Please visually check your battery. If top of the battery is surrounded with blackish material, or it is used for more than two years, probably it is dead. If not, then get the specific gravity of the battery be checked. It is supposed to be in between 1.280 - 1.320 at the temperature of 40 degree Celsius. If the specific gravity is found low it needs to be re-charged for nineteen to twenty two hours at the rate of slow charging.
Regards,
Shadab Lodh
SOURCE: 91 toyota camry 4 cyl. It will not start even with
Hi Mike
Try lightly tapping the starter with a spanner and at the same time turning the key to start, if it starts you need the starter overhauled.
Regards Gary M
SOURCE: 2002 Toyota Corolla S. Replaced battery this
Look for a lose connection at the crank shaft sensor. This is a signal needed for obtaining tachometer as well as turning on the fuel pump.
