Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 keeps locking up
Yea my sidekick keeps locking up on the jump screen itll work fine for a few mins after i turn it on but then it locks up on the phone icon and the roller ball wont move or anything but yea its really pissing me off and im about to kill it!!!!! ive emulated a hard reset at least 10 times so please dont tell me that
thank you
rellik227
  • kris towe
    kris towe Feb 05, 2009
    hey thank all i got it the jump button was jammed appertly?!?! so thanks solved
Go to setting then go to system info....then press
Menu +shift+x
Then it will ask something...and press yes
Posted on Feb 03, 2009
My son passed away two weeks ago and I'm trying to get his phone unlocked so I can maybe get some closure as to what was going on that could have led to his death. He was only 18. Teen mobile will not help...
I don't know if this will work. I just found it on this site. Good luck and sorry for your loss.
In order to hard reset the sidekick u have to take the battery cover off when it is off press and hold the {R} letter and take the battery out while still holding {R}, count 4 seconds and place the battery back into the phone while still holding {R}. If this was done right then right then you should see the phone restarting and when it is fully powered on then u should see that the phone lock is completely removed and the phone is not blocked at all
Mar 24, 2009 | Nokia N70 Cellular Phone
Sidekick 3 keyboard keeps lockig
i am having the same problem and nothing l do fixes it!
Sep 10, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Hi - regarding sidekick 3
if the screen is black all the time most likely is the ribbon, but if it is just the camera, the the steps to do is the ones on the post, i've fixed a few that way i fixed one that took like 10-12 times before it started working again.
the sidekick 2 "skii" is known for the cam. to lock up on it.
Aug 27, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick is going crazy wont turn on anymore
This problem was said a lot by some users when the first batch of sidekick 3's were released last year. What you do is do a soft reset @ + 1 + 0 and then when it shuts down quickly hold down the W and when you see it restart you should see the sidekick 3 picture with a face on it and stars above its head, and from there you select English and you follow what the screen says to help you get past the bootup screen.
if you continue to have a problem, try removing your memory card and see how the phone works for a while.
Mar 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Help please
This tip unlocks the 3 digit security lock.
1. at the same time hold the menu button (top left) and the jump button (bottom left)
2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
4. The phone will reset and clear/unlock the security code
http://shop.sidekickskin.net/Sidekick-Tips-Tricks
How to do it
Clear 3 digit privacy lock on a Sidekick
TMobile Sidekick 2
yep, you can do a master reset.
Want to clear out info on your Sidekick info (ie: to sell yours)?
1) Remove your sim card
2) From the jump screen: Menu -> Settings -> System Info
3) Press Menu+Shift+X Select OK to clear the flash.
4) Press Menu+Shift+R Select OK to clear the login information.
5) Perform a hard reset now. This will reboot the device.
To perform a hard reset:
SK2 - Press the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen.
6) Call your carrier and ask them to detach your device IMEI from the username locked in. Once that is done, hard reset without your SIM card inserted.
You're done.
Jan 01, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick i.d
report.gifTry this............................................................. 1. Get to the screen where you would normally type in the 3-digit privacy lock code
2.Hold key-menu.gif + key-jump.gif to get to the Emergency Phone Call screen
3. Hold key-jump.gif + + s which takes you to the SYSLOG screen
4. From there press key-done.gif, key-jump.gif, or key-cancel.gif and you're in!
Dec 06, 2007 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 unlock code or how to unlock
ok dis is wat u have to do (i only tested dis on cingular or at&t waveva u call it)
1.your sim needs a password
2.turn off ur sidekick 3
3.place ur cingular card in
4.turn on sidekick 3
5.itz gunna ask you for a special code ignore it
6. go to settings den sim center
7. if ur sim lock is disabled jus enable it
8.den change ur sin pin to wateva you want
9.once u change it you will signals bars go up
10.go 2 settings network options
11. press scan scan select manually
12. select ur network
13. and datz it your sim iz workin on sidekick 3
if u turn it off u will have 2 do da same process again
soon i will put a video of dis on youtube
Nov 22, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
107 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
