Question about LG LSC26905TT Side by Side Refrigerator
How do i remove the water filter
I have a lg lsc 26905tt fridge and i'm unsure about where the water filter is. I believe it is located in the right hand corner of the light fixture of the fridge and I turn the little knob and pull out what i guess is the filter but it doesn't look like any filter i ever seen is this the filter or a cover leading to the filter and if this is not the filter how do i remove the filter.
    Guru:
  • 351 Answers
The filter will come out attached to the cover .. look inside the cavity . there should be a space there for the filter .. the ones at the top of the fridge are quite small compared to the ones that go at the bottom on some fridges. Most appliance or building supply stores will have replacement filters on hand .. have your make and model number to get the correct replacement., or the old filter ..
Posted on May 10, 2010
My LG LSC 26905TT Refrigerator started to heat up around the outside of the freezer side/top and center bar between the fridge and freezer. The freezer is not freezing no matter how high we set it or the...
HI.IF THE REFRIGERATO BOX OR DIVIDER IS HOT ,CHECK THE CONDENSER MOTOR ,FOR RESISTANCE OR CONTINUITY,CHECK FOR POWER COMMING TO CONDENC MOTOR,, IS OK REPLACE THE CONTROL BOARD OR REPLACE BOTH..GOOD LUCK..
Jul 04, 2011 | LG LSC26905TT Side by Side Refrigerator
LG LSC 26905SW control panel for temp, ice,
Replace the control pnl.
There is no way to fix the existing control.
Jan 12, 2010 | LG Refrigerators
Display stops working
new control.
and LG parts are only available through LG at this time
Oct 07, 2009 | LG LSC26905TT Side by Side Refrigerator
We have a LG LRSC 26923 frig. It will make and dispense ice fine. We cannot get water to come through the dispenser. We had this problem a couple weeks ago and it looked like water had frozen up in the...
i believe there is a water filter in the fridge side as well as a storage tank. if the fridge is set too cold the tank or filter will freeze. causing blockage. Try setting fridge to 38 deg or higher for a couple of days. should melt blockage
Aug 26, 2009 | LG LRSC-26922 Side by Side Refrigerator
Location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Jul 22, 2009 | Refrigerators
Where is the water filter located on my LG LSC 26905TT refrigerator?
Open the left door, look up to left top, there should be and s looking cap.
Jul 14, 2009 | LG LSC26905TT Side by Side Refrigerator
Change Kenmore fridge water filter due to slow water dispenser
what you want to look for on the filter is an arrow turn the arrow left and then pull down
Dec 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Using without water filter
The effort it would take to eliminate filter would be too much. Just leave filter in place. If new house filter is working right you should never have to replace fridge filter and your water will be double-filtered :)
Jul 02, 2008 | LG LSC26905TT Side by Side Refrigerator
Water filter replacement
Fm, it's not threaded, turn it counter clockwise until it stops (should hear a click), then pull it out. Push the new one in all the way and turn it clockwise, you should hear it snap in. You may have to use a little force. If you are still having trouble, give them a call at 1-877-714-7481. Catriver.
Jun 28, 2007 | LG LSC26905TT Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
458 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
