Question about Mitsubishi WS-65809 65" Rear Projection Television
The net command picture won't stop going from each device on the
The device menu selector runs thru each device and does'y stop on any and won't respond to remote or the front controls
  • mrshadetree May 11, 2010
    I am not able to assist you with your problem with your tv, but if youget a point where you decide to get rid of this tv for parts then iwould love the chance to get this tv from you as i need the lense outof the front of this model tv for my application. please contact me viaemail at mrshadetree0222@aol.com, and or via telephone at 304-937-2369thank you have a great day!
    Problem Solver:
  • 5 Answers
Sounds like you may have a stuck switch on the front panel. Try pushing them several times each. If that doesn't work you can unplug the front switch panel and see if the problem remains. I think you need to remove the speaker panels and middle panel off the front to get to the connector.
Posted on Feb 20, 2009
How can I fix windows 10 installation error c1900101?
  • Disable (preferably uninstall) your Antivirus utility before attempting the upgrade.
  • Restart a few times and try again.
  • Disable General USB Devices (example - Smart Card Reader).
  • If you are using a SCSI hard disk, make sure you have drivers available for your storage device on a thumb drive and it is connected. During Windows 10 setup, click the Custom Advanced Option and use the Load Driver command to load the appropriate driver for the SCSI drive. If this does not work and setup still fails, consider switching to a IDE based hard disk.
  • Do a clean boot and try again.
  • If you are upgrading using the .ISO file, disconnect from the Internet during setup, if you are connected by LAN (Ethernet) or Wi-Fi, disable both and attempt setup again.
  • If you are updating through Windows Update, when the download reaches 100% disconnect from the Internet LAN (Ethernet) or Wi-Fi and proceed with the installation.
  • If that does not work, try using the .ISO file to upgrade if possible.
  • If you are connected to a domain, switch to a local account
  • If you have any external devices attached to the machine, disconnect them (example, gaming controllers, USB keys, external hard disc, printers, non-essential devices). If you are installing Windows 10 using Windows Update, try the following:
    1. Press Windows Key + X on the keyboard and then select "Command Prompt (Admin)" from the menu.
    2. Stop the BITS, Cryptographic, MSI Installer and the Windows Update Services. To do this, type the following commands at a command prompt. Press the "ENTER" key after you type each command.
    net stop wuauserv
    net stop cryptSvc
    net stop bits
    net stop msiserver
    3. Now rename the SoftwareDistribution and Catroot2 folder. You can do this by typing the following commands in the Command Prompt. Press the "ENTER" key after you type each command.
    ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
    ren C:\Windows\System32\catroot2 Catroot2.old
    4. Now, let's restart the BITS, Cryptographic, MSI Installer and the Windows Update Services. Typethe following commands in the Command Prompt for this. Press the ENTER key after you type each command.
    net start wuauserv
    net start cryptSvc
    net start bits
    net start msiserver
    5. Type Exit in the Command Prompt to close it and then restart the computer.
May 14, 2018 | Computers & Internet
ROOT\LEGACY_QKNFD\0000
To resolve this issue, examine the device manager to see whether the .NET Runtime Optimization Service V2.0.Number_Numberis installed as a device. If the service is installed as a device, you must uninstall the device. Then, run the following command to install the service correctly:mscorsvw.exe -i
To do this, follow these steps:
  1. Click Start, click Run, type DEVMGMT.MSC, and then click OK.
  2. Right-click .NET Runtime Optimization Service V2.0.Number_Number if the device appears, and then click Uninstall.
  3. In the Confirm Device Removal dialog box, click OK.
  4. At the command prompt, run the following command:%WINDIR%\Microsoft.NET\Framework<64>\v2.0.Number\mscorsvw.exe -i
Jul 18, 2014 | Microsoft Windows 7 Home Premium 64BIT...
My printer stopped printing? Canon Pixma 210 New
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Apr 20, 2011 | Canon PIXMA MP210 InkJet Printer
My hp 2180 printer will not print. When I click on print nothing happens. I have check everything nothing happens. The photocopier works only
Hi
Maybe the print spooler service had stop. Try to stop and restart it again. Try this solution.
Go to START MENU
Exit
Go to C: drive
Click show content
Choose spool folder
Choose printer
If still not printer, try to set up or add once more the printer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 10, 2011 | HP Office Equipment & Supplies
The printer is not connecting to the pc
Hi
Please try this
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32 and press enter")
Exit
Go to C: drive
Click show content
Choose spool folder
Choose printer
I hope it helps you
Please let me know it you need more help. Regards
Mar 18, 2011 | HP Office Equipment & Supplies
My hp photosmart c4580 all in one printer wont print but will copy. how do i fix that?
How are you connected to the computer? Did you install the software from HP (either from the CD or after downloading from HP)? Remember you need to connect the USB cable during the installation even for a wireless connection. See this page for details and pictures of the installation process: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01746713&tmp_task=setupCategory&lc=en&dlc=en&cc=us&product=3418707 (click on the appropriate link towards the bottom for the software installation). If you need the drivers, go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3418707& and select your OS in the drop-down menu. Then click Next. Then expand the Driver section.
If you are using a wired connection, make sure the cable is connected. If a network connection, try disabling your firewall for a few minutes. If that lets your printer work, set the permissions to allow the bi-directional communication to the device.
Next check your printer status and queue. You may have a job that got stuck and needs to be manually removed. In a Windows OS, open the Printers Control Panel (Start > Devices and Printer for Win7, older versions it was Printers and Faxes). If you can't delete the jobs in the queue, you can stop the print spooler and restart it. In the command prompt (run as administrator for Vista and Win7) window (Start > Accessories > Command Prompt (right click and choose Run as Administrator)), type "net stop spooler" without the quotes and then press Enter. On the next line type "net start spooler" (again without the quotes followed by Enter). If warned about stopping Fax service, type Y to accept between the two commands. Then restart your computer. (If you do not do both steps in the command prompt, it takes much longer to restart the spooler after stopping the jobs.)
Turning the printer off and on or rebooting your router may be needed for a wireless connection.
I hope this helps.
Feb 14, 2011 | HP Photosmart C4580 All-in-One InkJet...
My computer will not install updates. it says it is installing them after it shuts down but they never install.
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Regards,
Om
Oct 11, 2009 | Microsoft Windows XP Professional
UNABLE TO INSTALL SP2 ON XP OP.SYSTEM
net stop wuauserv
net stop bits
net stop cryptsvc
net start wuauserv
net start bits
net start cryptsvc
Regards,
Om
Oct 01, 2009 | Microsoft Windows Xp Home Edition Sp2...
Net Command Does not work
Go to net command menu click on the AVR Learn icon.
Now you can program 4 different functions (inputs) from another remote. I programed 4 different source settings from my A/V receiver. And you label each input appropiately. Such as DVD, SAT, CAB, ANT.....
Now go back to net command and just to the right of previous Learn Icon you input the name of the source you just programmed for which ever device it is currently watching.
Net command is very confusing but works great once you figure it out. Hope this helps.
Jan 28, 2008 | Mitsubishi WD-65833 65" HDTV
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
