Question about Home
Dish washer not working
We have a Whirlpool dish ADG642 washer and no water is going into the machine?
    Problem Solver:
  • 19 Answers
Close the hot water valve to the water line feeding the machine and disconnect the water supply from the valve.Once you've done that than slowly turn on the valve to see if their is any water flow if their is water coming out of the valve than you probably have a problem with the pump.
Posted on Feb 03, 2009
Samsung dish washer DD81-01549A_EN How do you reset the dish washer it won't wash it just hums
Humming could be no water going in, check fill hose.Or get a bucket of water put into drum then start machine helping to Flush out.
Oct 21, 2017 | Samsung Washing Machines
My dish washer has started to flash Err 7 on the screen and will not work. I ahve cleaned everyhting out, put drainO down the drain, turned it off for 1 week then back on again, checked that the hoses
F7--7 Flashes--Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked
make sure water is getting to your machine, its possible that the hose is kinked and not feeding water sufficiently to the machine.
alternatively, Unplug the appliance.
Take it out of it's position.
Take the left side panel off.
In the large plastic tank on the left side of the machine is the flow meter.
It's a small pcb with a 2 wire plug on it.
Pull the plug off and push it on again.
Do this several times to clean up the connection.
Ensure the connection is dry and tight.
Try the machine again.
If it still doesn't work, you'll need to obtain and fit a new flow meter to try and cure the problem.
Apr 03, 2013 | Dishwashers
How do you replace water intake hose on machine
under the kitchen sink there is a water valve that is attach to a hose that goes in behind the dish washer that feed the water to it,,,,the dish washer is attached to the counter by two screws in the front of it,,take them out and the you can slowly pull out the unit,,,to change out the water feeder hose,,but make sure you shut off the water going to the dish washer first
Feb 19, 2011 | Dishwashers
Dishwasher does not fill with water
change the water valve on the dish washer.send the model number and i can tell you the part number or if your dryer has it check to see if something is stuck under the float inside the dish washer,if it's stuck up in the air it stops the water from coming into the machine
Feb 18, 2011 | Whirlpool Dishwashers
It lets a little "soaking"
your belt went bad in dish washer replace belt. dont keep runing that like that you will burn the moter up in dish washer
Feb 15, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My new dishwasher leaves a white residue on my pots. pans and stainless flatware. I have not changed soap. Could the water not be hot enough?
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Sep 19, 2010 | Whirlpool Dishwashers
Dish washer fills and then drians without washing
If you're sure it is heating the water, then it sounds like the wash motor/pump has failed. If you've worked on washing machines and/or dish washers before, this is potentialy a DIY job - the Haynes Dishwasher manual is very good, and parts can be found on the internet.
The reason for cheking it is actually heating the water is that the symptoms sound very similar to those of a failed heater = fill, pause, empty, stop usually accompanied wth an error code. Error code will be presented by a number of flashes of a lamp, or a number on a display panle depending whch machine you've got.
Sep 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Home Logo
70 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
