Question about Canon CLC 1150 Color Copier
How can i get the CANON CLC1150 to boot up on service mode?
Any ideas?
  • 1,602 Answers
Toner cartridge mixute problem
go on line type conan printer error e020 interkey
look threw the problems and see what you wannt to fix the problem best solves the problem
Posted on Feb 03, 2009
CLC1150 problem code E020 0181
what is this? The machine has been off/on and we also this problem
Jan 31, 2010 | Canon CLC 1150 Color Copier
I own a Canon Laser Color Copier Model No. 1150 CLC1150. The error code when I start up the copier is E0000 0132. How can I fix this issue?
the cause of error is the fixing heater/s is not functioning well .Try this press asterisk with the head then 2 and 8 simultaneously then same asterisk with head. The lcd display will change Pres the ff: COPIER>Function>Clear>Err > ok .to reset fixing error .Switch power off and on the machine.If the Error
return, you have to call the canon service agent to check your fixing/fusing unit and its components
Jun 21, 2009 | Canon CLC 1150 Color Copier
Canon irc2600n is taking time to boot what could be the problem
There is a boot wait timer set for 2 minutes by default on the unit. If the unit is taking longer than that it may be that it is warming up in preparation for printing. If you have warn parts, it may be taking a longer time to fully become ready.
Otherwise, seek support from a trained Canon technician or your Canon dealer.
Most features in service mode are designed for trained technicians. Many options are not labeled and ambiguous and assume you have been trained by Canon for the machine.
The process to enter service mode is available by searching google. I am unable to post it here due to a non-disclosure agreement.
Guides for this are almost impossible to find online, in my experience.
Mar 27, 2009 | Canon imageRUNNER C3200 Color Printer
Canon clc 1150
9 times out of ten that means you need a new drum when it does print does it look ok?? if yes then its definatly the drum it measures the voltage on the drum when its worn this code happens sorry
Jan 16, 2009 | Canon CLC 1150 Color Copier
Canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Dec 22, 2008 | Canon imagePROGRAF iPF8000 Printer
E008 error code on canon
Brother DCP-8065DN Laser Printer no paper error please any solution for that.......!
Oct 21, 2008 | Office Equipment & Supplies
Blank page from ColorPass
I cannot login to ColorPass z40e from Vista. How can I remove/change the login info from ColorPass ?
Sep 12, 2008 | Canon CLC 1150 Color Copier
you more than likely need the oil blade replaced. others things can be that you have paper jammed up at the top of the fuser which means youll need to open up the fuser.
May 07, 2008 | Canon CLC 1150 Color Copier
Canon clc 1150 copier
i have an erro paper jam in copier jam the code 0360 what i can do
Nov 12, 2007 | Canon CLC 1150 Color Copier
Canon CLC 1150 Color Copier Logo
115 people viewed this question
old marine
old marine
