Question about Audiovox MP4128 MP3 Player
How to install firmware in jxd mp4 - Audiovox MP4128 MP3 Player
  • safetyfirst1 Mar 15, 2009
    I have jxd921 mp4 player
    I want to upgrade the firmware but how, and where can I find the firmware?
  • aakashl Apr 09, 2009
    I wants to change my jxd 661 themes so, What can I do for you ?
3 Suggested Answers
shadow83
  • 496 Answers
SOURCE: where can i find the free firmware software for
mympxplayer.org/image-vp60195.html
Posted on Sep 24, 2009
SOURCE: Video not seen in JXD 661 MP4 player SD Card
convert the video into a format like mp4,3gp
Posted on Dec 27, 2009
What is the difference between JXD S7800A and JXD S7800B?
JXD S7800 has two versions:
JXD S7800A: Quad Core, 1GHz (CPU:cortex A7, GPU:Power VR SGX 544 mp2),1GB DDR3, 9 emulator games and android games
JXD S7800B: Quad Core 1.4GHz,2GB RAM, ARM Mali-400 MP4 GPU, 16 emulator games and android games
JXD S7800B is better than 7800A.
Dec 12, 2014 | Audio Players & Recorders
How to instal JXD 698 frimware ?
NOTE: Installing new firmware ontp any JXD is difficult, and OFTEN results in a brick of the player. Try this at your OWN RISK.FIRST: Find the firmware, online, that you wish to install.
NEXT you need to install the FRM program and the driver setup program that should be included in the zip, then on your JXD 661 go into tools - upgrade - usb, when it says connecting to PC then connect your player to the PC with the USB cable, you should see Windows going crazy installing drivers, once it's done open the FRM program, click on advanced, then right click on RSV, go to set working folder and choose the directory containing aimg and bimg and the .bin file, then right click firmware, go to set file, and click the .bin file it shows in the pop up window, then ok. Then in the main FRM program window click on basic, make sure Program All is selected, and untick Read Verify, tick Auto Power Off, then ISP. After a while, it should say firmware programmed successfully and hopefully there you go!
THIS IS EXTREMELY RISKY
Jun 17, 2011 | Video Game Consoles & Games
Sir, I Have JXD 656 recently I connected it to my
WARNING : This procedure can render your device dead, so do not try if your player is working fine.
  1. The most important step of the whole process is to correctly identify your device CONTROL CHIP and CPU, using wrong firmware or flashing tool may cause damage to your device, unscrew and open your device and write down all chip id's and motherboard numbers you see, you can also try the EasyChips - firmware identification utility but it did not worked for me.
  • You will now need to download the correct firmware and flashing utility for your device, visit sites below and search for your control chip and cpu to download the firmware and flashing utility, you can also post on user-forums to get help identifying the firmware :
  • In my case the chipset was Sunplus AJ262-V7 and the utility needed to flash it was FRM Pro.
  • Once identified you need to connect your device to computer via USB in camera mode (Press A + OK button and plugin USB cord on player), for Windows to identify this mode you will need camera drivers you need to point Windows Found New Hardware Wizard to Driver folder downloaded with the FRM Pro utility above, this will install the first camera driver, for correct identification by flashing utility you need to install a second camera driver - open Windows Hardware Manager and install unidentified camera device drivers by pointing the driver wizard to Driver folder used earlier.
  • Now install and launch FSM Pro flashing utility the new firmware.
  • Jan 13, 2011 | Audio Players & Recorders
    Dec 27, 2009 | Apple iPod touch
    I accidentally erased the flders that appear on the computer when i connect my mp4 how can i get the back in order for me to be able to use it again it's an MP4 Titain 4GB
    hello dear jxd Ltd
    here maynmar
    i want to say some question about jxd mp4 player
    it csreen is white screen and another jxd mp5 player is power green led is open but screen is black csreen so, pls explain me above problem
    Oct 15, 2009 | Audiovox MP4128 MP3 Player
    Jxd 685 ipod not able to power on, also not recognise by PC, seems dead.only the green light glows untill the power on button is pressed.pls help me.
    The firmware has got corrupted...unfortunately the firmware is not available on the net as far as i have searched...even the official site does not provide the firmware... If you have another working piece,you can extract the firmware from there and use it on the dead one...if you get hold of a working piece, post back for further info..
    Sep 30, 2009 | Audio Players & Recorders
    Display problem
    u will need to reload the firmware using FRM tools....identify the screen size if its 2.4,2.5 or 2.8 and download the associated firrmware from this 4shared folder....http://www.4shared.com/dir/11185794/f5b91a38/sharing.html d FRM tool and instructions are available in the 2.4 firmware...
    Aug 24, 2009 | Audio Players & Recorders
    Audiovox MP4128 MP3 Player Logo
    3,230 people viewed this question
    Top Audiovox Audio Players & Recorders Experts
    John
    John
    Chinmay Joshi
    Chinmay Joshi
    Computer Links
    Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
