Question about Lenovo 3000V200 Laptop
Cd write wizard
Cd write is some times not working properly
  • 33 Answers
One reason may be that your writer may be old and the lense must have died.
another is that the lense require cleaning.
the last one is if you have sony writer then you need to upgrade the drivers and firmware for your writer which you will get here. if it is other make, search on google for its firmware.
http://sony.storagesupport.com/models/21
If all the above things dont work, replace it.
Posted on Feb 09, 2009
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the...
ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Mar 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Simple yet idiotic: I go to burn a CD-R (in XP), the wizard wizardizes fine, but when I go to open the CD there is nothing on it and Properties shows 0 bytes used space and 0 free space. Device...
I would start by going into my computer, right click on your burner, select properties then the recording tab and uncheck the box "enable CD recording on this device". Windows burning software causes havoc with other recording programs.
Feb 26, 2011 | LG Electronics 16X DVD-ROM IDE ATAPI DVD...
Does it need a modem or works on it's own ??
It doesn't need a separate modem; it replaces a modem in your home network. If it's properly connected to the phone line, and you have an internet service provider (ISP) supplying you with a broadband connection, and the PC is connected to the router, then it should all work fine.
If it isn't all working fine, the most likely problem is either that the wires aren't connected in the right places, or that the PC's internet connection isn't set up properly (e.g. if you changed from dial-up with a modem to broadband with a router).
If you have recently changed from dialup to Broadband, and you're running Windows, use the Network Connections wizard to set up the internet connection. In Windows XP you can do it this way:
1) click on Start
2) move the mouse to Settings
3) click on Control Panel
4) double click on Network Connections
5) click on File
6) click on New Connection Wizard
7) follow the instructions.
Your ISP should have sent you a CD-ROM to help you to connect, so insert the CD when prompted by the New Connection Wizard.
Sometimes you can just insert the CD into the computer and you'll be prompted to do everything necessary to connect to the internet. BT, for example, do it this way.
Oct 09, 2010 | Trendnet Wireless Home Router TEW651BR
Why wont my mitsumi cr-48x9te cd burner not work
Install a the appropriate cd burner driver software in your
laptop so that it will function properly. A CD disc installer normally goes with the unit you purchase. You
may ask assistance from the store where you buy your
CD burner. Or you can download it from the internet.
Just send in your comments through the e-mail.
Oct 04, 2009 | Mitsumi (CR-4804TE) CD-RW Burner
Lost cd and when i put USB in computer it doesn't work?
The New Hardware Wizard comes up whenever a new device is connected to the computer. At this point, you would usually put the CD into the drive and proceed from there.
Since you have lost the CD, go to http://www.praktica-uk.com/dload.php and select "Driver download for Practica SlimPix 5200" from the drop down list. Click on the Icon and download the file SlimPix 5200.zip. Unzip the file into a new folder and connect the camera. This time, when the New Hardware Wizard comes up, direct the wizard to the new directory rather than let it search for the drivers.
Aug 09, 2009 | Praktica SlimPix Digital Camera
Cant find the properly hardware,hardware not working properly
www.download.com
you can download generic driver from here it is safe legal and free
May 07, 2009 | Logitech Webcam
My computer will not recognize the installation CD and therefore I can't install the program. The registration wizard does not come up and thus I can't enter the serial number. The install wizard has never...
be sure the the CD-Rom is connect proper and just press the IDE cable,power cable and you have SATA drive just replace the sata cable and power cable.
thanks
xyz.
Dec 26, 2008 | Sony ACID Music Studio 6 Full Version for...
I just purchased an lexmarx printer, but I can't installed it because my cd rom drive is not detecting or working properly.What should i do about installing my printer?
if your computer can access the internet, you can simply donwload the driver from the lexmark website for your printer and use the add/remove hardware wizard to install the printer.
you can also copy the content of the disk to a usb flash drive and run the wizard from there.
or you can simply borrow a cd-rom drive from a friend or from your neighbor so you ca install your printer.
hope this'll help you
ciao
Nov 06, 2008 | Lexmark Office Equipment & Supplies
Cd rom problem
If this is a problem that just occurred and until now it has worked, my first step would be to check that the hardware, (the CD drive) is still functioning and that the software, (the drivers) are still installed and not corrupted. First go to the start button, then control panel, then performance and maintainance,go to system, and then hardware. Look for DVD/CD ROM drives, if you have more than one CD or DVD drive, point and left click on the plus symbol to the left of DVD/CD ROM Drives. Point and left click on the drive in question to highlight it then go to action, scroll down to properties and left click. This window should say that the device is working properly and also at the bottom of this window, under device usage it sould say "use this device, enable". If all of this seems to be working so far, the drive itself should be good.If there have been error messages, there is an option on the last window that opened to troubleshoot. Use it. If so far, everything looks good, now check that the drivers are good. Follow all of the above steps up until you open the device manager and point to the drive in question, go to action. This time scroll down to update driver and left click. A window will open that says " welcome to the hardware update wizard". Point and highlight the circle that says" no,not this time" regarding connecting to the internet to search for a driver. If this device has been working, the driver should still be on your hard drive. Follow the wizard prompts. If at the end of the wizard you are informed that a better match could not be found, then most likely the drivers are still good for this device. If after checking both the hardware and the software, you saw no errors and everything looked as though it were operating, the problem may be more than you can solve without some repair expertise.
Oct 01, 2008 | Microsoft Windows XP Professional
Not working
Try unplugging it plug it back in then goto add hardware wizard if you have xp and run the wizard if that doesnt work sounds like you need a new dvd burner
Sep 12, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Lenovo 3000V200 Laptop Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
