Question about HP Compaq nx6110 PC Laptop
Cpu over heating because of upgrade
I had a Intel Celeron M 1.40 GHz in my HP nx6110 laptop I upgrade the cpu to the highest cpu that came with this moddel.
I upgraded to the Intel Pentium M 2.13 GHz. but I used the same heat sink. The laptop has the latest Bios but I have no way of changing the fan speed. In about 5 min. the cpu over heats. I think I need to change the heat sink but I do not know what one. I put the 1.4 back in untill I can get assistance with this problem.
Thank you
CPU upgrade for Compaq SR1220NX Desktop
Here are the CPU specs that will help you find a new CPU for your desktop:
Socket 478 for Intel P4 Williamette and Northwood processors
  • Supports Intel Pentium 4 processor up to 2.8 GHz
  • Supports Intel Celeron processor up to 3.06 GHz (Prescott based Celeron with 533MHz FSB)
Oct 14, 2014 | Computers & Internet
What to do next after upgrading CPU
Hey;
Start your computer and right after the hp logo, keep pressing the F8 button until you see a large list of options.
Select
"USE LAST GOOD KNOWN CONFIGURATION"
and press enter. Let windows load and it should work just fine.
Feb 03, 2014 | HP Compaq 6720s Notebook
Is there a cpu upgrade for an hp pavilion 6835 with a motherboard 115561 cognac 20000731
The fastest Pentium 3 that will work in your board is a Intel Pentium III 1GHz chip. Here is a link to the specs:
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201000%20-%20RB80526PY001256%20%28BX80526F1000256%29.html
You could also get a Intel Celeron 1.1 GHz but it only has half the level 2 cache size so it's actually a bit slower than the Pentium III 1GHz chip.
Here's a link to celeron specs:
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20%28BX80526F1100128%29.html
May 23, 2012 | Powerleap PL-NEO/T Celeron, 1.4 GHz...
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Apr 12, 2010 | HP Pavilion dv1000 Notebook
Is it possible to upgrade to a faster processor on a hpn pavallion dv1000
here is a list of processors supported on that machine
side bus (FSB)
Mar 15, 2010 | HP Pavilion dv1000 Notebook
Celeron 540 upgrade
Aspire 4315 Specifications Specifications
Part Number
Varies by specifications
Processor / Speed
Intel Celeron mobile processor 530/540/550 (1 MB L2 cache, 1.73/1.86/2 GHz, 533 MHz FSB), supporting Intel 64 architecture
if you have a 2 Ghz processor installed, you will have to replace the motherboard to go with a faster CPU.. which will be spendy..
Hope this helps
May 06, 2009 | Acer Aspire 4315 Notebook
I have an intel celeron 1.79 GHZ on my dimension 2350,what is the better processor for upgrade? and is there something else that i should change inside for the new processor?
you said that you want to upgrade ur 1.79ghz celeron cpu.
to upgrade a cpu just check that the packaging of the new cpu matches with the motherboard.
and also check that the motherboard supports the new cpu that you are installing. check this in the manufactures site.
Apr 14, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
I have 2.6 celeron processor with intel 865 motherboard i am up grade tell us who is processor best
on mb with intel 865 the bigest CPU is pentium 4 @ 3GHz. socket 478
however your MB might require to update microcode for the new CPU.
one more thing: this chipset Intel 865 is obsolete, and intel does not manufacture this cpu type anymore.
Feb 22, 2009 | HP Celeron A , 2.6 GHz (DL458AV) Processor...
Hi, I have HP dv4000 model, Intel Pentium 1.60 GHz processors, Can I upgrade the processor? And what is the maximum upgrade for the processor? Regards, for more details and features...
According to the service manual, these are the processors your notebook will handle:
Part#
Intel Pentium M 2.13-GHz 396700-001
Intel Pentium M 2.00-GHz 396699-001
Intel Pentium M 1.86-GHz 393327-001
Intel Pentium M 1.73-GHz 383474-001
Intel Pentium M 1.60-GHz 383473-001 and 396698-001
Intel Celeron M 1.50-GHz 383471-001
Intel Celeron M 1.40-GHz 396697-001
Intel Celeron M 1.30-GHz 389036-001
So it looks like the Pentium 2.13GHZ is the top one.
Here is a link to the service manual for reference: This is on page 5-24.
Thanks fro using Fixya. A Fixya rating would be most appreciated.
Jan 26, 2009 | HP Pavilion dv4000 Notebook
Possible cpu upgrades for p4vmm2 motherboard
I see that you have already had this answered at Techspot.com They were right when they answered you, you need to check your MB manual to see if it is capable of upgrading to the CPU that you want to use, not all MB support all CPU's just because they both have 478 pins. I looked on the ASUS website and they don't even list your MB model on there.
Mar 20, 2007 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
HP Compaq nx6110 PC Laptop Logo
232 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
