Question about Epiphone Les Paul 100 Electric Guitar
LP epiphone 100 "g" string problem,
I'm having a problem with the G string on tuning. I tune the guitar, but very shortly after I bend it few times it completely gets out of tune. I regularly change the strings though i cant get the problem fixed.
Well, i have this guitar, for me if i bent the string it would pop off the nut, but it went out of tune on me also becuase of the tuners. so i suggest checking the nut to make sure the string sits completely flush in there, and than also just upgrading your tuners if you can and it will be fine. but deffinately upgrading your tuners would stop that hopefully but still could be something with the nut becuase i had both. tuners = machine heads
Posted on Mar 25, 2009
  • led_zeppe707 Mar 25, 2009
    also to add, is that the longer you have the strings on your guitar the more they are stretched and go out of tune a lot less. but this string never goes out of tune on me becuase i upgraded tuners, so honestly get some really good ones and do some research on them. i got some good ones, Grovers Vintage-135, look like ones on gibsons but better than gibson brand, i actually just dropped my guitar recently and hit my tuners, the one tuner that hit didnt break but went out of tune, and all of the rest stayed in tune
    Problem Solver:
  • 17 Answers
After tuning ....put a capo on ... if this stops the problem then the cause must either be
1 the string catching in the top nut or
2 a faulty machine head
if it still goes out of tune with the capo on then look at where the ball end of the string sits
Posted on Feb 02, 2009
Epipne es-335 g string sounds out of tune
Most likely the bidge needs to be setup. Take it to any guitar shop to get it done.
Mar 31, 2014 | Epiphone Music
What is the proper way to change a string on a guitar so it doesn't slip?
The first thing to remember is that the strings will stretch so i always over tune it about a turn for small strings and 3 for the big strings. To prevent it from slipping when you are tightening the string pull it tight while turning it and make sure the string has overlapped its self a couple times before releasing it.
Apr 08, 2012 | Fender Music
How do I tune my Les Paul Studio Guitar using the tune-o-matic.is there a method that I can get instructions for?
Here is a link to their standard manual:http://www.epiphone.com/images/EpiOwnrsManul.pdf Pay attention to Intonation and Saddle Adjustment for a Tune-O-matic bridge. They come adjusted but you may have to adjust if you change the guage of your strings.
Jul 04, 2010 | Epiphone Les Paul Studio Electric Guitar
Buzzing of strings in frets up to fifth fret; seems that the bridge may be low but it's not. Also, too there is more gain in high strings than the fifth and sixth
Sounds like a warped neck, if the bridge isn't low what else would cause the strings to buzz.? With the gain problem perhaps the neck is twisted as
well as bowed. Epiphone are proving to be quite popular but they are built to a price and for beginners they are usually a good choice. Unfortunately some fakes of different guitars are sold on ebay and they often make better tennis rackets than a musical instrument. Unless you changed them the guitar usually has a cheaper Humbucker pickup. Check it's fitting anf make sure there are no loose parts or wiring sitting against the soundboard on the inside.
Try looking down the neck of the guitar and seeif you notice any warp or bend. Overtightening the strings can cause the opposite warp and the strings end up further from the frets. Also try some measuring. The distance between the any string and the fretboard starting at the nut and working down to the bottom of the fretboard. These measurements should be consistant
Also, check the nut to see if the grooves aren't too deep. This could cause buzzing by allowing less distance between the string and the first fret.
Make sure all the frets are seated correctly and not slightly out of kilter at one end.
