Question about Mitel 5220 IP Phone
Changing the main answer message
Have the book for the phone, but it states to push the Admin key, and I have no Idea where it is, or how to get to it.
  • cindy158 Feb 03, 2009
    cindy 158 - still no solution to changing main message on MITEL 5220 IP Phone.
    can not pay for Assistance Plan.
    Please HELP!!!!
    Cindy
  • jwolf37 May 11, 2010
    Are you trying to change the recording for the phones mailbox or the recording for your main auto attendant? The mitel phone doesn't have an Admin key but it does have a superkey which controls most of the funtionality of the phone, it's the blue key. You may be able to get where you need to by pushing that.
    Problem Solver:
  • 8 Answers
Hi Cindy,
a couple of requirements here;
1~ you need to know the VM huntgroup number ie; number dialled to access the voicemail system
2~ the administrator mailbox number usually, 999 or 9999 by default
3~ the admin vm pin code which is usually 8642 by default
basic menu selection;
4 change system gereetings
1 change primary greetings
the system will supply voice prompts to allow you to change system greetings,
The superkey is the Blue key on the top left of the set
4 sys gereetings
1 pri greeting
if you are trying to change AA greetings follow the above just change the VM box number to the one associated with the Auto attendant alternativly you can configure the greeting from the System administration tool under the following ;
Sys Administration menu -> Voice Mail -> System audio files Update
select the AA greeting and greeting type
Posted on Mar 18, 2009
Changing the voicemail message on Panasonic KX-T7731
The KX-T7731 isn't an answering machine.
If the voicemail is on an answering machine connected to your phone line, consult its manual/
If the voicemail is on the phone company's server, look up the instructions in the phone book, or conrtact the company.
Oct 27, 2016 | Panasonic KX-T7731 Corded Phone
Changing voice mail message panasonic kxt7731
If the voicemail is on the phone company's server, look up the instructions in the phone book, or conrtact the phone company.
Oct 27, 2016 | Panasonic KX-T7731 Corded Telephone
I work at a women's shelter that uses the Lucent phone system. Our problem is that we can't change the main phone greeting. I have tried changing it several times from extension 10, and it did record my...
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System2.gif the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. 3 for greetings, 1 for the auto attendant #.press 1 for the day menu or press 2 for night menu and 6 to modify the menu. press *# to skip selector codes.Press 1 to record your new greeting 1 to stop recording. Press *# to approve or 21 to re-record hang up when finished.
Aug 20, 2010 | Lucent PARTNER18 Corded Phone
Phone system AT&T MLS-34D we do not have the manual and I need to change the answering phone message
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,3 for greetings, 1 for auto attendant number, 1 for day greeting 2 for night( if your using a night key at the receptionist station then it usus the night greeting) # to go past selector code, 1 to start recording 3 to accept greeting hang up when done
Apr 07, 2010 | Lands Phones
Locked out of voicemail box!
Hi there, let me give this a crack at it...
The Telephone system sounds like a Norstar BCM... what Consultel1 gave you as an answer is correct, for a Norstar Key system.
OK, do all that Consultel1 stated: -> FEATURE 983 -> You will now see LOG:type in 738662 (SETNNA) and press OK -> You will now see PASSWORD: type in 266344 (CONFIG) and press OK -> then you will see the ADMIN and the options for MBOX, AA, OTHR
Now follow Consultel1 advise on changing Voicemail Passwords, from his orginal post.
Good Luck!
Sep 02, 2009 | NorStar T7316E Corded Phone
Short record time on my answering machine
The only thing I can think of is that there is a switch which determines recording time, there was on mine and then there was the VOX option which only recorded as long as they were speaking and cut them off if they didn't talk quickly. You might check and see if somehow they got turned on.
Jul 15, 2009 | Lands Phones
Cannot change Main Voice Mail Greeting
after dialing 72 you must first hit the instr key in the display than dial 001 or 002.
Apr 06, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Need to change greeting
main system greetings can be changed via the administrator mailbox, dial your voicemail huntgroup number, on answer press the * key and supply the admin mailbox number which is usually 999 or 9999 the default pincode is 8642 then follow the voice prompts to change the system greeting.
Jan 30, 2009 | Mitel 5220 IP Phone
Merlin Legend (Lucent) phone--changing vm list of extension
I do not fully understand you message but it sounds like you want to get into administrator programming of your voice mail.
I don't deal with voice mail programming. My only suggestion is to try and determine exactly which voice mail model you have and find the "administrator" or "programming" manual for the voice mail.
All manuals are available free at www.avaya.com
Apr 25, 2008 | Lucent PARTNER18 Corded Phone
Mitel 5220 IP Phone Logo
468 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
