CD player won't play after pressing the play button on all tracks
The CD rotates after it has been insurted anything from 5 to 10 seconds then stops and whatever button is pressed the CD does not rotate again. The display will show each track only when pressing the advance button and then only for about 3 seconds and then returns to zero. All other buttons do nothing. It sounds as if the lazer is trying to read the disc on entry, do you think the lazer needs changing or does it just need adjustment and is this easy to do?
    New Friend:
  • 35 Answers
This problem is usually caused by dust or smog accumulating on the laser lens assembly. Unplug the unit and remove the top cover. Take a cotton swab and wet one end with glass cleaner. Wipe it gently across the lens (do not apply pressure). Use the other end of the swab to dry the lens. Reassemble the unit and test for skipping or non-playing discs.
Posted on Mar 02, 2009
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Sony MDS-JE440 mini disc,single play
If there is a "PROGRAM" button, then you just turn on "program", rotate the knob to what track you want and then hit ENTER. Then when you hit 'play' it will only play back that track. You'll have to repeat this for every track or manually hit the PAUSE button between tracks if you program more than one.
Nov 10, 2009 | Sony MDS-JE440 Mini Disc Player
KDC-716S sometimes plays CD, other times just tray drop
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Jun 01, 2009 | Kenwood KDC-716S CD Player
Cannot turn off the machine
Try cleaning the laser with a cleaning cd.
May 20, 2009 | Sony D-NE20 Personal CD Player
Format error on my nw-505
be sure to format using the MENU mode on the unit and ADVANCE MENU then FORMAT Press and hold the search/menu button for half a second in stop mode. The menu screen is displayed. Rotate the shuttle switch to select "Advanced Menu" > and press the play/stop button to confirm. Rotate the shuttle switch to select "Format" and press the play/stop button to confirm. Rotate the shuttle switch to select "OK" and press the play/stop button to confirm. "Formatting..." blinks and start formatting. When formatting is complete "complete" is displayed.
This is how i get rid of the problem "Format Error".
May 11, 2009 | Audio Players & Recorders
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
I have a stanton-vestax cd-11 dual cd player, and was wondering how to get a cd to play on it. I put one in, turned the player on, pushed all the buttons and nothing happened. how does it work?
I have had one of these for many years: Switch it on, you must make sure the two transit screws at the back of each deck are fully unscrewed and loose, let the machine displays settle down, then insert a CD, then press the 'reset' button. There is a built-in delay of about 11 seconds before the deck begins to read. After this the machine should then display the first track number, and pressing the big red button will start play.
Pressing the 'reset' button again stops playback and the CD spins down, but if you leave the CD in there it will eventually re-index and cue up again. This feature is to enable fast, one-button CD changing and it works very well in practice, as the 11 second delay is enough time to take one CD out and get another in there before it tries to read it again.
To stop playback just press the 'reset' button (this is the most used button!) and take out the CD. After the delay, the machine will try to read a CD as normal, but display 'no CD' on the display. There is no stop button, as this unit was designed for continuous use in a club or disco.
Hope this helps. :)
Oct 18, 2008 | Audio Players & Recorders
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
CLOCK
You can download the manual from the link below: http://safemanuals.com/user_guide_instructions_owner_manual_CLARION_DB165_E.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 11, 2007 | Clarion (DB165) CD Player
Open Questions:
209 people viewed this question
 Grubhead
Grubhead
