My 99 alero keeps overheating ,and coolant is full, then when i shut it off it starts gurgling why is that
SOURCE: i have a 99 cadillac eldorado it is overheating i
Hello: Open hood, stand in front of car look on left side (driver side) of engine toward the radiator, there will be a black metal guard, under the guard there will be a small belt. This is the belt that drives the water pump. Make sure the belt is there. If belt is there start car and with engine running check to be sure belt is turning and that the water pump is turning. If all that is okay then you may have blown head gaskets. To check head gaskets you need a sniffer tool to smell the engine coolant which will tell you if you have exhaust gas in the coolant.
SOURCE: 99 OLDS ALERO 2.4 IDLING PROBLEM
intake manifold has a vacum leak or other vacum leak hose etc.
SOURCE: 1998 Chrsler Sebring coolant gurlges - now overheating
yes some systems have to be burped or the boil over can occur in the motor and cause head gasket issues..at 195k i think you should check the system for leaks and thermostat if it is opening at right tempatures or is slow..plus the vented cap on your radiator check with vacuum gauge if it holds about 12-14 psi before it vents...
check the radiator cap if the rubber seal is dry rotted or torn this will cause the radiator to not build pressure properly so the fluid can flow properly.also check to make sure there is no air in the system.please rate this
