Question about HP Compaq Presario SR5612F-B Desktop PC & Monitor BUNDLE
Complaint Problem: =>1:Monitor problem monitor screen usually shiver . =>2 :Dvd drive problem And whenever i run any kind of cd/dvd in my dvd drive, my computer gets hanged.And mouse and keyboard don't work and that time my dvd drive and speakers both make loud sharp sound.
  • Dan rogers
    Dan rogers May 11, 2010
    is this a new system you recently purchased?
    Habit-Forming:
  • 34 Answers
It seems to be either part of a Virus, or a system bug, Make sure you have an up-to-date Antivirus, if you do, it might also be several component isues, check the device manager to see if any of your components have any errors. Or the best resolution to your problem would be to get the restore CD that comes with the PC and restore it back to its original manufacturer's defaults, if you don't have it you may also find it through hp.com's support site.
Posted on Feb 12, 2009
Where to look to put a disc in my all in one dell
Many new computers do not come with a CD/DVD drive. This may be the case with your All-In-One Dell. Check your owners manual to see if a CD/DVD drive is included. You can also look on the left or right sides of the screen/monitor to see if there is a CD/DVD slot.
If you find that you do not have a CD/DVD drive, an external one can be purchase for $50-100 from numerous places.
Example:
Amazon com LG Electronics 8X USB 2 0 Ultra Slim Portable DVD RW...
Aug 28, 2014 | Computers & Internet
Computer screen has shifted 3 inches to left, how do I correct?
You did not say what type and model of monitor, so this may vary. There are buttons on your monitor. They will be on the front, bottom or side of your monitor. Look for the *menu* button and press it. A menu will display on the screen. You need to check which buttons have little arrows on them. these will help you go thru the menus as you need. You need to look for a *Reset* or *Factory Reset* or a *Default* settings, which will make you monitor return to the original state it was in when shipped from the factory. Hope this helps.
Oct 09, 2013 | Gateway E-4300-2 4-Bay Computer - 2900765...
Monitor shows driver must not watch the monitor while driving
hi philip, your model has a cable on the harness called "park brake" which needs to be connected to ground/black wire. this wire functions as an enable/diable to the video output to the screen. once it is connected to ground permanently the video/movie will display whenever a dvd disc is inserted. cheers.
Feb 26, 2013 | JVC AM FM CD DET FACE CAR STEREO
How do I connect my laptop to a Monitor
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 06, 2012 | HP Pavilion dv9000 Series Laptop DVD Drive...
Monitor is black. How do I fix it?
if the monitor led indicator is amber and and the hard drive (usually red) indicator on computer is blinking red. that means your computer is working but onboard video is dead. if under warranty, bring it back for replacement or repair.
Sep 23, 2009 | E-Machines eMachines Monitor E15T4
Problem:Monitor problem and Dvd drive problem
open your cpu and clean all dust from it.reattch all power connection and harddisk connection .also clean dust form RAM and refix it.
ten enter i bios setup.
then load optimal defaults settings.ten save and exit.
Feb 02, 2009 | HP Compaq Presario SR5612F-B Desktop PC &...
Acer Monitor AL1706 freezes w/ horizontal lines after burning cd
The issue is you system, download memtest86 and run it from disk if you get any error your ram is bad or it my be the program you are using try uninstalling it and reinstalling it
Dec 09, 2008 | Acer AL1706AB LCD Monitor
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
LG GSA-4167B DVD Writer... PC restarts whenever any CD is inserted
What is happening is that the dvdrom firmware or the laser is failing and cannot read the disc; and because the pc is using all the system resources trying to do so; it appears that you cannot get anything to run, making it seem as if the hard drive is faulty also, though not the case. You will need to replace the drive if this is a common occurance, as the life of a dvd drive nowadays dependant on use is aprox 2 years, because as the prices come down so does the quality of the laser required to burn and read discs.
Aug 25, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
No picture
A blue screen suggests no input signal, or a signal that the electronics in the screen can't handle. I don't think you need the remote, but, it may help. I suggest you try the dvd on a working monitor and check that it's a compatible output. The LM-S6001 is a multi-system monitor both NTSC(US) and PAL(Europe/Aisa). The monitor has a composite video (usually yellow) and RCA(phono) input and DIN, the manufacturer is unclear if both plugs are present. You can assume it's auto-switching, but that may not be the case. More information is needed to fully understand your problem. 1. make/model of DVD. 2. description of external plugs on monitor.
Apr 24, 2007 | Savv LM-S6001 Car Monitor
HP Compaq Presario SR5612F-B Desktop PC & Monitor BUNDLE  Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
