Question about Samsung CLP 300 Laser Printer
Internal error on samsung clp 300
There is a internal error showing on my samsung printer that says:
intenal error 40154810
What you need to do is get a new transfer belt, if you email the company they should give you a new one.
Posted on May 28, 2009
SOURCE: Samsung CLP-300 Printer has red light on, won't print, don't see any paper jam
  1. Close all the covers.
  2. Check in the paper tray for paper.
  3. Check for the toner cartridge.
  4. Remove paper tray, toner cartridge and open the back cover for any paper jam.
  5. Please make sure that only supported paper type and size is loaded.
  6. If printer prints after opening and closing the door, try to load different type of paper.
  7. Disconnect the pritner from the computer, and restart the printer.
  8. If Red Light lits up right away, there's a possible paper sensor problem.
  9. If you see a Green Light, press and hold down "Cancel" button for 4 seconds and then let it go.
  10. If it prints the demo page fine, connect the printer cable to a different port or replace the printer cable.
  11. If it goes back to Red Light, pick-up roller inside the printer is defective.
Posted on Aug 23, 2008
SOURCE: new trouble with my samsung CLP-300 printer
Can't believe the geniuses at Samsung didn't respond to this. I had the same problem and as usual, I started tinkering.  Two solutions: 1. Remove the used toner reservoir(located left on the toner cartridges...light grey, "L" shaped object) and discard(be environmentally aware).  Replace with new one. or 2. (My choice) Remove reservoir, empty contents carefully.  Wash thoroughly with cold water until water is clear.  Dry thoroughly with paper towel and blowdryer. Light must be clearly visible through the little magnifying bubble on the side. Works everytime.  Be patient. This takes about 5 minutes.  Can be very messy if you are not anally retentive as I am. :)  Al
Posted on Mar 03, 2009
  • 220 Answers
SOURCE: Samsung CLP-300 Laser Printer
The chips on cartridges are causing the problems.
Posted on Jun 24, 2009
  • 400 Answers
SOURCE: samsung clp 300 shows waste tank full
You will have to buy a new waste tank/bin for it as the old one is now full.
They are relatively cheap.
It looks like this:
http://www.cartridgesave.co.uk/CLP-W300A.html
If you don't want to spend any money you can remove it and try to empty the powder into a bin but it can make a big mess.
Please rate the answer if it helped you.
Thanks
Posted on Jul 13, 2009
  • 51 Answers
SOURCE: can i just print black from my samsung clp 300
Yes, you have to pick file for print instead of just print. And choose grey scale only.
Posted on Apr 06, 2010
Where to download the driver for Samsung CLP-300 Laser Printer
Go to http://www.samsung.com/uk/support/model/CLP-300/ELS-downloads?isManualDownload=true and select Drivers from the left hand menu - this will show a choice of drivers to use with all supported operating systems including Windows 7.
Dec 09, 2011 | Samsung CLP 300 Laser Printer
All the lights are flashing
When the status LED is flashing red, it means there is some minor error(i.e. the front door isn't latched shut, paper is jammed, etc) or the toner is getting low.
Double click on Smart Panel (the blue S in the task bar...it's installed with the driver) and it will tell you what the error is. For future reference, you can download the manual at our support site: http://www.samsung.com/us/support/downloads/CLP-300
you can also have a look onto the below link
http://answers.us.samsung.com/answers/7463/product/CLP-300/samsung-clp-300-dsl-questions-answers/questions.htm
Mar 17, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP-300 shows red light . what does it
Dear ,
Install a smart pane software from samsung.com and search clp-300 printer and download the software.
Sep 27, 2010 | Samsung CLP 300 Laser Printer
I have samsung printer 1600. The printer not pick
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=06010200&model_name=CLP-300
The above is for the clp-300 laser printer.
You say you have a samsung print 1600 but when I searched I found a blue ray player with that number.
Is this the right link?
Jul 20, 2010 | Samsung CLP 300 Laser Printer
Our Samsung CLP 300 's red light stays on..
Install a smart panel on PC and see the error on the PC screen.
Oct 26, 2009 | Samsung CLP 300 Laser Printer
Samsung clp-300 Error message is "fuser low heat error"
your printer toner is not installed properly. pls shake the toner & fix again.
Sep 01, 2009 | Samsung CLP 300 Laser Printer
I have a printer of samsung clp-300 series laser but i have a problem about with this driver cd it cant run on win-vista-ultimate-it show me that it is not supported for vista
try:
http://www.samsung.com/uk/support/download/supportDown.do?group=printsolutions&type=printsolutions&subtype=colourprinters&model_nm=CLP-300&disp_nm=CLP-300&language=&cate_type=all&dType=D&mType=DR&vType=R&prd_ia_cd=06010200
They now have vista listed there....
Cheers
Jan 05, 2009 | Samsung CLP 300 Laser Printer
System Error. lower heater is not warming. I have reset the printer. but no response. My printer model is SAMSUNG CLP-310 SERIES. WHAT TO DO NOW?
It's a internal issue of printer. you need to check your printer warming heater. because in the printer you can find two warming heater they are used for waming the text of your printer cartradge ink. go to neares service center and check it.
Dec 01, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
403 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
