Question about Dryers
Hotpoint TDC30S tumble dryer not working.
Fuse OK; filter cleaned; water emptied. ????????????
  • stevey_andre Feb 02, 2009
    Thank you kachbibi1. I tried your solution. I bypassed the thermal fuse and there was a buzzing noise and a burning smell. I would like some more advise please, if you have time. xx
  • stevey_andre Feb 03, 2009
    Thank you again kachbibi1. I tried again; there was nothing at all this time. I found the motor (after removing some screws and a panel) but it seemed OK. I followed the wires to the control panel and I could smell the burning (even though there was no power). After removing lots more screws, two struts and the front panel, I removed a melted and burned micro-switch, which is activated by a plastic pin in the door. I bypassed this and reassembled the whole thing (which took some patience). IT WORKED! So, I'm going to order a new door-switch and attempt to fit it. Thank you so much.
  • 979 Answers
Remove the back of the dryer and you will see wires going to a small terminal block. You could have your problem here. First, I would check to see if the plug is properly wired. A wire could have come loose there. If this doesn't work, then check underneath the top of the dryer. This is easy with onlt 4-6 screws to remove. You will find a themal fuse there along side of the drum. Bypass it and see if it works. This will more than likely be the problem. If not, reply back and we will go further from here.
Posted on Feb 02, 2009
  • Bill Dickerson
    Bill Dickerson Feb 03, 2009
    Hi Steve, it sounds like you got right on this. If you are getting a buzzing sound and burning smell, then this is probably why the thermal fuse blew. It protected the rest of your dryer. If you are not sure where the buzzing came from, try this again and and direct your attention to the motor that turns the drum. Don't leave it on long as it could do permanent damage. I am thinking your motor is or has burned up and you are smelling the wiring from within the motor. There may be a buzzing coming from the control panel as well. Try this and let me know back and we will go to the next step or feel free to call me at 803 463 5567. I enjoy these sight unseen projects.
  • Bill Dickerson
    Steve, you have done the hard part already. You are now in the homestretch. Good job finding the problem.
How do i clean filter at bottom of hotpoint condenser tumble drier. Water coming out at base.
if you mean the condeser itself ...it just pulls out..........best way to clean is with a hosepipe gets all the fluff out....but.if you have water leaking...........best bet is to check the tank at the rear.....at the bottom of the base.....the tank operates via a piece of plastic or fibre which floats up as the tank fills.....which inturn hits a micro switch
...setting the pump going to pump the water to the empty tank........check the float first.........
cheers
May 02, 2017 | Hotpoint Dryers
I have a tumble dryer Condensed Hotpoint Aquarius tcm570. The empty water indicator is on. I have cleared the,filters and no water was in tank. I have noticed it is taking longer to try clothes and the...
Dryer need to be clean out .
all area of lint screen down to were are comes out or fan may be blowing stripped blade on motor.
Need whole model # of dryer to quote you parts cost
Mar 01, 2015 | Hotpoint Dryers
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
Feb 05, 2013 | Hotpoint Dryers
My hotpoint ultima dryer has no power to it changed fuse checked plug socket emptied water tank cleaned both filters
power comes in at mains lead goes to the choke /filter from here onto the door interlock switch then onto timer ......hope this helps
Feb 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
Tumble dryer
pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Mar 12, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
How to fix Hotpoint CTD00 Tumble Dryer?
http://www.fixya.com/support/t232066-hotpoint_ctd00_trips_power
The link above should solve your problem. I have the same problem and my parents who bought the same tumble dryer also had the same problem. Its water backing up to the fan then its hitting the heating element which is tripping the electric off.
At the back of the Tumble dryer near the bottom you'll see a panel that has about 8 screws that you can taqke off as well as a small panel that cover the pivet for the drum. If you unscrew this you will see the fan and heating element and no doubt a small puddle of water and damp dust that has clung onto the panel. You should dry this with kitchen roll and clean the old dust off then carefully turn the tumble dryer on (at your own risk lol) or you can take the advice of the person who posted the link above and use a hair dryer. This will stop the element getting wet and tripping off.
Also there is a water reservoir to the right of the panel i mentioned. If you prise the clips open and remove the top section you will see the water in the reservoir. If you look inside it on the bottom left hand side there is a little **** that the water drains in from. If you use something like pipe cleaners or a knife and wiggle it about you may have some fluff or hair trapped there that is making the water back up to the fan and causing the tumble dryer to trip off.
Hopefully this willsolve your problem for the time being but the filter in the bottom of the dryer needs to be cleaned thoroughly every week or so to stop this happening again.
Personally i think this is a major design flaw and the tumble dryer should be recalled but Hotpoints aftercare service is awful to say the least so lesson learnt, don't buy a hotpoint tumble dryer!
Feb 01, 2008 | Dryers
Not heating up
I would check the thermo fuse in the back of dryer.. its on the burner towards the top.. use omh meter and check if its good. If you dont have a meter, if very careful and just hook wires togeter and tape so nothing touches and will not short out by touching anything, bypass switch JUST to see if switch is bad! Replace it if bad
Sep 05, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
151 people viewed this question
Top Dryers Experts
