Question about Logitech 967437-0403 Keyboard
Keyboard not working
Keyboard was working, now if I follow installation procedures, it does not work.
  • 34 Answers
I wouldn't worry too much about the installation procedures, try unplugging the keyboard, and shutting your PC down. Then reconnect the keyboard, turn your PC back on, and then try it. If still not working you can reach me at support@computech-sa.com.
Posted on Feb 19, 2009
Why won't this gearhead keyboard connect
google your keyboard model, there is a sync button somewhere , some how.
press the helpful button and follow me on fixya
How to Install Wireless Keyboard and Mouse
Re syncing my wireless Keyboard Mouse
Microsoft Hardware
How to Connect Wireless Keyboard to PC
Feb 04, 2016 | Computers & Internet
My keyboard will not work
Keyboard Is Dirty:
Keyboards should be cleaned with "spray-n-wipe" cleaner and a cloth or tissue on a monthly basis. Ensure that computer is not powered up while cleaning the keyboard. Compressed air can also be used to clean between the keyboard keys. Another tip: clean the keys with a cotton swab dipped in alcohol.
"Keyboard Not Found" Message:
Your keyboard is not plugged into the computer securely. Unplug it and plug it back in and the problem should go away. If this doesn't work, follow procedure: "Computer isn't taking inputs from keyboard" (below).
Key Is Stuck:
1. If a key does not work or is stuck in the down position, you may try to remove it with a CPU "chip puller" tool. These simple "L" shaped tools are great at pulling out keys. Once you've pulled out the stuck key, you can try to stretch the spring to "reanimate" its action.
Computer Isn't Taking Inputs From Keyboard
1. Is keyboard connected to computer? Ensure that the keyboard is plugged into the keyboard jack and not into the mouse jack. If the keyboard was unplugged, plug it back in and reboot the computer.
2. If the keyboard still doesn't work on boot-up, power down the computer and try to borrow a friend's known-good keyboard for troubleshooting. Plug the new keyboard up and boot up the computer. If the new keyboard works, the old keyboard is bad and needs to be replaced.
3. If the known-good keyboard doesn't work, check your BIOS to make sure it sees the keyboard. It should say, "installed." If the BIOS recognizes the keyboard, then you probably have a bad keyboard port.
I Plugged Keyboard Into Mouse Port
1. Many mice and keyboards today use a PS/2 connector
. If you plugged your keyboard into the mouse port (or viceversa), follow steps 2 and 3.
2. Shut down the computer and plug the keyboard into the keyboard port. The keyboard port is usually marked with a "keyboard" symbol. Plug the mouse into the mouse port (usually marked with a mouse symbol).
3. Reboot the computer; the keyboard should work now. If keyboard doesn't work, check your BIOS to make sure the BIOS recognizes the keyboard. You should see the words, "installed" or "enabled" under the keyboard.
4. If the BIOS recognizes the keyboard but it still doesn't work, you may have a bad keyboard port.
I Spilled a drink on my keyboard!
1. If you spill any liquid in the keyboard, turn it upside down ASAP. Drain all the water out of the keyboard, shaking it if necessary. If you've spilled water into the keyboard, just let it dry. You may use a hair dryer to dry out area under the keys (remember, too much heat and you could damage the electrical components).
2. If you've spilled a soda into the keyboard, completely rinse it in warm water. No soap please! You may use a hair dryer at this point or just let it dry for 2 days. Ensure the keyboard is perfectly DRY before you attempt to use it again. Don't plug a wet keyboard into electrical equipment. Think safety.
5. If the keyboard still doesn't work, replace the keyboard.
Nov 13, 2010 | Dell Computers & Internet
My uiop keys wont work, on my laptop keyboard.. I have replaced it many times, and now my uiop keys wont work -- typed on On Screen Keyboard
you must have configured the settings incorrectly when you installed the OS.go back and repeat procedure choosing correct type of keyboard.
keyboard configuration is a basic function of all operating systems
Sep 12, 2010 | IBM ThinkPad T42 Notebook
Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
Jul 20, 2010 | Casio Music
How can i reinstall firmware nokia 6300 ??? Can someone help describe how to do it ? Keyboard doesnt work , sometimes it work .........
To reinstall Nokia 6300 you need Nokia Software updater. Dowload it from www.nokia.com,Install then start the application follow the step by step procedure
Aug 28, 2009 | Nokia Cell Phones
I just recently purchased the wireless keyboard and mouse. Thought I was following the instructions for installing them. The computer says they are installed properly, yet the keyboard won't work. Can't...
usually these have a tiny "Connect" Button on the bottom of the keyboard, mouse, and a button on the receiver. Have you followed the sync procedure with this ?
Is there another wireless device nearby that may be interfering ?
Is it one receiver for both devices ?
Does the mouse work ?
Have you tried a 2nd set of batteries on your keyboard ??
Hope this helps.
Jul 28, 2009 | Logitech 967437-0403 Keyboard
Microsoft wireless keyboard
check the reciever of your keyboard ,maybe its not inserted properly.
Mar 17, 2008 | Logitech Cordless Desktop S 510
S510 Keyboard Problem, Keys Dont Work, Everything Else Works,Ect-Mute
I had the same the problem. The cause was a corrupted encryption code. That is why only worked the keys that don't require encryption.
1) Install the Logitech software and restart.
2) The software will tell you to press CTRL-ALT-F12. This procedure resets the keyboard encryption and tells you to enter a new code.
3) If you already had the software installed simply press CTRL-ALT-F12 and follow the above procedure.
Mar 15, 2008 | Logitech Cordless Desktop S 510
Keyboard stopped responding
Please re plug your cable from your usb point provided in pc.Which windows are u using if xp or vista it will re-detect.
Dec 22, 2007 | Logitech Cordless Desktop MX 967300-0120...
Keyboard does not work
You don't need to install any software updates. Just do the following:
[Ctrl]-[Alt]-[F12] (must use the left [Ctrl]-[Alt] keys, not the right)
Push the Connect button beneath the keyboard, then the Connect button on the USB Receiver, then the [Esc] key on the keyboard.
This will unlock the security encryption on the keyboard. You may need to reconnect the mouse afterward too.
Oct 25, 2007 | Logitech Cordless Desktop MX3200 Laser...
Logitech 967437-0403 Keyboard Logo
102 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
