Question about Car Audio & Video
I have a mitsubishi colt czc3 and I want to buy a cable to plug into the aux socket on the dashboard...what do I need?
    Problem Solver:
  • 17 Answers
Post a photo of the aux input socket on the dashboard and ill do my best!!
Posted on Feb 02, 2009
Orange light on dash showing a fan
Need to have it scanned. If you get a PO420 or PO430, it's the cat. converter which is a manifold converter. Must change spark plugs also. Misfire in engine
May 02, 2016 | 2005 Mitsubishi Colt 1.1
Connect an AUX cable
Use the speaker output and plug it into the mic socket. Not ideal but the alternative is to buy a cheap adaptor for the end of the aux cable so that you can plug your speaker output into the aux input.
Nov 22, 2013 | Pioneer VSX-1014 Receiver
Eps light coming on
1. disconnect the battery both terminals.
2.Look for EPS control module on front passanger deck below dashboard,disconnect the cable connector
3, spray both EPS and cable connector with contact cleaner aerosol.immediately plug in back.
4. Right above EPS module there are Air Con piping make sure the condensate water do not dripped onto EPS module by covering it with plastic sheet.
5. Spray all cables to battery terminal with contact cleaner and connect it back.
6. Start your engine .
In case it still dont work ,you have to look further into EPS motor.
Hope it will solve your problem at least it work for me.
Oct 29, 2013 | 2006 Mitsubishi Colt
The plug works because the socket switch is turned on and the volume control button is green but when I plug in the auxiliary cable there's no sound? Is there something wrong with the inside of the...
Was the second aux cable you tried new or old? If both aux cables were older, you might possibly want to try (not necessarily buy) plugging in a new one. If you have done that: How old is this receiver? Brand new or older, if older it could be build-up inside the jack causing a break in the connection between jack and aux cable. If this is the case then a simple cleaning with a Q-tip and some alcohol could help immensely. If that's not the case, it sounds like you could have a short in the jack.
Jul 13, 2011 | Audio Players & Recorders
I have a denon ipod dock and a harman/kardon receiver. Can I connect the dock to the receiver?
To plug the dock into the receiver to supply power and interface with the iPod you would have to have one with a built in iPod. Most receivers will not do that, the most common way to connect an iPod to a receiver is using a 3.5mm to RCA cable. You don't even need the dock to do this, you can plug the iPod directly in. You can find this cable at most electronics shops if you don't want to buy online, like Best Buy or Radioshack.
Make sure you connect the white and the red end of the RCA cable to the correct sockets on your receiver, and the small 3.5mm jack into the iPod or the iPod dock, you have to turn the iPod volume up and select the corresponding input on your receiver. If you plugged the 2 RCA jacks (white & red) into the socket labeled "AUX" or "Video 1" you have to select "AUX" or "Video 1" in order to hear the sound.
Jun 18, 2010 | Harman Kardon Audio Players & Recorders
How do I use altec lansing acs40 with a laptop?
Fairly easy really. You'll need to buy a jack to jack AUX cable. Single point for stereo needed and a headphone jack on the laptop.
The left hand and right hand speakers are slightly different. The right hand speaker only has a cord coming out the back of it and no AUX points.
The right hand speakers has a series of small jack points.
The first hole is the adaptor plug that has to be plugged into mains socket, then the 1st hole marked SPKR has to have a jack to jack cord going from that speaker to the other one. The last two holes marked "A" and "B" give you the option to put two jack to jack AUX sound cables in.
To get it into your laptop, you'll need ONE AUX jack to jack cable and fit it into the point at the back marked "B" and then through the headphone socket on your laptop. You will then have sound.
Make sure to remember to put the system on by the push button switch on the back of the left hand speaker. The speaker system also has another rotary switch on at the front of the speaker.
I've had these speakers for well over 10 years - brilliant sound quality and very durable. Hope it has helped you!
May 04, 2010 | Altec Lansing Multimedia Computer Speakers
Mitsubishi Colt Cz3 1.3 2008 start problem in a cold seasons
This dosen't help but.........
I have a similar problem. Every 4 weeks or so the car refuses to start. Again battery is not a problem but if we use cables to jump start from another car it starts fine.
Mitubishi cannot find the answer, only suggestion was to spend £150 on a new key , however the problem has now occured with both of the keys !
Feb 03, 2010 | 2006 Mitsubishi Colt
I have got the new plugs and socket , but the socket wont fit down the hole
There are different sockter sizes for the different size plugs.
Do yo have the right one?
Also you might need a thin walled socket - yes they have these.
That would fall under great engineering!
Dec 16, 2009 | 2006 Mitsubishi Colt
Where is the aux plug for this radio; Eclipse's optional Rockford Fosgate premium audio system
The Mitsubishi Eclipse with the Rockford Fosgate premium audio system does not actually have an aux plug. When you are scrolling through the sources, one of them listed is an AUX. This implies that there is a headphone jack somewhere in the vehicle where you can plug an iPod into and play it through the system. The port, however, was never actually installed on all pre-2009 eclipses.
The only way to access this feature of the stereo is to obtain an AUX cable from the mitsubishi dealer, which will be a wire harness that connects to the back of the head unit and provides an additional AUX port cable allowing you to plug in your iPod. You can talk to your local mitsubishi dealer about the cable, from what I hear, its rather expensive, and then go to best buy, somewhere similar, to have them install it.
Aug 06, 2009 | Rockford Fosgate Car Audio & Video
Mp3 connector cable
A double male mini 3.5 mm headphone jack you can get at walmart or radio shack.... does your car dash have a small headphone style jack? if your ipod head phones will plug into it then it is exactly what i described above.... Good luck
Feb 02, 2009 | Car Audio & Video
Car Audio & Video Logo
176 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
