Question about Neff 24 in. S4443 Built-in Dishwasher
Neff s4443 dishwasher
Plerase provide dish water door ajustment as the door does not remain open and has to be held with lower basket dishwashermodel s4443
  • Neff Master
  • 19,396 Answers
  • 679 Answers
Most folk will just replace the door locks .but a tech needs to check the secure connnection of the wiring to both the lock and the circuit board, and to look at the bottom of the circuit board to be certain of ** cracks on the relay solder joints as is the usual issue, sometimes its the relays themselves that have pitted contacts due to all this intermittent issue.
Thanks for using FixYa
Posted on Feb 02, 2009
  • rockfixya
    rockfixya Feb 02, 2009
    please le me know if problem solved.
    Thanks for using FixYa.
  • 13,433 Answers
You need to adjust the strings
http://www.applianceaid.com/lookup.html
The dish washer is not heating S4433n
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 10, 2011 | Neff 24 in. S4443 Built-in Dishwasher
Just moved into a house with fitted NEFF dishwasher, never had one before and no manual left. Where do salts go? Thanks
The salt goes in the salt compartment in the base of the dishwasher. Open the door and pull the lower basket out. You should then be able to see a cap near the front-left corner of the base of the dishwasher. Unscrew this cap (anti-clockwise) and fill the compartment with salt all the way to the top - or with as much salt as you have in the packet - then screw the cap back on firmly, but do not over-tighten it. The salt compartment will (or should!) be full of water and some will spill out as you fill it with salt. This is totally normal and not indicative of any problem.
Do not use any type of salt which is not sold specifically for dishwashers. The dishwasher can be used without salt but it is not advised and may result in a white film being left on your cutlery, glassware and/or dishes.
It may also be possible to provide a user manual in PDF format which you can download, but I would need to know the model number. If you don't know the model number Most Neff/Bosch dishwashers have the model number laser-etched into the stainless-steel at the top of the inner-door or the rim of the washing compartment. Please click on the link below for a guide to locating the model number of your dishwasher. (Neff is a Bosch owned brand)
http://www.bosch-home.co.uk/type-plate-details.html?aftersales=dishwashing&aftersales=dishwashers~16468
Hope this helps. Please let me know if you would like the manual or need further assistance.
Regards,
BElectric
Feb 28, 2011 | Neff S5946 Built-In Dishwasher
The dishes are not coming out clean and the soap gets stuck
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Dec 13, 2010 | Neff 24 in. S4443 Built-in Dishwasher
My dishwasher no longer cleans my dishes and white spots remain even when jet dry is being used.
Dishwashers rely upon water circulation. Make sure there is nothing blocking the pump receiver at the bottom of the washer, like paper labels from gars, or large food pieces. It also relies upon the proper amount of water in the washer. After the washer fills and starts its cycle, squeeze the handle to open the door but do not open the door until all the sound has stopped. The water level should be visible and close to the top edge of the basin. Don't worry, opening the door after the pump has stopped will not spill water on the floor. If the water level is good and you are sure there is nothing blocking the pump receiver, check the stem in the center of the basket.
Sep 20, 2010 | Dishwashers
Washer jets do not spin water just runs out
1)check the inlet pressure.
2)scaling present in boiler tank.
3)check the arm rotaing freely.
Jan 07, 2010 | Neff 24 in. S4443 Built-in Dishwasher
The middle and top sprayer is not rotating, causing dirt to remain on the dishes. What controls these sprayers?
When you push the top drawer back to close the door the arm engages into what looks like a small doughnut this is where the water is pumped through your machine.
Both the middle and lower arms get there water this way. Take the lower basket out completly and look at the end of the arm where the water goes in has you lost the small rubber sealing ring it's usually orange in colour and forms a seal when the door is shut.?
If this rubber ring is missing the water will not get pumped to the top of the machine it will just flood out of this connection.
Nov 07, 2009 | LG LDF6810 Built-in Dishwasher
Small amount of water remaining in bottom basket
There is a screen in the drain that is plugged.
Apr 15, 2009 | Viking DFUD042 Built-in Dishwasher
Water filling problem
change the input water hose to bigger size
Dec 19, 2008 | Neff 24 in. S4443 Built-in Dishwasher
Dishwasher not washing very well
usual reason is that the arms are not rotating freely - they only turn by water jetting out of angled jets. blockages are not always obvious as blockage material tends to go out of sight when water pressure off. favourite culprits are rice and sweet corn
Mar 09, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Spinning arms stationary
problem is usually debris in the end angled jet of the spray arm which is used to turn the arms. take them outy and patiently clean. very common problem
Apr 24, 2007 | Neff 24 in. S4443 Built-in Dishwasher
Neff 24 in. S4443 Built-in Dishwasher Logo
41 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Mike Cairns
Mike Cairns
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
