Question about LG KC910 Renoir Cell Phone
LG KC910 connecting wifi to my home internet
Hi guys
I cant seem to connect my phone to my home wifi connection. I typed in all the passwords etc but it just keeps on saying failed. Do i need to do something on my mac to allow this. if so, how?
  • 8 more comments
  • ali124 Feb 02, 2009
  • monique2505 Feb 03, 2009
    cant connect to my home router please help
  • clareval Feb 10, 2009
    I am unable to connect via wifi to my home network hub or an open hub while out in Mcdonalds restaurant which has free wi fi. The phone just says connetion failed!!
  • Numptylad Mar 03, 2009
    LG Renoir can find router but cannot connect. Have tried many times. I have a Siemens Orange router.
  • b4ber2000 Mar 26, 2009
    Having problam connecting to my home wifi, it says conniction failur
  • Anonymous Mar 27, 2009
    i cant connect to my wifi at my home
  • Anonymous Mar 30, 2009
    i can connect to my wi fi but do not know what do after to connect to thr internet
  • bill david Mar 31, 2009
  • Anonymous Mar 31, 2009
    i have same problem with my kc910..i can't use wifi. it show all the wireless network and signal strength too, but when i connect it says fail to connect... i can't figuer it out what's gone wrong.. ??
  • Anonymous Mar 15, 2014
    hi i have the lg optimus l9 phone but it wont connect to my home wifi. whenever i try to connect it just says "obtaining ip address" How can i fix it?
I had this problem, My wirless router is using WEP Authentication with a "Shared Key". I had to change this to either Open or Automatic on the router.
Posted on Feb 04, 2009
I had this issue, and the D link tech support guy solved it. I had to hook a computer into the router via a cable to start with, as during the process, internet would probably be lost without a cable. Problem is the kc910 RENOIR supports WEP and WPA -PSK/2 encription, not WPA-PSK like I was using with the Dlink Router. We switched encription over to WEP 64 bit, hex, using the router page, and gave a new ten digit numerical key. I wrote the key down. KC910 could now see my network with WEP encription, I entered the new ten digit key, and with dns on the phone set to auto, not static, it was connected. Then I had to go to each laptop etc in the building, and redo the wireless profile using WEP. This meant deleting the old profile, then having the laptop discover it again, this time thru WEP. I inserted the new ten digit key in each case, and all well. here is the process as pasted from the email the Dlink guy sent me. He is a legend.
customer said that he has a new phone but cannot get it connected online wirelessly.
Troubleshooting:
verified that all their computers are able to conenct online wirelessly.
advised customer that we do not have any support for his phone.
had him change the security from his current wpa-psk to just wep.
customer tested the phone when using the wep security.
customer was able to get his phone to work.
checked the wireless pc and tried to have them reconnect to the network.
customer's vista cannot connect to the wireless network.
he brought the pc near the router and he is able to connect to the network.
opened ie and he is ONLINE wirelessly.
customer thanked. call ended.
http://files.dlink.com.au/products/DI-524/REV_B/SetupGuides/How_to_enable_wireless_security.pdf : Click here to view this document with screenshots
It is recommended to enable encryption on your wireless router before your wireless network adapters. It is better to use WPA (WPA-PSK, WPA2-PSK) encryption rather than WEP as it is more secure. However if you wireless clients do not support WPA, use WEP encryption.
Please establish wireless connectivity before enabling encryption. If you are configuring the router from a wireless connection, please be aware that as soon as you enable encryption on the router, you will lose connectivity until you enable encryption on the wireless card you are using.
Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead.
Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
Step 2 The default username is admin (all lower case), and the password is blank (nothing). Click OK . Select the Home tab and click the Wireless button on the left hand side of the screen.
Step 3 Select Enable next to the WEP radio button. In some router models you need to select WEP in the drop-down menu. For WEP Encryption select 64 or 128-bit encryption. For the Key type select HEX.
Note: 40-bit and 64-bit encryption is the same as well as 104-bit and 128-bit. Please visit http://support.dlink.com/faq/view.asp?prod_id=480 for more info.
Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption.
64-bit encryption 10 characters
128-bit encryption 26 characters
256-bit encryption 58 characters (optional)
The encryption key is HEX, meaning 0-9 and A-F are valid characters.
Step 5 Click on the Apply button then click on the Continue button to save your settings.
Step 6 You wireless computers will now need to be re-configured to use WEP with the same key and re-connect to the wireless network.
Posted on Apr 01, 2009
You have to put your Mac adres in your router
Posted on Apr 18, 2009
A,jdej
Posted on Dec 27, 2012
How to connect internet of computer home to LG kc910 mobile phone
Posted on Mar 31, 2009
Hi can you please help me with this matter how do i reset my phone as i cant get on the internet i think i am conected to wifi
Connect to wifi, then open a web page to a new page. Do you see something that asks you to connect, or pay money?
If you are at home, you will need to connect your phone to your home wifi connection, and then you have to add the password.
If the phone worked before and nothing has changed, power the phone down, count to 10 and power it back up.
Aug 19, 2015 | Cell Phones
My itel phone does not want to connect to the internet.
Hi Amanda,
In order to access the internet via your cell carrier from smart phones - you need to enable "Mobile Data" in the "Settings". This setting has nothing to do with your ability to send and receive calls, SMS text, Pix, etc. It is for internet access to browse the web, read email, etc.
If you are trying to get access from a WiFi hotspot from such places as local businesses, in your own home - or that of a friend - you'll need to provide the login credentials that may consist of one or more of the following: SSID, Encryption Key, Usage agreement, Username, Password. Most WiFi hotspot require only the first 3 - one or more of which may be provided in a notification on your phone's screen.
If you have problems still, contact you provider to learn where to find these settings on your particular brand and model phone.
Jan 28, 2015 | Google Cell Phones
I have wifi connection but no web page apears
make sure your not connected to a wifi connection with a password, or in the interm, just use the internet off 3g if you have it, or edge networks.
Sep 29, 2009 | LG KC910 Renoir Cell Phone
Cant access the INTERNET thru wi-fi!!!
check the status of connection and check the driver curruption ........
if necessory update drivers ....
Jul 01, 2009 | HTC Touch Pro Smartphone
LG Renoir wi-fi connection failure
When i try to turn on my wifi my Lg Renoir restarts ! Any suggestions on how to solve this ?
John
Apr 07, 2009 | LG KC910 Renoir Cell Phone
LG Kc910 connectivity to pc/wifi
3845#*910# Master Reset code for lg kc910 , once in do a factory reset
Mar 08, 2009 | LG KC910 Renoir Cell Phone
LG 910 Internet Settings Problem
i had the same problem with my 910 , i rang my service provider and they text me the codes and software to load directly onto my phone , problem fixed straight away !
Feb 06, 2009 | LG KC910 Renoir Cell Phone
LG KC910 Renoir Cell Phone Logo
6,892 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