That should give you enough to keep you busy for a while. There are plenty of reasoins why a string will buzz. I've covered a few mecanical ones but without sounding rude there are also player caused buzz. Depressing the string too far behind the fret can cause it whereas too close to the fret can kill the note. But that's not my field in this situation. Check all the above and then try your fingering. One way or the other that buzz will stop. The best way to check if it's you is to get someone else to try your guitar out and see if the buzz buzzes off :-)
good luck
Apr 07, 2010 | Epiphone Les Paul 100 Electric Guitar
What is the recommended height for humbucking pickups on a epiphone lp 100?
the closer to the strings the greater the magnetic pull. it's a personal variable to the player.basically how aggresive of a sound you want
Dec 30, 2009 | Epiphone Les Paul 100 Electric Guitar
Gibson Les Paul wont stay in tune
That's the problem; you're using light gauge guitar strings. Chances are that if you are not used to playing strings that light, you're fretting hand will hit the strings with more force than is neccesary to fret them, thereby forcing them out of tune. You can solve this problem by adding more winds around the string post (three or more winds should do it), or you can switch to a heavier gauge of string.
If they're true locking tuners, they should have a notch on the back of the gear housing that you turn with a nickel to engage the locking mechanism once tuning has been established.
Also; check the intonation of the guitar itself on an electronic tuner. If it tunes right but sounds out of tune when played, this is an intonation issue, and can be solved by adjusting a small set screw that moves the individual saddle back and forth in the tune-o-matic style bridge. You can check this by tuning the string to the correct note, then playing the same string at the 12th fret and checking it against your tuner. If it rings in true, you're fine, if it comes up flat or sharp, every note on the fretboard is going to be off by that much, and you'll have to adjust accordingly (turn the screw to the right to add length and lower a sharp note, turn the screw to the left to subtract length and raise a flat note, if I remember right).
Hope that helps.
May 12, 2009 | Gibson Music
Which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
"G" string tunning problems,
hi there .... flat means does the string go lower in pitch ...needing the string to be tightend after you have bent it ?
Do you give the strings a real good pull a few times after fitting? this often corrects the problem .... let me know ..as there could be a few other reasons
cheers Pete
Feb 02, 2009 | Epiphone Les Paul 100 Electric Guitar
My Dean razorback V Standard keeps going out of tune and I have no clue how to fix it.
First, I don't know how long you've been playing guitar but you need to make sure the strings aren't old and/or not kept clean. The oils and skin cells from our fingers will cause strings to break down in there elasticity, therefore causing them to lose there retention (eg. memory). If you have a locking system with floating bridge then make sure your locks are tight, but not to tight as to strip or break the screws. Next, if you have a cheaper guitar, like in the $250 range, you will experience this more often than not, especially if you don't have a locking system. But just remember that guitars have to be retuned all the time (just watch live video of guitarists like Jimmy Page and Angus Young, etc.) if you play a lot and really play the instrument to the fullest (eg. Dive Bombs, EVH Horsie, Pitch Bends, etc.). Also, when you put on new strings they need time to stretch before they find that place where they retain their memory so it's a good idea to play and stretch the strings using various techniques like bending and whammy (EVH has been known to boil his strings to aid in this). Last, but not quite the least, if you find your guitar going out of tune after just a few minutes and after all my suggestions then your guitar may have a problem with its INTONATION, which you'll need to take it to a guitar technician which won't cost much and you'll be very happy with the sound. One last thing to remember, if you have a cheaper guitar without locking system they're really not capable or designed for using the whammy bar that comes with most of them---this is just a feature for helping to sell the guitar because everyone wants a whammy bar---the guitar will go considerably out of tune everytime it's used. Hope this long explanation helps.
Dec 09, 2008 | Dean Razorback Db Electric Guitar
Guitar strings on a mandolin.
Looking at your desired notes the mandolin is standard tuned to gdae.
So three of the four notes are already available, just put the "d" mando strings where the "g" ones would go and the "g" ones where the "D" ones would go the highest is already a "e" and I am sure the "a" would tune up to a "B" with little risk.
You can also
look at string sets made for the madochello or possbly octave mandolin.
Good luck,
The dude.
Aug 07, 2008 | Johnson Ma100 Lynchburg Mandolin
Epiphone Les Paul 100 Electric Guitar Logo
327 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Robert Graf
Are you an Epiphone Music Expert? Answer questions, earn points and help others
