Question about Kenmore Washing Machines
Kenmore washing Machine not agitating.
My washing machine, a kenmore 110.9223810 is not agitating to wash.  It loads and despense the water.  What could be wrong.
    Problem Solver:
  • 4 Answers
Try spinning it if that dont spin or not as well as it did its you bushes,you can temporary swap the left wth the right till you find them cheap to purchase
Posted on Feb 02, 2009
Why does my Kenmore washing machine leaks in front when agitating?
Most likely the sight of water leaking from the front of the machine, means it is leaking from somewhere else. Check all inlet and outlet hose connections. Hard water deposits build up and can cause minor leaks over time. If it is only noticeable during the wash cyclee,(agitating) it is possible there is a leak in the drum. Rare, but possible.
Jun 11, 2014 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Kenmore Washing Machines
Kenmore top loading washing machine model 4021092, keeps filling
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
May 03, 2010 | Kenmore Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Water will not drain from washine machine
it could be your lid switch or your water pump
Mar 17, 2009 | Kenmore 22642 Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
My washing machine water wont drain,it is a kenmore 90 series.
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Jul 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing machine
ck lid switch also ckd hinge screws that looks like newer moder with switch under left side of console try pressing left rear corner of lid or listen for clock when lid is shut slowly
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
96 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
