Question about MSI K8N Neo4 Platinum PCI-E (NON SLI) Socket 939 Mainboard (MB7125010) Motherboard
Still odd warning sound when starting the computer
When i am trying to start my computer, it just makes odd and really anoying and loud warning beeb sounds.. beebs last like second or two and then theres a little longer silence part but the computer wont start.
Bought a new cpu and cpu fan. Tried everyone of my memory chips one at the time.. and STILL nothing.. the same beeb comes over and over again.. i know that this problem is about my bios settings, about overclocking but how on earth i can revert these settings without actually getting into the bios? Help me please, going crazy!
Could all my memory chips be broken or something.. thats all i can think about this..
  • anttivalli91 Feb 03, 2009
    resetting cmos helpd :) thanks!
    Sergeant:
  • 219 Answers
Reset your CMOS...
If you don't have a Jumper to reset the CMOS, pull out your power cord, open the computer, and pull out the motherboard's battery leaving it out for about a day (Don't plug in the computer's power cord during this time period). About 24 hours later plug the computer's power cord back in and try a boot (Don't put the battery back in to your motherboard at this time).
If this problem persists check manuals to see if there is a method to reset the CMOS by moving a jumper. If there is not such a method available you might have to send the motherboard back to the manufacturer requesting the BIOS ROM chip be replaced. Depending on if you're still under warranty or not you might have to pay a small fee.
If at any time the boot is successful, enter the BIOS and save the default settings. Afterward shut down, pull out the power cord, and place your battery back in to the motherboard.
Hopefully you get it fixed.
Posted on Feb 02, 2009
When i switch on my lenovo m58 desktop i get a beeb sound then the fan starts being loud then it automatically switches of then the loud sound from the fan continues....i've tried to remove the ram and the...
This is short false-alert of the time gap during start-up, and it happens on Intel based boards. Just take care of fan controls in BIOS, and try to locate missplaced fan connectors viewing the board layout. I know the lunatic who plugged a processor fan into system fan connector, and everything works fine, but monitoring is too bad, got it?
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Mar 18, 2014 | Lenovo ThinkCentre M58e 7298 Core Duo...
Engine making loud sound when attempting to start.
Diesel or Petrol?
Any warning lights on on the dash?
Oil pump working ok?
Check your timing belt?
Dec 04, 2012 | Cars & Trucks
HELP 04 Hyundai Sonata Intake
Boy, it sure seems a lot of work to capitalize every word...
It is an odd answer, but I think one or more of your intake valve are not sealing. Engines make a horrific amount of noise if you pull one spark plug, then start it with the other plugs still in.
There just is nothing in the intake system that can make noise, except what is on the other side of the intake valves.
Do a compression check. If the intake valves are having a sealing problem, the compression will be low.
If the cam that opens the intake valves is late, you could get a short backward flow just before the valve shuts, which could make some noise.
This is a truly odd complaint you have. But that;s all I can think of that could do this.
Jun 27, 2010 | Hyundai Motor 2004 Sonata
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
Front end noise - Basically really loud "howl" when driving
Try jacking your vehicle up and turning the tires. listen for any odd noise like a grinding sound, wheels hubs have been known to make a grinding noise when they go bad.
Mar 22, 2009 | 2002 Honda Odyssey
Odd warning sound when trying to start computer
Beep codes from the bois normally indicate a hardware configuration or faulty hardware error. From the msi site they are using award bios. Here is a link to what the codes mean.
Listen carefully to the beeps and try to identify the problem and fix it.
From the MSI it looks as if there are very particular memory configurations make sure you have it setup correctly. Link.
Jan 29, 2009 | MSI K8N Neo4 Platinum PCI-E (NON SLI)...
Anoying
My mom and dad had this problem, after replacing the bulb everything is working great again.
Jan 25, 2008 | Hitachi 50VG825 50 in. LCD HDTV
MSI K8N Neo4 Platinum PCI-E (NON SLI) Socket 939 Mainboard (MB7125010) Motherboard Logo
96 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
