Question about Bosch Appliances 27 in. Wall Oven Electric Single
Bosch Oven HBN430550
Our oven is approx 1 year old and the inside of the glass door is dirty and grimey. I have tried hot water, hot water and mild detergent. The grime looks oily? from roasting?
I do not want to use the wrong substance or cloth and ruin the glass glass/coating.
I would appreciate any advice on the best way to clean this. (I haven't tried using the self cleaning catalytic function).
Thanks heaps,
chris
  • 883 Answers
SOURCE: bosch built under oven
you can try high-temp gasket maker from an auto supply store.
Posted on Jun 04, 2007
Master_Tech
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
barkencoa
  • 3463 Answers
SOURCE: Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Posted on Feb 11, 2010
  • 414 Answers
SOURCE: I have a bosch oven,
You can use a silicone adhesive as long as it's heat resistant.
I'm in the uk, but I have added a link for an au product as an example, all the best.
http://www2.blackwoods.com.au/infoBANKProduct.aspx?SG=2000165&S=4084745&G=2004222&P=7741858
Posted on Sep 05, 2010
Testimonial: "thanks for your reply, very helpful."
guru_fixya
  • 944 Answers
SOURCE: My built in Bosch oven
The code actually means there is some problem in the lock mechanism.unplug the range at least for 6-8 hours.So memory and internal battery a reset.Spray some WD40 into the lock mechanism and let it sit over night.So the lock mechanism will work properly.The self-clean function will not be activate if it shows this error.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 08, 2010
Spilt milk inside Smeg oven door
no use crying over it :>)
Get an old towel and soak it in hot water. Put baking soda over the stain, then the towel and wrap the door in cling film. Leave overnight. Wash off with hot water.
If it is between the glass in the door, then you have to remove the door, remove the screws holding the two halves of the door together and then do the above.
Feb 21, 2016 | Smeg Ovens
How do i clean the inside glass of a kuppersbusch oven ?
Hello, Make sure the oven is warm, not hot. Open the door and spray the glass with vinegar and water and wipe with newspaper.
Dec 11, 2014 | Kuppersbusch Ovens
How do i remove the glass from my built in moffat oven door as the inside of the inner glass is very dusty,there are no screwws or nuts to undo it or do you know a way of grtting into it to clean it
LOOK FOR VENTS AT TOP OF DOOR SPRAY IN OVEN CLEANER AND LEAVE FOR 20 MIN THEN SPRAY WITH WATER AND TURN OVEN ON TO HOT TO DRY DOOR.
Oct 18, 2009 | Ovens
Hot point oven 20 years old cleaned oven now door
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 15, 2009 | Hotpoint DY46 Style Line Stainless Steel...
How do I take off the glass on my oven door to clean it?
I have a Kenmore oven and all I had to do was remove the screw at each end of the handle (accessed with the door open) and the very front section just opened up - SIMPLE!! Wiped it down put the screws back in. Did it all by myself - just have your cleaning cloth in reach before you start. Can't believe I looked at those drips for years and it was that simple!!!
Mar 21, 2009 | Maytag CWE4800A Electric Single Oven
Bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Nov 21, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bosch HBN13M551B Double Electric Oven
new door approx £150.00 you can get indevidual parts for it? regwoolley@uwclub.net
would need the enr no.!
Sep 01, 2008 | Ovens
Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Aug 01, 2008 | Ovens
Inner glass door lower double ove
Many teasons for this to happen, no one has come up with a definitive solution for this,it just happens..
All you can do is have it replaced.
Mar 23, 2008 | Bosch HBN 455 Stainless Steel Electric...
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 | Ovens
Bosch Appliances 27 in. Wall Oven Electric Single Logo
168 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
