Question about Graco Quattro Tour Travel System
Car Seat Belt keeps getting stuck
I have the Deco travel system, and everytime I put the carseat back in the base, the seatbelt gets lodged somehow between the base and the carseat. Now everytime I want to adjust the straps I have to unhook the carseat from the base and do it from underneath instead of using the adjustable strap in the front. Any answers?
    Sergeant:
  • 308 Answers
Check the adjustable strap then check the spring of the strap .
Posted on Jul 16, 2009
Carseat jammed to easy base 2
Try pressing down very hard on the seat while trying the release. If that does not work, call the manufacturer.
Note: if this does release, check the seat belt for damage before using again. Also check that the belt path used to install the base is/was correct.
-- Marc
May 23, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi, I would like to ask a few questions: 1. Does the Maxi Cosi Cabrio car seat fits only to the isofix base, or can it be installed to the mico base as well ? If it does, the only difference is that the...
Good Morning
The Maxi Cosi CabrioFix can be fitted without any base, using the 3 point seatbelt: With the EasyFix base, using IsoFix points or 3 point seatbelt: With the EasyBase and EasyBase 2 using the 3 point seatbelt. It cannot be used with the Mico carseat base as they are not designed to be used together. The Mico is available in US and does not meet UK standards: Likewise the CabrioFix does not meet US standards so they should never be used together.
If you don't know how to fit the carseat into your vehicle using the 3 point seatbelt please check your user manual, or download a replacement copy at www.maxi-cosi.com before use go to an authorised retailer to check it is correctly installed as this will affect the performance of the carseat.
Aug 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Our car doesn't allow us to use the easyfix base (we have a new Citroen Berlingo but it doesn't allow ISOFIX bases with the leg support), so we have to put the cabriofix in our car with the safety...
The carseat has obviously not been correctly installed using the seatbelt as it cannot be removed without undoing the seatbelt if it has been correctly installed. Contact your retailer for a demonstration on correct fitting.
Jun 19, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How can I un-stick a stuck seat belt. It worked fine last time we used it and does not seem to be twisted. 2001 chevy blazer
If it is stuck in the seat belt clip (meaning its buckled) then that model year had a seat belt buckle recall for failure. If its stuck in the seatbelt retractor and your seatbelt retractor is floor mounted there is a release pin on the ratchet gear. TO access it you will need to remove the plastic cover located at the floorboard next to the door on the side of the car that is stuck. If its a seat mounted retractor this means the retractor mechanism is located within the seat frame. You will need to view the bottom of the seat of the belt and see the anchor point. Seatbelts must be anchored to frame of car. Trace it into the seat back. If its located in the back of the seat you will need to remove the seat cover to the extent to reach the mechanism. This can be located at the bottom of the seat.. but more than likely is located at the shoulder area. The Seat cover (fabric) is removeable via clips located at the base and tucked into the seat (think hidden bra/pant clip style connectors or zipper) If you have leather seats it is a bit more detailed and more difficult to manage the seat covers. Typically your local Chevrolet dealer mechanic can get this done in 10 minutes (based one experience) and quite possibly wont charge you or charge you minimally. The downside to this is if its locked that means the same gear that locks it in an accident was frozen in place somehow and this typically indicates a dirty dirty spring or broken spring mechanism. The locking pin operates on centrifugal force and activates based on speed by which the seat belt is pulled out. (just a bit of knowledge) Good luck
Jun 15, 2010 | Cars & Trucks
Rear seatbelt stuck behind head rest in locked position
haha we know you didnt do it on purpose, without seeing your problem and the hard to describe issue, i can only recommend to maybe try folding the seat to the cargo position, if that helps. if not, then you will more than likely need to disassemble the rear quarter panel, and unbolt the seat belt retractor from the body of the vehicle. sorry but there is no other way
Oct 25, 2009 | 2008 Ford Explorer
Installation of base into car
Place the base into the car ,pull seatbelt through the large holes on the base, lock seatbelt and place the infant carseat in you should hear the seat click into the lock position. Hope this helps.
Jul 08, 2009 | Evenflo Journey Elite - Pink Lemonade...
How to install car seat with seat belt, instead of latch belt. illustration shows seat belt going throw where latch belt is in the base.How does the latch belt come off and the seat belt go in.
this is easy to install but need to be explain with pictures. go to google.com or youtube.com and type in search box how to install car seat with seat belt. you will get pictures showing you how it's done . good luck
Jun 05, 2009 | Graco Quattro Tour Deluxe Travel System -...
How to install infant car seat
The two clips are both for the LATCH system - they're not top tethers (which go to the back of the seat for forward facing seats only).
You need to choose EITHER the LATCH installation OR the seatbelt installation - doing both together can put too much stress on the belt path of the seat, causing the plastic to weaken.
If your car has the LATCH system, there will be two metal U-shaped anchors in the seat, where the seat back and the bottom of the seat meet. Some cars only have them for the side seats, not the middle, so check your car's owner's manual - if you don't have them specifically for the center seat, you'll have to either install with the seatbelt or put it in a side seat to use the LATCH - don't try using one anchor from each side, as they won't be the proper distance apart.
If you'd prefer to use the seatbelt to install, kneel with all of your weight in the seat to tighten the seatbelt. It's tight enough when it can't move more than 1 inch from side to side if you grab it at the belt path and pull it back and forth. You probably will still be able to pull the TOP of the infant seat back towards the back of the seat of the car - that's not a problem - it helps the seat to cradle the baby through an accident.
You need to have an owner's manual, though - to request a copy, contact their customer service at consumer@djgusa.com or call them at 1-800-544-1108.
Jan 27, 2009 | Eddie Bauer 22-625-BLD
Fitting cabriofix car seat with seatbelt only
yeah i had a cabrio and just fitted it in car with the seat belt the part of the seat belt that would go around your waist goes over the front of the carseat and over were the baby would be sitting there is clips at either side just below the carryhandle put the seat belt through them then put the part of the seat belt that would go around your neck round the back there should be another clip in the middle of the back above the storage part if you put the seat belt throgh it then clip the buckle in and pull tight the car seat should be secure hope i explained it easy to follow.
Oct 28, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
Rear Facing Installation
That is the common installation process for a convertible carseat in rear-facing position. It is important that the shoulder/lap seatbelt be as tight as possible. This can best be achieved by putting as much of your own weight as possible on the carseat (without the baby of course), clicking into the seatbelt fastener and then pulling as much slack as possible out of the seatbelt strap. If you have the assistance of another adult, one should provide the weight on the carseat from inside the vehicle while the other pulls on the seatbelt strap from outside to remove as much slack as possible. If you have an I-shaped locking bracket, it should be installed over both straps 1 inch from the seatbelt fastener.
Some, but not all, manufacturers provide a metal locking bracket to be placed on the seat belt after the carseat is installed to prevent excessive slippage. You could contact your manufacturer to see if one should have been provided or you may purchase one at most major baby product retailers.
Be aware, a little movement of the installed carseat is considered normal and acceptable.
One last note, many fire stations, police stations, children's hospitals and even car dealerships offer free carseat safety checks. Call those in your area and ask if they offer this service.
~Alkara
Mar 10, 2008 | Eddie Bauer 3-In-1 with Latch
Graco Quattro Tour Travel System Logo
140 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
