Question about Viking 48 in Built In Professional Integrated Side by Side Refrigerator - VISB483SS
DISPLAY LIGHTS NOT WORKING
THE FRIDGE IS WORKING BUT THE DISPLAY LIGHTS IS NOT WORKING,I CHECK THE LOW VOLTAGE BOARD WHAT I OBSERVE , LOOK LIKE THE L.C.D LED THAT LED TO THE DISPLAY HAVE BURN OUT
  • Anonymous Mar 16, 2014
    Fridge appears to only be getting low voltage
  • 59 Answers
If the display is burnt out then the low voltage board will have to be replaced.
Posted on Mar 04, 2009
Display light board faded
Four years ago I had this problem (display goes dim, then goes out altogether) and fixed it per this post:
The circuit board for the display/touch panel is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
To remove the circuit board, GENTLY release the two black plastic tabs; the solder pads are underneath. I too used a 100 mf capacitor because no local supplier had a 68 mf hi-temp. Observe polarity; the (-) lead goes towards the center of the board (away from the edge connector.) You must use a high-temperature capacitor (105 degrees C, I think) or the problem will recur.
If your oven isn't put together the way mine is, this solution won't work - and I'm sorry to have taken your time.
Sep 16, 2013 | Jenn-Air W30400P Stainless Steel Electric...
HV board problem. replaced board, but can not reprogram to enter new code. what do I do?
I recently had the identical problem after replacing the high voltage control board myself. Although display looked normal, no response to programming attempts. All I could think of was that the low voltage board under the display ppanel was also bad and was about to go out and buy it ($240 locally) when I ddecided to check its connections first. Took off the display panel, unplugged the 4 connectors, plugged them all back in. When I powered up the fridge, it responded to the programming directions and has been working normally except the ice-maker made one batch of ice and then just stopped. Now I have to try figuring that one out.
Aug 11, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
No temperature digital display in refrigerator, light working, but loosing temperature in fridge & freezer
if its a G.E. make first check the PTC overload on the compressor to make sure compreesor is operating, if this isnt,check voltages on ptc,if no line voltage here,then check for the motherboard in the rear behind a panel as this board when bad will make digital readout go out and lights strobe and you may hear a clicking noise from there also as the lights flicker or strobe this board failure can be caused from a surge within the unit by a light bulb burning out or a power surge from outside too
Feb 10, 2012 | Refrigerators
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
My fridge was moved around in the kitchen & I have plugged it in at a different spot & now the freezer & fridge is not working. The lights inside the fridge go on but the digital screen is...
The compressor in a fridge draws a lot of amps on start-up and it could be you blew a fuse . Scoot the thing out and take off the back and then check the voltage going up to the display you could have jarred a wire loose which is what I suspect Look at everything and see ,its something simple I'm sure.Take voltage measurements to see if the compressor is getting what it needs and the display as well,in between the two is a control board and that is where the fuse will be found if no wires are off.
Mar 29, 2011 | Samsung Refrigerators
Ever since I bought my new "KIng of the Hill" Ge
so try to install voltage regulator maybe it can affect on the main mother board operation bec. of power fluctuation observe unit after install automatic voltage regulator . if problem recurring mother board have problem or try to check the program setting.
Feb 05, 2011 | GE Profile PFCS1NJWSS Stainless Steel...
Same problem. red light flashes 3 times, but will not turn on.
The blinking light means the controller QA01 in the AV_TERM system board is booting and driving the TIMER/REC RED LED light accordingly. This failure mode is true for many conditions, not exclusively for the main PS board PE0071. It could be caused by many things, LOW B, SEINE, AV_TERM, LCD, PROTECT, etc.
Specifically for PE0071+12VDC circuit failure, which is the most common , listen for the LINE relays SR80, SR81 coming online. If several (3) or more clicks are present when applying power to the TV set then suspect the +12, 20, +32 VDC inverter is faulty.
As a quick check, you can disconnect P807B. If the relays cycle every 1-2 seconds then is most definitely the +12VDC inverter. Check for voltage level at optocoupler Q881 pin 4 and this should not be cycling. This point is the VCC for the oscillator. Repair or replace board 75002913 as necessary.
TROUBLESHOOTING: (this is my own, not the OEM !, try at your own risk!)
  1. Check for LINE1 input voltage level at inverter on sheet [4].
  2. Check for LINE2 input voltage level at inverter on sheet [3].
  3. Check for STBY +5VDC & +25 VDC ( observe correct GND REF) page [4]of PE0071 POWER
  4. Check for +22 VDC out of regulator on page [3] out of Q822 Emitter
  5. Check P809B connector for :
  • P809B (12) POWER = 3.00 VDC (+/-0.2)
  • P809B (11) POWER_SIG = 0.00 VDC (HIGH to Power on TV)
  • P809B (10) PROTECT = 0.00 VDC
  • P809B (9) ACDETECT = 3.00 VDC (+/-0.2)
  1. Check for PFC_OUT = 368-371 VDC
  2. Check for +12, +20 & +32 VDC inverter page [5] of schematic manual.
For +12 VDC Inverter, suspect components:
Q880 STR-W6765 PSR (works really hot!!)
C888-C890
D884A and related switching circuit components.
Good luck,
mrwindex
Jul 03, 2009 | Toshiba 42HL196 42 in. LCD HDTV
My GE Profile side by side will not dispense ice or water. Also, when the door to the fridge was opened the temperature setting lights were out but then came back on The fridge and the freezer seem to be...
The contol board on the back of the unit may have a low voltage problem not sending power to the dispensor or display lights properly. Is it still making ice just not dipensing? That's been the most common problem I've seen on these units.
May 16, 2008 | GE Refrigerators
Whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Viking 48 in Built In Professional Integrated Side by Side Refrigerator - VISB483SS Logo
434 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Iron
Iron
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
