Kyocera printer no.1118 cannot scan to mail because of error1101
    Sniper:
  • 54 Answers
This is a scan to email error code
The scan isn't registering the dns servers properly, so the smtp server name isn't getting resolved. Replace the server name with the server ip and this should resolve you error. Let me know how this works for you.
Please remember to rate me.
Posted on Feb 02, 2009
Guyscan you help me configure Scan to email from a Kyocera Copystar 250ci printer what settings will i look around to configure scan to gmail or other email clients
You need to find where to enter the settings for an smtp server. (simple mail transport protocol) Most internet service providers allow clients to use their smtp server. For instance, for Shaw in Canada to smtp server is mail.shaw.ca. Some will require authentication in which case you will need to have a valid account with that provider.
Jan 22, 2016 | Kyocera Office Equipment & Supplies
How do I fix kyocera 1118 showing err a3 200?
scanner unit dusty please clean than solve problem
Sep 23, 2015 | Kyocera FS-1118 Printer
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
Resettare codice errore c6 su kyocera fs 1118
If the code is C6400, then just follow the procedure showing in the images below.
If the code is C6000, then you have to remove the fuser unit and check the thermistor, the thermal cut out and the heater lamp. If are able to fix the problem-damage, then follow the procedure below to reset the service call.
b6abe89e-6db1-403f-b1d5-10039126b726.jpg 6bbf89df-5e1f-4ba9-830e-5fa3e278ce55.jpg
Mar 16, 2014 | Kyocera FS-1118 Printer
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
When i scan to email, i get an error; "send error 2202" and the document is not sent to email. The Kyocera fs-1028mfp printer is connected to the LAN using a network cable.
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
Sep 12, 2011 | Kyocera FS-1118 Printer
HOW DO I SCAN DOCUMENTS
pls sleep down on your bad and cried loudly
Apr 14, 2010 | Kyocera FS-1118 Printer
Kyocera fs-1118 When I want to use scanner Message a cannot connect the machine Any solution? Before reinstaling WinXP work fine.
are you able to take print ........... and have you installed the paper cut software for scan the document ..... please check while you connecting printer to your pc its detecting or what ...... please check above thing .... please post your comment if you facing same problem ...............
Jan 13, 2010 | Kyocera Office Equipment & Supplies
Kyocera FS1118 mfp gives error code CF 040 after start up
do a google search for the service manual and then lookup the error code in the service manual
Jan 23, 2009 | Kyocera FS-1118 Printer
290 people viewed this question
jasbo
jasbo
