I have any Hp Laserjet 6110 all-in-one it gives me an error scanner error turn off and then on . I tried also to print some files but the printer gives me an error . I then tried to reinstall printer drivers but there is no change at all the error is still coming .It si configured on Hp machine with Windows XP
Try updating the printer firmware and check if it helps. Reset the printer to clear certain error states by calibrating the scanner mechanism, and then check the power source to confirm the printer is getting enough power to operate the scanner. From:
Please try to use scanner glass and see the resultSecondly try to scaan to PDF for multiple files.If the issue still persists clean the rollers on the ADF and if not working, replace the ADF
52.00 error is not good. If you tried powering off and on and that didn't work, a tech is going to have to look at it. Problem could be the laser/scanner or the engine control board(ECU)
PRINTER ERROR
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
open the top side of the scanner and clean inside of the glass you will see a white line behind the glass, clean it and try agan this is a standard problem of HP 6110 type all in one printers
This sounds like there is something wrong with the printer. What exactly does the error message say?
