a mesh screen that should go on the hose part of the shampooer that connects to the tank...make sure that its seated properly since it's this mesh screen that produces the suds
Dec 16, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Cleaning brush assembly on steamvac
Yes this does come apart. The clear plastic pieces clip into the black plastic piece, flat tip screw driver inserted into the gap can release the clips and allow for cleaning.
Nov 10, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
41 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
