Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Drill bit Stuck (and then broke off)!
Help! The bit is stuck inside my Black and Decker CD70 CRE power drill. To make matters worse, I set it on the table and it fell off-breaking off the tip of the bit. How do I get it out now? Thanks!
  • Allen Neal
    Allen Neal May 11, 2010
    does it have a keyless chuck
    Problem Solver:
  • 5 Answers
Keyless chucks have two parts (see pictures) when the drill is in operation both parts spin. Assuming you put the drill bit in and tightened the keyless chuck by hand, put on a work glove and grasp the part of the chuck at the front of the drill, grasp the other part and twist the front part anti clockwise.
If this does not work you can hold the front of the chuck and reverse the direction of the motor as if you were unscrewing something, then pull the trigger. If your hand does not grasp the chuck tight enough it will slip, hence the glove. If this does not work you may have to hold the front of the chuck in a vice or with caliper pliers and again the pull the trigger with the drill in reverse.
All this depends on what you used to put the drill bit in with your hand tight or held onto it with something else. Whatever was used should be enough to loosen the chuck
Hope this helps.
If it does let fix ya know.
Cheers
Les
Posted on Feb 12, 2009
I have a black and decker 1179/100 drill. The drill was dropped and now will run only in reverse but not forward. I took a look inside and nothing was obviously broken. What would cause this?
Obviously, the switch which controls the direction in which the motor turns the bit is either damaged or stuck. I believe I'd call B&D technical support. The fix may be something simple.
Jul 28, 2017 | Decker Drills
Chuck removal B&D KD335 drill
I have instructions in the tip section that might help. There is usually not much difference in the removal of a corded or cordless drill. Let me know if you need more assistance.
Jan 25, 2012 | Decker BlackN Household Drills and Kits...
Bit is stuck. chuck wont open. turns but makes a
the chuck is broken inside if clicking. Ace and True Value stores sell chuck replacements
Mar 04, 2010 | Black & Decker BD12PSK 12-Volt Smart...
Keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Feb 23, 2010 | Garden
Black and Decker corded drill won't tighten around a bit.
the chuck sounds like it is bad or maybe stuck from rust, what you can try and do is spray some WD-40 on the jaws and then try and holding the collar with a glove and run the drill SLOWLY in forward/reverse and see if it loosens up if not you will need a new one.
Jan 14, 2010 | Black & Decker Drills
My chuck wont open on my KD574CRE Black &
Try putting a vise grip on the bit,, and a big vise grip or chanel lock wrench on the key lock..
That should break it free..
Good luck..
Sep 10, 2009 | Black & Decker Drills
THE BIT DOESNT STAY IN PLACE
Could be 2 problems, first are you using the right type of bit to lock in this tool and second the ball that locks into the detent of the bit might be stuck or the ring holding it in has moved. Give me a brand and model number and I will find a breakdown for this and see if I can give you more help
Jul 27, 2009 | Black & Decker Pivot Plus Cordless...
Black & decker pivot plus bits are stuck
I had this problem too, an unfortunately, there's no manual on the black & decker site for this product.
I figured it out though! You have to push down (towards the motor) the chuck collar (cyllindrical black part which holds the bit). If you've tried this already, try harder - it can get really stuck and require a lot of force to push down.
Anyways, if you apply enough force, it will give and allow you to remove whatever bit is inside.
Hope this helps.
Dec 23, 2008 | Black & Decker Pivot Plus Cordless...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
993 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
