Question about Car Audio & Video
Mp3 connector cable
What type of connector cable is required to connect an ipod to the aux/mp3 connector on the dashboard of a new Colt CZC3
  • m3odq May 11, 2010
    Post a photo of the connector on the dashbord and ill do my best!
    M3ODQ
    Problem Solver:
  • 14 Answers
A double male mini 3.5 mm headphone jack you can get at walmart or radio shack.... does your car dash have a small headphone style jack? if your ipod head phones will plug into it then it is exactly what i described above.... Good luck
Posted on Feb 13, 2009
Playing MP3
Should be able to with a headphone jack to rca cable. Does the shelf system have an aux input on the back?
May 29, 2013 | Aiwa Audio Players & Recorders
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
My iPod has a bigger case so not I won't fit on my ihome I only use my ihome for music but my iPod won't fit so I bought an aux cable for my IPod, wene I plugged it in it didn't work the cable worked
Your video ran out. Anyway, you could try using an adaptor so your iPod will sit on your music box. If that fails, connect via your aux lead, gently pull your aux lead out of the back of the box gently and slowly giving it a wiggle, you might make the connection. Other than this, as you've not provide enough footage, you might need to buy a new aux cable that fits. Not all products are compatible with iDevices, you should check the instructions to see if your model of iPod is compatible.
Oct 14, 2012 | Audio Players & Recorders
There is a auxiliary button on the sony cdx-m8800. Is there a way to hook up an IPOD? The stereo also has MP3 written on the inside face. Thanks
Contrary to the below Expert's testimony, the UK CDX-M880 has a REAR AUX connector that will enable you to play your iPod through your car's stereo.
You will not be able to control the ipod's interface through the radio. You will have to use the control on the iPod .
You require a Male 3.5mm extension cable like the following...
a5e60c6.jpg A 4-6 foot length is recommended, as the cable will need to be routed from behind the radio to a place your iPod can be easily manipulated.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 18, 2009 | Sony CDX-M8800 CD Player
AUX to work
Hello alex_maya21,
The AUX input on your CDE-9845 is on the back of the receiver. To use it, you need a cable with the appropriate connectors on each end. The receiver end needs to be a standard "mini plug" and the device end needs to match the output connector on your mp3 or iPod. There are many commercially available cables that you can plug in and run the device end under the dash to a convenient location. Almost any car audio retailer will have the correct cable or you can order one online from www.crutchfield.com.
Hope this helps.
Jun 21, 2009 | Alpine CDE-9845 CD Player
MP3/Ipod on 2009 Kia Sportage not reading media
It requires a special usb/stereo connector, got the same issue with my Ipod touch
Jun 07, 2009 | Apple Audio Players & Recorders
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
Aux
if it has aux its probably going to be right on the front, its most likely mini-din, the same connector used for headphones and pc speakers, youll need a mini-din to mini-din cable, also known as an audio cable, you can get the mcheap at radio shack usualy, its a cable that allows a pc subwoofer to be hooked up to the pc's audio card, with this just turn you ipod on and control it as normal while the deck is set to aux and you should hear your ipod. some decks have actual ipod connectors that work differntly but I personaly don't know much about them, I have the mini-din connector, and an ipod shuffle
Apr 23, 2007 | Pioneer KEH-P5950 Cassette Player
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
