Question about Hotpoint Aquarius WF000 Front Load Washer
Loose Paddle in the Drum
I have a loose paddle and I believe i can tighten it if I get the top off but although I have removed the two screws at the back it wont move. Any ideas how I can get the top off and is the right method for tightening the paddle
  • Barry Coates
    Barry Coates May 11, 2010
    Can you please confirm the make of washer, because if it is a Hotpoint, then you do not need to remove the top.
    You did not state the make in your post.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Not the right method, the paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare part and come with instructions. you will need to varify which version you have by counting the bumps on the end of the padle, should be 2 or 3.
basically you put a small screwdriver down on of the holes in the top of the paddle, i think the 3rd one, to push the metal drum tab down enough to be able to pull the paddle towards you and out of it's slots. carefull not to push the tab down too far as it will bend inside the drum and isd pain to bend back again.
Posted on Feb 03, 2009
Remove loose change from washing machine
Depends where the loose change is? Some times it caught between the middle paddle and the basket.Tthat I just use a small flat tip screw driver and finger, trap it and lift carefully out. If the coins are underneath the basket then its more involved. First, tape the door down and lift top cap and prop up aside. Then remove tubs cap off of tub. Next inside basket in the center, remove center cap off of paddle. Then remove bolt from center. Remove paddle." This I use a screw driver small enough to fit in paddle holes, one on each side to lift equally,back and forth." You will find six phillips head screws under paddle you need to remove. This should be able to lift the basket out. Walla!! T
here's the bottom of the tub and anything lying there should be removed. If you want to really inspect it there are two 5/16th head screws that hold a protective plastic plate that should be removed and checked sense your there any ways. good luck to you and hope this helps.
Feb 21, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
The paddle is not off but loose on Maytag neptune model mde4000ayw dryer, how do you make a repair on it.
you need to remove the drum, and tighten the paddle,, look on this site on how to remove the drum http://repair2000.com/wpoolbelt.htm
May 29, 2011 | Dryers
The paddle has come loose inside my dryer how can I get the lid open to get to the back of the drum
take the 2 screws out of the door and take out the other 2 screws opposite the hindge screws,close the door,now grab the sides where you took the screws out of and pull forward and this will remove the front panel,take out the 2 top 5/16 screws one on each side that go through the metal holders,they are the screws closest top the top lid,remember how the holders hook into the top cover and the catch is in the middle of each piece,now lift the top and spin the drum so the baffle(paddle) is on the top and you can get at the screws to tighten them,the top doesn't lift to far up so you might have to lay down and tighten them from the floor,this is how i've done it ,hope this helps
Jan 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
Fin / paddle has come loose in the drum.
The paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
Any further help, Let me know.
Thanks for using Fixya.
Do rate the solution 'Fixya" if 100% satisfied.
Apr 30, 2009 | Washing Machines
Maytag Atlantis MDE6200AYW loose dryer paddle
You might have to remove the back, then the top, but it looks like the paddles are either held on buy a screw from the outside of the drum or they just have clips that lock them to the drum. Once the back is removed, you should be able to see how the top is held on. I think it is screwed or has clips for the back and then you slide it forward to unlock the front tabs. You can follow this if you don;t get a reply
from someone who has worked on this model#. Hope you get it apart ok and fixed by yourself.
Mar 14, 2009 | Microsoft Windows XP Home Edition
Excessive wear between paddle and panshaft?
You can drill and tap the paddle, where it faces the flat on the shaft, and install a small setscrew. Something like a 10-32. Make sure you use a nylok screw or use a thread locking compound (available @ auto parts stores) to prevent the screw from working loose and getting into your bread! Just tighten the screw enough for a snug fit so that it can be removed for cleaning.
Jan 13, 2009 | Breadman TR2200C Ultimate Bread Maker
Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
Dec 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Hotpoint Aquarius WF000 Front Load Washer Logo
288 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
