Question about Hitachi 53UDX10B 53" Rear Projection Television
Red power light, lights for one second then nothing.
No power light, when I unplug then plug back in it lights for a second, then nothing.
Ed
    Scholar:
  • 150 Answers
Hi, this means you have a short somewhere in the power supplies, this type problem is very difficult to diagnose without removing the back cover and seeing which diagnostic led goes out first, once that is determined you can get the shorted part replaced, this will not be a do it yourself repair, you can check the led`s as I said to see which goes out first but all that will tell you is which power supply has failed, video-tek
Posted on Feb 04, 2009
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Goes to standby with fast blinking red light after 5 seconds
From my experience you need to replace the Hi power module
Sep 11, 2009 | Denon AVR-1905 Receiver
Just no power. outlet is ok! reset button does nothing to help
Might be some problem with adapter. verify output voltage of the adapter with multimeter. If no output then replace your adapter.
Regards;
Hassan
Jun 27, 2009 | Linksys Wireless-G Range Expander (WRE54G)
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
I can't get my tv to turn on... nothing but blinking red light
Dont know if this will work for you or not, but my brother gave me his because of the same problem. It would power up and a green light would come on, then after 10 -15 seconds it would change to a red blinking light. I plugged a usb cable into the service port on the side and left the other end unplugged. Then plugged the tv back into the power. i took a small screwdriver and ran across the contacts in the end of the usb cable until both the red light and the green lights came on. I did this several times listening fot the clicking noises in the TV. after doing this for approx 20 seconds, i pressed the power button and the TV worked fine. 5 days now and no problems. Only thing I can think is I somehow reset the software and now it is working fine. Hope some of you can figure this out and give it a try. if the TV is just sitting, you have nothing to lose
Aug 17, 2008 | Philips 26MF231D 26 in. LCD Television
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
