Question about HP Pavillion ZV6000 Notebook
Reboot back to factory settings
Can i reboot with out the cd/drivers
  • Kim Tyler May 11, 2010
    reboot?? yes
    what exactly is the problem??
  • 837 Answers
If you are having problems with your system and you want to restore it to factory settings .. as long as there is nothing wrong with the CD drive itself you do not need windows drivers for it to function properly during a factory restore
Posted on Feb 02, 2009
Can I reset it back to factory setting with out a CD or DVD
If the restore partition is still on the hard disk then press Alt and F10 just before it boots. Otherwise try T8 just before it boots. If this fails try Creating a System Rescue USB drive (Note: An alternative to the spyware-laden Daemon-tools for mounting the ISO file as a virtual CD-ROM is Virtual CloneDrive). If you have trouble with the System Rescue CD, you can try some other distros.
Reboot the netbook and go into the Acer BIOS settings. Change the boot settings to check USB first. Plug in your System Rescue stick, and restart the netbook.
Run "wizard", and launch gtparted (icon towards the lower-left of the screen).
Delete partition 2, create a new one, then reformat it as NTFS
Mark partition 1 as bootable (right-click, edit flags). Remove USB drive.
Reboot into the Acer System Restore software. Choose to restore the system.
Plug the System Rescue USB drive back into the Acer netbook.
Reboot into the System Rescue CD/USB, go back into gparted, and flag the restored partition 2 as bootable.
Remove USB flash drive and reboot.
Hope that helps.
Jan 11, 2014 | Acer Aspire 7720 Notebook
I restored my acer aspire one back to factory settings without a back up device. when I try to restore from disk with an external cd. it says my disk is incorrect. it was the disk that came with it.
In that case, only the seller can solve it replacing the disk or your CD drive that I did not want to mention but seems to be your problem. Before calling them, try to disable the CD driver in Control Panel, reboot, Enable the driver, reboot and try the cd again.
Aug 10, 2011 | Computers & Internet
How do i reboot emachines
Hi! Welcome to www.fixya.com.
  • Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.Press F1 when the black screen appears; you will enter the setup configuration mode. You will be presented with a menu.Select Restore Factory Defaults. Your computer will do all the work for you. As with the CD, this process may take several hours.
  • Read more: How to Reboot a Computer Back to Factory Settings ' eHow.com http://www.ehow.com/how_4479794_reboot-computer-back-factory-settings.html#ixzz1SPR0nI9L
    Hope this resolution fix the problem on your computer.Thanks for contacting Fixya. God bless. Bye for now.
    Jul 17, 2011 | eMachines Computers & Internet
    How do i reboot my laptop back to factory settings
    To reboot to factory setting you need to have the restore disk from the computer, put it in the drive and restart with the cd in the drive, if the startup screen does not start right away you need to type f11 or f6 to change startup order to cd first the the restore screen will startup and click restore factory settings
    Jun 04, 2010 | eMachines eMD620-5133 Notebook
    How do you Reboot a computer back to factory setting
    Instructions Things You'll Need:
    • Factory Settings CD
      How To Use the Restore Factory Setting CD
    1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
    2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
    3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
    4. Step 4 Reboot the computer to complete the process.
    5. How to Reboot Using the Computer Start-Up
    6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
    7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
    8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
    Jan 27, 2010 | Computers & Internet
    I need to reboot to factory settings on an old gateway how do I get it done?
    Older gateways used to come with a recovery CD that would rebuild the machine back to factory settings. The alternative (which can be a little more difficult) is to use an XP setup CD and format and reinstall the operating system. The downside of that method is that you would need an XP key and you would also need to manually reinstall the hardware drivers like the sound card, network card, etc.
    Nov 15, 2009 | E-Machines (T2958) PC Desktop
    Restore factory settings without CD
    Hello
    Reboot your system . Press F11 when started . Generally F11 is for recovery to the factory settings . If there is any other option for recovery , select it . Your system will be booted to the factory image if tha is already stored on your system.
    Jas
    Apr 13, 2009 | Computers & Internet
    Compacq Presario
    Prior to re-installing your OS, backup all your documents..
    Insert your recovery disk cd on the cd rom drive and reboot your pc.
    As it reboots press any key to continue so it will boot from cd and delete the partition, create a partition and active it.
    Then install the OS which goes to C:\ drive. After the installation is complete install all the drivers and the applications. You can go to the manufacturer's website and download others drivers as needed.
    Activate Windows then go to Microsoft Update
    Dec 09, 2008 | Computers & Internet
    I want to reboot my Toshiba A200 back to factory settings, i have a spyware down load **** that keeps on asking me to install.....how do i reboot
    If you have the recovery CD, then put that in the drive, reboot the laptop and make sure you boot to the CD. The recovery process will start up and you can restore the laptop to it's factory settings. Make sure you have all of your documents, music, etc. backed up.
    Dec 05, 2008 | Toshiba Satellite A205-S4617 Notebook
    Fedora
    When you start your computer Press F2 or F12 to make changes in Boot sequences.Make the CD-ROM or DVD-ROM 1st in the Sequence. Save the Changes and Exit.Before rebooting put the XP CD inside the CD-ROM Drive and reboot.
    If you donot have Driver's CD of Motherboard,it is better to make Driver's CD before reinstallation.
    Sep 19, 2008 | fedora Linux Operating System
    HP Pavillion ZV6000 Notebook Logo
    320 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
