Question about Campbell Hausfeld 26 - Gallon Air Compressor
Air leakage through pressure switch needle
When the compressor stops it starts to release air through the pressure switch needle.Air releasing only stops when pressure goes down to cut in pressure,where the compressor restarts.
Condor Model MDR-21 (General Model SWP60401U-C)
    Problem Solver:
  • 19 Answers
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Posted on Feb 02, 2009
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
My compressor will start and run well but when it turns off it will turn but not run stalls and kicks the breaker
It sounds like the small valve that releases the pressure out of the main pipe that runs between the compressor and tank is not working once the tank is full and the motor automatically cuts off. You know this valve is working by the sound of a short spurt if air being released when the motor cuts off. Releasing this pressure means that the motor is able to restart easily because there is no load. If the valve is not releasing this air, the compressor is trying to start under full load which the motor is not capable of doing, hence the humming and popping of breakers due to a current overload as the motor tries to start. Motor burnout is possible if it keeps recurring.
This small release valve is attached to the Pressure control switch that switches the motor On & Off and usually has a small pipe going to it or is incorporated inside the Pressure Control Switch.
Sep 17, 2010 | Porter Cable Cable 20 Gal 150PSI Oil Lube...
My compressor builds to 125 psi then shuts off like it should then when the pressure is released the compressor wont start back up. Sometimes it will attempt to start and it sounds like the motor is...
When a compressor reaches set pressure, there should be a release of air from discharge hose thru the unloader. This release of air unloads the compressor head pressure. The unloader is usually located within the pressure switch. Easy to check. Follow discharge hose from compressor head to tank. There should be a brass/steel checkvalve at the tank. The checkvalve allows air to enter tank, however not allow air to be released back into discharge hose. If this valve is leaking, air will be released from the unloader constantly. Follow 1/4" tubing from checkvalve to unloader and listen for leaks. Repair as needed. If air is not leaking from checkvalve then check unloader mechanism with-in pressure switch. Parts are available at Good luck
Aug 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor problems when filling tank
There should be a device called an "unloader " connected to the machines own switch. This releases the pressure from the compressor so it can start up without the resistance of the pressure in the tank.There should be a hissing noise when the machine stops, the sound of the air on the compressor side of a non return valve being released.
Jun 03, 2010 | Campbell Hausfeld 13 HP 30Gallon Air...
Keeps on cycling on and of when not in use?
I believe you have a faulty pressure switch. The black hose reports to the switch what the pressure is and either starts or stops the compressor through the switch. Air is bleeding out of the hose ...causing short cycling ... for some reason. Fix the leak - fix your problem
Thanks for using
positive comments always welcome
Oct 27, 2009 | Hitachi EC12 Portable Electric 2hp Air...
DeWalt emglo compressor does not start
well,you have to release the pressure,the cut out pressure at 120 psig.reached,and the cut in pressure maybe at 40 after realeasing pressure at cut in the compressor will run.if the compressor not run at cut in or after releasing check your power supply if still have,swicth off power breaker,by pass pressure switch,by disconnecting the line on terminals of pressure swtich,connect the line w/out pressure switch
the wire line should supply the the compressor,
open the service valve of compressor,switch on
observe if compressor run and develop pressure or air is coming out to nozzle,if that so switch off again and replace pressur have defective pressure switch,regards rate me,thanks
May 02, 2009 | Heating & Cooling
Air compressor - pressure problem
'When the machine is shut off, disconnect the discharge line out of the head of the compressor. If air releases, replace discharge check valve in tank.
Mar 30, 2009 | Air Tools & Compressors
Trips breaker starting under load
The problem that you describe is caused by pressure in the airline due to faulty in-tank check valve and/ or the unloader at the pressure switch. When the compressor cycles off the pressure switch releases the air that remains in the air line thru a small valve. There is a 1/4 " tube extending from the check valve to the switch. Listen for the release of air as soon as the compressor stops. There is a small metal tab that pushes on the unloader valve that may need to be adjusted. The motor does not have enough power to start pumping if there is air/backpressure in the air line. If these parts are working correctly then check the value of the start capacitor and use meter to measure. The cap should test within 95 % of stated value. Replace parts as needed. Enjoy
Dec 18, 2008 | Coleman 3HP 11 Gallon Oil Lube, Direct...
Compressor comes on and hums and goes off and does it again, ?
The fact that your compressor completes a cycle indicates that the motor and pump are probably working correctly, however when the pressure switch cycles off there should be a slight release of the air that remains in the airline. If this air is not released thru the unloader of the pressure switch the motor cannot overcome the back-pressure in the airline and just hum. There should be a 1/4 in. hose extending from the pressure switch to the checkvalve in the tank. There is a small tab and needle valve that releases the air. Also check that the tank checkvalve is not leaking air back into the airline as this would cause back pressure. Finally, failing motor start capacitor will cause motor to hum. Weak capacitor will start motor when cold and no pressure in tank, but when things heat-up and with pressure in tank, motor may not have enough power to overcome load and hum. Enjoy
Oct 29, 2008 | Dewalt D55140BN Heavy Duty 2 Inch Brad...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
865 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
