Question about HP Compaq Presario SR5612F-B Desktop PC & Monitor BUNDLE
Problem:Monitor problem and Dvd drive problem
Problem:
1:Monitor problem
monitor screen usually shiver .
=>2 :Dvd drive problem
And whenever i run any kind of cd/dvd in my dvd drive, my computer gets hanged.And mouse and keyboard don't work and that time my dvd drive and speakers both make loud sharp sound.
    Genius:
  • 1,913 Answers
Open your cpu and clean all dust from it.reattch all power connection and harddisk connection .also clean dust form RAM and refix it.
ten enter i bios setup.
then load optimal defaults settings.ten save and exit.
Posted on Feb 02, 2009
2 Suggested Answers
jea2381
  • 34 Answers
SOURCE: Complaint
It seems to be either part of a Virus, or a system bug, Make sure you have an up-to-date Antivirus, if you do, it might also be several component isues, check the device manager to see if any of your components have any errors. Or the best resolution to your problem would be to get the restore CD that comes with the PC and restore it back to its original manufacturer's defaults, if you don't have it you may also find it through hp.com's support site.
Posted on Feb 12, 2009
Shivering screen
Shaking or trembling of a computer screen is often caused by interference from another device that is within a couple feet.
It can also be caused by another monitor close by.
If the removal of these objects does not stop the trembling, the monitor may have built up magnetism and need to be degaussed.
Find the menu button for your monitor.
This is usually on the front of the monitor.
It is sometimes on the side of the monitor.
Push the menu button. Scroll down until you find the screen option.
Select "Screen."
Scroll down to the degauss option.
Select "Degauss."
Select "OK."
The screen will make a tuning sound, as if you hit a guitar string.
The screen will shake and vibrate.
The shaking should now be gone.
If it is not, it will need to be looked at by a professional.
May 04, 2013 | HP Computers & Internet
Monitor
Try getting anything that may have a magnetic field away from the LCD (speakers, phones, any electronic product), does the problem persist?
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Crt screen shivering with some noise inside
From the description the high voltage inside the set is arcing that would explain the shivering in the picture and the noise you are hearing, the monitor is on the verge of failure and should not be left unattended while it is running.
Apr 02, 2012 | Computers & Internet
My monitor is shivering due to magnetic field tell me solution
Solution for many "jittery" or "shaky" or "shivering" monitor problems...
Be sure there are no power AC cords in direct contact with or very close to the monitor cable anywhere along its entire length. If no help, be sure the monitor and monitor cable are not very close to a wall that may have an AC power lines running in it. Also, be sure that you are using a "grounded" (3 prong) power cord, that is is not plugged into a "2 prong" adapter that eliminates the ground ("earth") prong, and be sure that your power circuit that you are plugged in to is properly grounded.
Dec 08, 2010 | Gateway HD2201 22" LCD Monitor
My screen keep on shivering and i can't stop it
Its like Hororizontal wave and its only happen once in a while not all the time!
Mar 16, 2010 | Gateway HD2201 22" LCD Monitor
Screen shivering
Time to get new monitor.
Aug 24, 2017 | HP Computers & Internet
Complaint
Feb 02, 2009 | HP Compaq Presario SR5612F-B Desktop PC &...
Acer Monitor AL1706 freezes w/ horizontal lines after burning cd
The issue is you system, download memtest86 and run it from disk if you get any error your ram is bad or it my be the program you are using try uninstalling it and reinstalling it
Dec 09, 2008 | Acer AL1706AB LCD Monitor
Aoc 17 inch silver black monitor problem
main regulator capacitor for the hot side of the power supply may need replacement, usually value is 220uf to 400uf 400 volts..
Apr 27, 2008 | AOC CT720G 17" CRT Monitor
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
HP Compaq Presario SR5612F-B Desktop PC & Monitor BUNDLE  Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
